Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 09-16-2010, 08:14 PM
LPLAW740IL LPLAW740IL is offline
Mein Auto: 740il
Can put the rims of a 750 on my 740il?
hello can anyone tell me if I can put the rims of a 750 on my 740il?
Old 09-17-2010, 06:11 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
What years?
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 10-11-2010, 09:18 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
Yes
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 12-31-2010, 07:21 AM
Vecoplan Vecoplan is offline
Jeep on 42s, B7 on 22s.
Mein Auto: 2006 LJ, 2008 B7, 2015 X5
yes... with exception of the "X" SUV models all the BMWs have the same bolt pattern. The issue is going to be the size of the tires, as the E65/66 models run a relatively huge tire for a car.
Just because I said it doesn't make it true... it just makes in my opinion. Conversely, just because you said it doesn't make it true, and I'm still going to form my own opinion. meverhart@vecoplanllc
Old 12-31-2010, 08:47 AM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
The "issue" is also the offset.
White 1993 850Ci - 251,187 miles
Black 1993 850Ci - 125,508 miles
Old 12-31-2010, 11:14 AM
M.Wong's Avatar
Mein Auto: The E38
But be careful, not all BMWs have the same hub size...
M.Wong
Old 01-11-2011, 10:53 PM
BayAreaBimmer's Avatar
BayAreaBimmer BayAreaBimmer is offline
Supporting 'Fest Member
Mein Auto: 1994 530i Manual
I'm 99% sure you can
Justin'94 530i 5-Speed
"I hit the gasser, go faster, all you hear is dual-exhaust flow master."
All California BMW owners click here for a meet and greet!
Old 01-15-2011, 02:16 PM
JUNEBLOOD JUNEBLOOD is offline
Mein Auto: BROOKLYN
Yes
Old 05-06-2011, 06:13 PM
Carabinieri-One's Avatar
Carabinieri-One Carabinieri-One is offline
I'm Your Huckleberry!
Mein Auto: 7
Should work, but as others have mentioned
There are a few things you have to make sure of. Center Hub size for example may be different. On my 07 750 the Hub is 72.6 on a X5 it is 74.1 and like one of the other members mentioned, the offset has to be correct, so that the wheels don't stick out too far or too far in.
Last but not least is the Tire size. Hope this helps
Name:	The 7 Passengerside Rear View.jpg
