Old 04-20-2011, 11:38 AM
vclifford vclifford is offline
Mein Auto: 530i
tools for a new owner
Hi,
I am a new owner of a 2001 530i. I am planning to do a coolant system overhaul and other stuff which will come my way. I have common hand tools , sockets , drive, extension etc. What else is specific to BMW.
Do I need 32 mm wrench for fan clutch or a 32 mm socket mounted on 1/2" drive will do.
http://www.harborfreight.com/32mm-x-...ket-67830.html
I will first try a screw driver for holding the waterpump from turning and then go for special tool.
For general repairs Do I need to get a set of Hex keys, and a set of torx keys ( I have some torx bits from volvo).
Regards,
Old 04-20-2011, 12:42 PM
bobdmac bobdmac is offline
Mein Auto: 2001 540i/6, '90 BMW k75s
You need the wrench. Clearance is tight, and you'll have trouble fitting a socket in there.
BMW--giving new meaning to the phrase "disposable income."
Old 04-20-2011, 12:53 PM
Fudman's Avatar
Fudman Fudman is offline
+1 on the 32 mm wrench
36mm for oil filter cap
16mm thin bicycle wrench for sway bar links
wobble adapters are nice (better than a universal) for getting to spark plug #6
Hex and torx bits are always handy and fairly cheap at HF
Old 04-20-2011, 01:08 PM
Originally Posted by vclifford View Post
...I will first try a screw driver for holding the waterpump from turning and then go for special tool.
If you order them separately, you'll end up paying almost double the freight. Expect to spend a little under $50, including shipping for the two. If you get them separately, you'll spend closer to $75. I searched and searched and debated and debated and finally said, "The heck with it" (or words to that effect), and ordered both, from an eBay supplier. They just arrived and look good.
Old 04-20-2011, 03:31 PM
ZeroDfx's Avatar
ZeroDfx ZeroDfx is offline
Mein Auto: 2000 528iT
Depending upon whether you will be changing tranny & diff fluids yourself, you'll need to get a couple large hex head sockets (14mm?) and some smaller ones (6-7mm?) to remove brake calipers & rotors.
2000 528iT sport (Sienna Red w/ Tan)
2000 540i/6spd (Sienna Red / Tan)
Old 04-20-2011, 04:26 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Right on. You will also need T30, T45, T20, and T25 bits. If I remember correctly, a 8mm hex is needed also.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-20-2011, 06:18 PM
Mein Auto: 530i
Thank you guys. I guess an adjustable wrench should be fine for the 36 MM oil filter housing.
Old 04-20-2011, 06:31 PM
Whorse Whorse is offline
Mein Auto: e30, e39
After owning 3 BMWs you end up needing a bigger tool box. no joke
Andreas
Queens NY
BMWCCA# 186796
86 325es (wrecked by careless driver)
87 325 300k (project for life) aka 1BADETA/Christine
00 540is 6spd 202k (daily driver)
Old 04-21-2011, 03:57 AM
Fudman's Avatar
+1
Old 04-21-2011, 06:26 AM
DAVLOH DAVLOH is offline
Mein Auto: 2003 530i sport 5sp
add a good torque wrench to the list.
Old 04-21-2011, 06:32 AM
GSXRYDER GSXRYDER is offline
Mein Auto: 540i
Start with
This set...you will not be sorry
99 540i-6 Sport
Pure
Adrenalin!
Old 04-21-2011, 08:55 AM
Mein Auto: 530i
Judging by this I guess you have spare engines in your basement and 2-3 parts cars in backyard
Old 04-21-2011, 09:47 AM
daw daw is offline
Mein Auto: 1998 528i 5sp - 175K mi
If you've got a 1 1/4" open end wrench, it will work fine instead of a 32mm for removing the fan clutch.
Old 04-21-2011, 01:37 PM
ZeroDfx's Avatar
HELL NO!! Unless you want to spend another 4-5 hours removing a lot of the front end to R&R the complete oil filter housing!! Here's the link to the procedure from a BMW Tech who documented the DIY: http://forums.bimmerforums.com/forum...1#post13970831
I just learned this the hard way; it took me a full day since the procedure was new to me.
For the cost of $8.99 plus tax you can pick up a 36mm 1/2" drive socket that will fit on a torque wrench to make certain all the force on the filter cap is vertical and not horizontal (pulling it away from the engine block).
Old 04-21-2011, 02:50 PM
Mein Auto: 530i
Thanks for the advice. I guess a 12 pt socket will be fine as well. Do you really use a torque wrench to tighten that, I do have one but this sounds like high standard for oil filter cap.
Regards,
Old 04-21-2011, 04:28 PM
Mein Auto: e30, e39
Hahahaha Very close, I have 1 spare engine in the garage along with an e30 and another e30 worth of parts. (parts car chopped up to save space) lol Just got this new box cause my old roll away was so over stuffed i couldn't open the drawers or find what i needed asap.
And the jesus statue in the corner is my helper on tedious e39 repairs.
