Old 04-24-2011, 09:31 AM
vetaldj vetaldj is offline
Mein Auto: 2015 VW eGolf
HELP!!! Power steering pump drain plug locatation for bleeding
Hi all,
I'm in process of changing my leaking power steering hose (1997 528i) and having problems with finding bleeding screw at my pump... Looks ike I'm looking in wrong way or something - I checked all links I found here and some of them clearly show that plug and I just can't find it... Did anybody do that for '97 528i?
Any help/tips will be very appreciated...
Commuter: 2015 VW eGolf SEL Pacific Blue, 20K
Pleasure: 2016 X1 xDrive Tech/Driver Assist/Cold Weather, 6k
Pleasure: 2010 X5 35d Monaco Blue/Saddle Brown with Premium/Technology/Sport/Climat, 80K
SOLD - 2003 525i Green M Susp/M St Wheel, 202K
SOLD - 1997 528i Silver, 116.5K
BMWCCA Member # 447308
Old 04-24-2011, 11:42 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I'm under the impression that there isn't a power steering drain that is easily accessible. Most people just change their fluid, and when they do that, suck it out of the reservoir and pour in more fluid, and bleed it by cycling the steering wheel a few times. HTH
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 04-24-2011, 06:05 PM
Well, problem is that I don't need just fluid change, I need to change hose so I need all fluid out in one time... Will post pics to show my pump
Old 04-24-2011, 06:42 PM
I've seen pictures of the V8 E39 showing a drain bolt at the bottom underside of the power steering pump; but I don't see that same drain bolt on my I5 M54 engine.
If you do a quick /power steering(F3) in the bestlinks thread, you'll see tons of pictures showing how to drain the fluid and how to replace the hoses, including the cn90 tricks which save a hose or two from the recycle bin.
Old 04-25-2011, 04:04 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
The I6 does not have a drain plug.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-25-2011, 01:17 PM
Thanks bluebee and Jimmys 530i, now I'm feel better because I started to think that I'm blind or something...
Now I need to find the cleanest way to do that... So, I need to first extract as much as possible and then dissconnect some hose, correct? I will read all helpfull links first focusing on this way.
Old 04-25-2011, 02:30 PM
microswitch's Avatar
microswitch microswitch is offline
Mein Auto: 2006 5251
99c Store. turkey baster is a wonderful tool.
( just makes sure you wash it before you decide to bast the turkey) .. lol
If you want to go the expensive route .. autozone vacuum gauge/pump $ 23.40
also check CN90 D.Y. on the cooling overall .. He has a session on repairing the leaking power steering hose
Old 04-25-2011, 02:39 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
You can only extract about a cup of fluid from the reservoir using a turkey baster.
If you are replacing a hose why don't you just disconnect the hose from the pump and put a can or pan under it to catch the fluid in. The pump, hoses, and cooling loop in front of the radiator holds more than you will get out of the resevoir.
Old 04-25-2011, 02:42 PM
That's what I'm going to do but I decided first to find it out here if it's OK to do so.
I'm new to E39 and BMW as well as DIY kind of thing and I'm scary to brake something while fixing something you know.
Old 04-25-2011, 02:44 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
My 2001 530i didn't have a drain plug.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 04-25-2011, 10:54 PM
Thanks for clarifying as I wasn't sure myself since I could clearly see the V8 drain but not the I6 drain.
Yup. 8 fluid ounces (or, in that strangely odd world system, 250 ml).
That's just about how much I got when I measured it last week:
- How much volume of power steering fluid do we have in the E39?
To the OP, a quick /power steering(F3) in the bestlinks nets this, among others:
- Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1)
Old 04-26-2011, 04:09 AM
If you drain everything completely, including the cooler, you will need 2 quarts. I just done this a couple of days ago, it will get messy.
Old 04-27-2011, 12:30 PM
Ok, now question which hose to remove.... I've read all links (well, all those that I found) but didn't find any good information how to remove fluid w/o drain plug.
First, I will suck all fluid from reservour. Then, how to proceed? Which hose I can disconnect to drain fluid? can I disconnect that one that comes to the pump? Or, can I disconnect return pipe coming to container, put it to some conteiner and start the engine without moving steering wheel for a few sec?
I will do it on parking near store so I need to make as less mess as possible so that's why I want to know how to procees with this....
Thank you all!
Old 04-27-2011, 12:48 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
I just loosened the banjo bolt to drain mine
Old 04-27-2011, 05:21 PM
By bajo bolt you mean bolt that holds hose "04 PRESSURE HOSE ASSY" on this pic?
1997 528i P/S
Old 04-28-2011, 03:42 PM
chiefwej's Avatar
Freude am Fahren
Mine is a 540 so the pump and connections are different. On that pic 9 &6 are banjo bolts, but on my car (see below) I loosened #6 or maybe #3.
http://www.realoem.com/bmw/showparts...27&hg=32&fg=20
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 04-28-2011, 04:21 PM
Oh well, I will do that then simple way, with mess
Thanks all! I will report back with results soon.
Old 04-30-2011, 10:36 PM
Ok, final update. I did it today!! Hurray!!!
My steps:
- Extracted all fluids from reservoir
- Removed reservoir from bracket
- Disconnected return hose from coil over to reservoir (this is the one that was replaced) from reservoir. Here I've got some fluid from reservoir but I was ready with towels and empty container.
- Disconnected 13mm bolt that holds two hoses at coil over BUT didn't removed them, while holding top one I just removed bottom one (that goes to reservoir and need to be replaced), got some fluid out but not much.
- Put new ring and attached new hose to its place
- Cleaned reservoir all hoses from mess
- Re-installed reservoir and added new fluid
- made about 10 turns, almost all fluids gone so I added some more to the almost MAX and made same 10 turns but this time level was the same.
- Cleaned everything and hurray - my first serious DIY done with success!
Thanks all for help and support!
