Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc...
Old 04-21-2011, 07:09 PM
drez14 drez14 is offline
Mein Auto: 2004 BMW 745Li
Hello,
I think i might need some clarification on how this works. I have a E66 with an L7 amp that is broken (wont drive the subs) Will this device help me go around my broken amp, or do i need a properly functioning amp for this to work. At first i thought that this will bypass the amp, but im beginning to get the feeling (from reading other posts about L7), that this will only convert the high output signals from a working amp to low output signals to be routed to an aftermarket amp.
thanks
Willis
Old 04-22-2011, 12:25 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Hi Willis
A functioning OEM amp is required for this harness to work.
The issue with the Logic7/Premium OEM amp is that it is a digital-proprietary (MOST) inputs amp so a proprietary device is required to handle those inputs. There is no aftermarket amp that can be used to directly replace your OEM amp.
There is a MOST preamp device available for certain BMW but it is not available for the 7-Series in particular: http://www.mobridge.us/sites/default..._Manual_V3.pdf
Originally Posted by drez14 View Post
Hello,
I think i might need some clarification on how this works. I have a E66 with an L7 amp that is broken (wont drive the subs) Will this device help me go around my broken amp, or do i need a properly functioning amp for this to work. At first i thought that this will bypass the amp, but im beginning to get the feeling (from reading other posts about L7), that this will only convert the high output signals from a working amp to low output signals to be routed to an aftermarket amp.thanks
Willis
Old 04-22-2011, 04:47 PM
Thanks for the reply technic. I thought i could get away with a fast one this time, but it looks like my 7 has beat me yet again.
Old 04-23-2011, 05:25 AM
gadg8man gadg8man is offline
Mein Auto: 2007 BMW X5 4.8i
Amplifier harness for E70 X5 with Hifi stereo
Originally Posted by Technic View Post
Improved harness is now available:
- add a trunk sub and/or power the underseat woofers with a separate amp, no need to cut OEM wires or harness itself
- quick underseat woofers connectors with 12AWG wires labeled for easy connection to your aftermarket amp outputs
Price the same, $85 shipped... :thumbsup:
I am designing an audio system for my 2007 E70 X5 and I would like to use one of your wiring harnesses, they look great and I would prefer to not have to splice into the factory wiring harness if possible.
I am planning on using the JBL MS-8 connected to a JL Audio HD900/5 amplifier.
The MS-8 requires either a full range low level input or several speaker level inputs that can be summed to provide the full range signal. I would prefer the speaker level input, to remove the LOC from the picture and reduce the possibility of noise in the system.
Can you provide a harness that would have the speaker outputs clearly indicated that can just be plugged directly into the amplifier? If so, I would like to order one.
Thanks in advance
Chris
Newfoundland, Canada
Old 04-23-2011, 02:17 PM
Technic's Avatar
Test... 1, 2 ,3
Hi Chris
I can create a MS-8 to OEM harness (no LOC) for full integration depending of the X5 OEM system. I have no Top HiFi harnesses available for the next 3-4 weeks, though.
Thanks in advance
Chris
Old 04-24-2011, 01:29 PM
Firebirddrvr Firebirddrvr is offline
Mein Auto: BMW 335I
Im looking to add a kicker solo baric with 1000 watt amp to my 2007 e90. I'm pretty sure I have the logic 7 system. Will this harness work for me? And all I will need to add is the power and ground correct?
Old 04-24-2011, 07:09 PM
Technic's Avatar
Test... 1, 2 ,3
Yes you do, yes it will, yes that's it...
Old 05-05-2011, 01:17 PM
jason53 jason53 is offline
Mein Auto: 335i
Any update on when the harness will be available....
Regards,
Impatient in VA
Old 05-06-2011, 03:06 AM
Technic's Avatar
Test... 1, 2 ,3
The harness should be available the week of the 20th of May...