Andreas
Queens NY
BMWCCA# 186796
Old 04-21-2011, 04:47 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: 2005 330/2013 F30 M sport
This is what I use. Been adding to my collection for a while. EBAY actually has great deals on used tool boxes.
And yes, it is filled with MAC Tools.
Name:	3 after.JPG
ID:	275504   Click image for larger version
Old 04-21-2011, 04:59 PM
Mein Auto: e30, e39
nice! now we gotta join a tool box forum, flat bed our boxes to shows and clean em up for concours class lmao
Andreas
Queens NY
BMWCCA# 186796
Old 04-21-2011, 05:06 PM
Whorse - I saw your box and thought "My new best friend!!"
On a serious note - a good set of tools will really save you thousands of dollars. I've done the cooling overhaul, brakes, oil filter housing gasket, and other small repairs. I can honestly say my tools have paid been paid for. Oh yeah, lots of oil changes!! At 128,000 miles I have no problem driving the car to California and back. Every repair I've done was done with DIY's from this website. Oh guys, invest in a a set of HEAVY DUTY jack stands. I still don't like getting under the car without a lift.
Old 04-21-2011, 05:47 PM
Mein Auto: e30, e39
lmao, if my garage was tall enough i would already have a lift. We have been looking to buy our own house and every house we went to look at i was only concerned with the garage. lol yes i got problems
Andreas
Queens NY
BMWCCA# 186796
Old 04-21-2011, 06:08 PM
If you ever have a job that needs a second pair of hands, let me know. I'm right across the river.
Old 04-22-2011, 08:57 PM
There is no way you can get a 32mm socket on the fan clutch nut because the water pump in on one end and the fan is on the other.
However, you can easily make or buy for a few bucks decent fan counterhold & 32mm open-end wrench tools (from this thread) :
For brakes, these are the tools you'll need (from this thread):
See also from the bestlinks ...
Basic Tools:
- Basic tools needed for working on the BMW E39 (1) (2) (3)
- Where to get the BMW Bentley shop manual (1)
- Where to get a cheap OBDII DTC scanner (1) (2) or a better scanner (1) or the best diagnostic tools (1) (2) (3)
How to make your own E39 specialized tools:
- How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1) (2)
- How to make your own BMW thrust bushing tool (1) or buy them (1) (2) or improvise (1)
- How to make your own BMW car ramps (1)
- How to make your own BMW subframe & differential bushings tool (1)
- How to make your own BMW oxygen sensor removal tool (1)
- How to make your own BMW single-VANOS solonoid socket tool (1)
- How to make your own BMW camber & toe-in alignment tools (1)
- How to make your own BMW hella headlight adjusters (1) (2)
- How to make your own BMW rtab removal tool (1)
- How to make your own BMW upper timing chain locking tool (1)
- How to make your own BMW flywheel locking tool (1)
- How to make your own BMW cylinder head bolt removal tool (1)
- How to make your own BMW cam locking nut tool (1)
- How to make your own BMW crankshaft holder tool (1)
- How to make your own alignment tools to adjust toe-in and camber (1)
For oil changes, these are what is needed (from this thread):
Old 04-22-2011, 09:10 PM
Mein Auto: e30, e39
One little correction Bluebee, You right about the wrench not fitting between the fan and pump BUT this does not go for all wrenches, My craftsmen wrenches don't fit but a cheapo name brand wrench i have does fit with no problem. I never had to use the pump holder unless the belts were already off the engine. I use the wrench and a rubber mallet after about 3 wacks it spins right off.
Ill check out what name brand it is tonight
Andreas
Queens NY
BMWCCA# 186796
Old 04-22-2011, 11:12 PM
I agree.
There 'are' (long handled, thin) open-end wrenches which 'do' fit (they're all covered in the aforementioned thread).
But, here is where the OP used the word "socket" & specifically a 1/2-inch drive socket:
So (Bob &) I were responding to the socket part only.
As Bobdmac intimated, there's just no way a "socket" will fit (but, as you said, a thin and long open-end wrench will fit just fine - but it has to be long and thin to work best).
BTW, I asked the same 'dumb question' over in that thread ... only I was assuming (incorrectly) I could use the box wrench on the nut. I was quickly disabused of that notion:
Yes. This is what 'most' people do. It's all covered (with videos) in that aforementioned thread for the OP.
Me? I prefer to use the right tools. Here's a picture of my tools:
And, here's a picture of my counterhold tool in action:
Since the tools to work on your BMW are free, I generally buy the right tool for the right job.
However, some people make do with whatever they have handy:
But, for me, I just don't trust myself with a crescent wrench on the pulley or swinging a mallet on the nut as you can see people hit the plastic radiator and busted it open in those threads ...
I suggest the OP simply get this 8-dollar wrench:
Old 04-25-2011, 07:33 PM
Melrose Melrose is offline
Mein Auto: 540i
You don't need the clutch holder just the wrench. Whack the wrench with the hammer. Remember, It is a left -- hand thread, and it will pop right off. You can get the 32mm Thorsen wrench at BIG LOTS for $4.00
