1987 325 (2.7L) Clutch - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 04-25-2011, 09:15 PM
D.Furian D.Furian is offline
Mein Auto: BMW 325
Question 1987 325 (2.7L) Clutch
Over the past couple months I have noticed the clutch slipping gradually getting worse until finally burning out and getting no acceleration. However, when I put it in "ANY" gear it goes in with out grinding...seems odd I thought when the clutch burns out that it can't get into a gear. Is there anything else to consider replacing when doing the clutch? I will also replace the flywheel and throw out bearing...Thanks for any replies.
Dallas
Old 04-26-2011, 02:18 PM
dreamketcher dreamketcher is offline
Mein Auto: '84 318I...'87 325 eta
You may not have to replace the flywheel... if your preassure plate has lost it ability to work properly one could could sill shift and go no place... clutch and p plate are changed together.
hth
Old 04-26-2011, 09:57 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
As mentioned above, the flywheel wont need to be replaced, it should be resurfaced though. And as for the clutch kit, it will come with a new pressure plate, clutch disc, and throw out bearing. Those should be the only components that need to be changed unless you notice something else abnormal.
