E30 (1982 - 1993)
Old 04-23-2011, 12:39 PM
pancho1984 pancho1984 is offline
Mein Auto: 1991 325i Cabrio
tie rod - not enough threads?
Hey ya'll,
so I changed my entire front suspension with FCP Grotons kit incl M3 bushings.
Strut mounts, new bilsteins, control arms, innner+ outer tie-rods, links, bar bushings.
OK - took it to the alignment shop. Guy tells me passenger tie-rod doesn't have enough turns to adjust. Drivers side adjusted well, but passenger he says needs another 5 turns or so.. saw it, and yup tie rod is aaaaall the way in. machine showed a -9 value so it looks severely off. My steering wheel is also pointing at 10-11 oclock when going straight...
anyone run into this problem before? guy told me to try to cut another 5-10 turns to be safe using a die.. which i can do butttt.. that's not the point. From what I've read, M3 control arm bushings only affect caster and shouldnt have any influence on toe.
Help?!?!
Old 04-23-2011, 06:33 PM
downhiller's Avatar
livin large
have you tried lock to lock to see if one side has more. if not then someone might of cut the tie rods wrong
Old 04-23-2011, 06:36 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
sounds like your steering rack wasnt centered when he started. try a different shop.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-23-2011, 07:48 PM
ok So the steering is supossed to be centered before starting?
what are the steps to do an alignment? It's one of those mystery topics for me hehe I've taken down trannys but never dug around alignments...
so steps to do an alignment.. anyone?
steering was pointing at 10-11 o clock when riding straight, before the taking it to shop. It could have been that when they lifted the car on the rails obviously the wheels will be straight (thus the steering was crooked to begin with..).
I would find it strange for it to be the shop though... online they have like almost perfect reviews that's why i took it there. It's kind of in the hood, but it's one of those shops that that's ALL they do ALL day long so I even made the special trip there.
Anyone else.. ever run into this problem? What would you recommend as a next step?
thanks for your help peeps...
Old 04-23-2011, 08:50 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
agree with steve
Old 04-23-2011, 10:27 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Originally Posted by eieio4tn View Post
agree with steve
I third that. Sounds like that shop isn't too knowledgeable. Like Steve said take it to another shop
Old 04-24-2011, 03:18 PM
thanks guys
I will follow your advise and take it to another shop.. it's just so whacky. Car's never been in an accident.. seems like adjusting Toe is a rather simple procedure, screw in/out. How much skill can this actually take..?
Pardon me if I sound utterly ignorant, but from what I've read, only real adjustable value in the e30 is toe sooooo.. yeah. It's just puzzling. Plus I dumped 60 bucks.. agh.
Are hunter machines any good at alignments? Thats what the guy used.
Old 04-24-2011, 04:03 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
An alignment machine is only as good as it's operator. If the person doing your alignment didn't know to center the wheel before starting, he didn't know what he was doing, period. That's the first lesson in Alignment 101.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-24-2011, 06:31 PM
Krumchev2's Avatar
Straight Bimmin
Originally Posted by pancho1984 View Post
thanks guys
Most don't do it by hand, most are done by machines. Although the machine should adjust the toe, like the post above me states; the operator must first center the wheel prior to adjustment.
Old 04-25-2011, 09:59 PM
downhiller's Avatar
livin large
and also during the alignment it has you turn the wheel, center it steering wheel, compress the suspension then adjust. he must of skipped a step
Old 04-26-2011, 02:17 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
^ this x10
4 or so years ago when i still had shops align my vehicles i had the exact same thing happen on my datsun after i replaced all the suspension components. Politely told the guy to go F. himself took my car home and aligned it myself
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
