E30 (1982 - 1993)
Old 04-19-2011, 11:00 AM
kanemack kanemack is offline
Mein Auto: United States
s52 to e30 whats front drive shaft?
im new to this swap so bear with me. i have a 87 e30 and im putting a s52 engine and trans(zf type) does anyone know the correct drive shaft for the front half and what car i can get it from? thanks in advance for any help.
Old 04-19-2011, 05:29 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Engine is irrelevant. It's the transmission that decides which one you are using. Do a google search, you will find what you are after. Iirc none of the 24v boys here have used that gearbox
E30 above Sold
Last updated 2nd January 2014
Old 04-19-2011, 07:11 PM
no one used it? is this trans a bad idea or just not common?
Old 04-20-2011, 03:12 AM
Using a getrag seems to be more common, I would assume because most people already have the one out of their e30 which bolts up. There are people out there that use the zf though
E30 above Sold
Old 04-20-2011, 06:20 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
You remember wrong. zf is the most stout and robust trans, G240 is what I prefer it holds up to 300hp no sweat.
Old 04-20-2011, 01:45 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
you remember double wrong brah... mark has a ZF i believe
and the stock manual drive shaft i believe will work..(dont quote me on that one)
believe my info until steve pops up and calls me a moron
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-20-2011, 02:20 PM
On Top
it won't. The holes on the E30 flange and e36 giubo are 2mm smaller/larger. You need to use the front half of an e36 328i driveshaft, with the rest of an e30 one auto or manual are the same on the rear shafts.
So in short, you need a front half of a 96-98? e36 328i driveshaft and have it rebalanced with your the rest of your driveshaft.
Old 04-20-2011, 07:44 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Yes!
My car has a E36 M3 manual trans drive shaft with a E30 center support bearing (CSB) mounted backward. IIRC the E36 M3 autobox shafts have a CV joint at the diff side.
I recommend driveshafts.com. They spin balance their shafts at 2500 RPM and will accept your E30 shaft as a core return for the E36 unit.
I Timothy 2:1-2