Old 05-18-2011, 12:46 PM
Technic's Avatar
Test... 1, 2 ,3
Harness will be available for sale by next Tuesday... thanks for your patience and support.
Old 05-24-2011, 04:39 AM
Technic's Avatar
Test... 1, 2 ,3
Harness is available...
Old 05-24-2011, 06:21 AM
Mein Auto: 335i
Awesome, what is the best way to order?
Old 05-24-2011, 11:06 AM
Technic's Avatar
Test... 1, 2 ,3
Use PM, please...
Old 05-26-2011, 09:26 PM
g9buf g9buf is offline
Mein Auto: E60 M5
As a quick and efficient solution for those that would like to either add a trunk sub or replace the OEM woofers with SWS-8 (or doing both), this is a custom made, plug 'n play complete harness with a built in, 150W max Navone LOC -custom made for this particular application- with remote turn on signal output right at the harness itself -no need to run a remote wire from the cabin.
This harness connects between the OEM amp and the OEM audio connector using OEM connectors, wires are properly soldered and labeled so no OEM wires need to be cut, spliced or tapped cut. Just plug it and add the amp. Navone LOC takes care of the Logic7 high power woofer outputs, so interface with any aftermarket amp is guaranteed.
Quantities are very limited as this is just a test of the potential market of a harness like this. It can be also used in 1-, 3-Series and X5/X6 Individual Audio/Premium systems.
Price: $75 thru PayPal shipped in the USA, 1 year warranty in case of defects or malfunctions. Warranty void if harness is modified in any way.
hello mate im in the uk i want 1 of these looms for my e60 m5 with logic 7 could you send one over for me ?? thanks dude
Old 05-29-2011, 02:03 AM
Technic's Avatar
Test... 1, 2 ,3
PM replied...
Old 05-30-2011, 11:53 AM
robsey29 robsey29 is offline
Mein Auto: e60
Hi mate could you tell me will this fit a e60 2005 with the standard system?
If so could you pm me a price with delivery to the uk!
Cheers
Matt
Old 05-30-2011, 10:50 PM
Technic's Avatar
Test... 1, 2 ,3
Cheers
Matt
If your standard system is the Stereo system (6-speakers, no OEM amp) then this harness will not work.
Old 06-03-2011, 05:57 PM
Technic's Avatar
Test... 1, 2 ,3
Bump...
Old 06-06-2011, 01:53 PM
Technic's Avatar
Test... 1, 2 ,3
Bump...
Old 06-09-2011, 11:52 AM
edmonem's Avatar
edmonem edmonem is offline
Mein Auto: 97 528i
cool product man, looks simple and effective. i have a 97 528i without dsp...i have no idea what this logic7 system is????? but would your setup work fine for my e39? im very interested in your product. let me know.... thanks.
BMWCCA member #446696
aloha state
Old 06-09-2011, 07:08 PM
Technic's Avatar
Test... 1, 2 ,3
Unfortunately, no.
Old 06-17-2011, 05:30 AM
rilot rilot is offline
Mein Auto: 2006 750i Sport
I'm interested in one of these for my UK L7 equipped 750i. Can you ship to the UK?
Old 06-18-2011, 10:54 AM
Boostednut Boostednut is offline
Mein Auto: 745Li
I need one of these I have a 2002 745Li I will check to see if I have the logic 7 my goal is to run aftermarket subs/amp and run a separate amp on the front and rear high/mid speakers..is this possible?
Old 06-18-2011, 01:22 PM
Technic's Avatar
Test... 1, 2 ,3
Yes I can... please use PM for details.
Old 06-18-2011, 01:26 PM
Technic's Avatar
Test... 1, 2 ,3
This Logic7 harness is only for adding a aftermarket amp to your OEM amp to either drive a trunk sub, power the underseat woofers or both as is.
If you want to add more amplifiers to drive the rest of your speakers then the harness itself will have to be cut and modified accordingly. I do not support/warrantee such use but it can be done, however you will need more than just adding another amp (search for JBL MS-8).
