Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 05-01-2011, 03:12 PM
Judy G's Avatar
Judy G Judy G is offline
Mein Auto: 2015 535 M-Sport
Programming garage door opener woes
What is the secret? I have a new 528i and a Genie opener. We just spent half the day and can't get it programmed. We searched and followed instructions from the opener co and this board and no joy!! The problem is it is not taking the code from the hand held opener.
535i M-sport
2011 528i sport gone, but not forgotten
2012 E93M sport (totaled)
Old 05-01-2011, 07:28 PM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
I've found them temperamental at best. It's definitely as simple as holding the transmitter button in the car and then the garage remote to get the frequency programmed. But the distance from the remote to car transmitter needs to be right. I recall having to try different distances and angles to finally get it accepted. Once you get the frequency right, it's just a matter of pressing the LEARN button on the back of your garage dor opener and pressing the transmitter button in the car.
Keep trying. It's most likely *not* you!
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 05-01-2011, 11:45 PM
Yorgi's Avatar
Yorgi Yorgi is offline
One thing I noticed when programming my Genie garage door openers is only the middle button on the 3 button remote would work when training/programming the car. I used the same middle button on one of my remotes to program all 3 Homelink memory buttons in my car. i.e. Each Homelink button in the car opens a separate garage door even though I used only the middle button on the same remote to "train" all 3 Homelink buttons. If you have single button Genie remotes you can use the same remote to program all 3 Homelink buttons in the car.
1) Use the BMW Homelink training instructions to program a memory button in your car. Like TopDownInFL said, you may need to hold the remote 3" away or maybe 24", buttons facing up or maybe facing down. You need to experiment.
2) Once the car has "learned" your remote (you know this based on the correct flashing light sequence mentioned in the Homelink instructions), press the "add remote" button on the Genie opener in the garage then run out and press-and-hold the button you programmed in your BMW. You need to check the Genie instructions on the correct method to add a new remote. I believe you need to press the Homelink button twice.
3) Use the same procedure that worked for you in step 1) to program the next memory button in your BMW. Then repeat step 2) on your next garage opener.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 05-02-2011, 01:27 PM
Judy G's Avatar
We had to replace the controller. It would not connect to the car. It was a simple process once we had a new controller.
535i M-sport
Old 05-02-2011, 03:18 PM
tlm999 tlm999 is offline
Mein Auto: '15 Macan
Distance is critical. I tried over and over holding the remote about 6 - 8" away as the owner's manual instructions indicated. The next day I went to the garage door opener web site and found instructions that said 1 - 3". That did the trick as it took the first time.
Old 05-03-2011, 12:01 AM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
In my case I had to use a full-size opener to do the programming, and even then I had to use a brand new battery for that opener, and have my car's engine running. If I tried using a key-chain opener, an opener w/ a slightly old battery, and/or had the engine off, the programming just wouldn't take. Once it's programmed it works well though. Mine's opened my garage doors every time I tried, and from a pretty decent distance too
Old 05-03-2011, 07:17 AM
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
Try this. http://www.homelink.com/program.php
I always find mine a little finicky, but these instructions have always worked for me.
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 05-03-2011, 01:07 PM
335i Driver 335i Driver is offline
Mein Auto: 335i
Sometimes it just won't work. I had no trouble at my old place, but in my new garage I never could get it to work after multiple tries so I just gave up. Yes, I did everything suggested above.
Old 05-03-2011, 08:52 PM
MB330's Avatar
MB330 MB330 is offline
Mein Auto: 2006 330i
In my case, I was able to program my car after I install fresh battery in remote control.
'16 320i Alpine White/Black/AT [ZDA, 494, 205, 459, 403]
Old 05-07-2011, 09:38 PM
KellyL KellyL is offline
Mein Auto: 2005 BMW X5
I had trouble too and researched it on the internet. I had to have someone get on a ladder to push a button on my garage door opener, then I had about 45 seconds to program the car unit and it only worked on button number 3, but that one works fine.
Old 05-09-2011, 08:52 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
That was also my situation - lots of frustration until I discovered I had to press a "Learn" button on the overhead unit. Luckily, with a convertible, I was able to simply lower the top, park under the unit and stand on the passenger seat.
Tom
Old 05-09-2011, 11:45 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Originally Posted by Tom K. View Post
...stand on the passenger seat.
Hopefully in stocking feet I presume!
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 05-10-2011, 06:22 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
If you would have done a search you would have found out that all the things you did are in the search plus you could have called homelink and they would have walked you through the procedure and you wouldn't have all the trouble you encountered.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 05-11-2011, 12:25 PM
Yorgi's Avatar
cheers
vern
And if everyone did a search there would probably be 10% of the traffic on the forums.
I learn half of what I know by reading answers to questions that have been asked 100s of times and answered over and over. When someone re-asks a question everyone sees the answer and it increases the general knowledge of everyone on the board.
'04 M3 - track
Old 05-11-2011, 01:26 PM
Then why have a search Some of the subjects have been beaten to death,like the garage door opener. Search is your friend if you do one you will find out.
cheers
vern
Old 09-23-2012, 07:57 PM
jdevereaux0001 jdevereaux0001 is offline
Mein Auto: 325i
garage door programming sux
Ridiculous. I could NOT program my Genie garage door remote until I inverted the key fob 1 - 3" away from the rear view mirror receiver. It FINALLY took the garage code but now wont open the garage door. For those of u who have been successful at this nonsense, congrats. My 2008 535i is being retarded.
Old 09-24-2012, 06:53 AM
Thumbs up
Call homelink they will walk you through it and everthing will be fine .
Good luck
cheers
vern
Old 10-03-2012, 11:25 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
It's amazing how a simple thing can be such a pita. Glad you got it set up. N4S
