Ever hear of Winhere brake rotors??
Had a noise in my brakes, figured it was the big ridge on the edges of both front rotors (original rotors at 105k miles!!) causing the scraping sound. So I pulled them off and took them to my local favorite FLAPS to put on the brake lathe and remove the ridge. But they ended up turning the surface of the rotors too and ended up below min. With the car up on jackstands in my driveway and a nasty storm fast approaching I couldn't wait a day for Zimmermans so bought a pair of rotors they had in stock- Winhere brand. I've never heard of it and I've probably changed a couple hundred brake rotors on all the cars I've owned over the past 35 years of driving.
But, I figured for $32 each it would worth a shot. Put them on, got out my dial indicator, and they're absolutely round and true. Bedded them in and so far so good. Time will tell. At least in my case the 528 isn't my back road play toy. Just hope they hold up to the daily commute.
2004 E53 X5 4.4 Sport 1997 E39 528i 1986 911 Track car 1996 R1100R |
It's certainly not in the most recommended set of rotors list:
- What brake pads & rotors are recommended for street use on the E39 |
Zimmerman coated or OEM. The rest are just that.
The rest.
I agree, except that Zimmermans weren't available when I needed them. Was able to get Zimmermans same day for my X5 a few months ago but I guess the E39 is old enough that the largest supply house in the Chicago area doesn't keep them in stock.
Oh no! Don't say "too old". It makes me feel, well, OLD.
Either you are part of the solution, or you are part of the problem. |
I don't mean to ignite a flame war ... but ... um ... isn't a rotor ... well ... um ... isn't a rotor just a rotor?
I mean ... what on earth could they do differently with rotor A versus rotor B if both are the OEM size and form factor (i.e., not drilled or slotted but vented just like the OEM rotors). I'm sure lot's of things 'can' be different (e.g., materials used & tolerances); but, practically, are there 'really' major differences between the various brands of rotors of the same fitment? Isn't a rotor, a rotor? |
Theoretically, I get your point. But I once had a Jeep where both front rotors completely rusted away from the hat and I had no brakes as a result. When I took it apart there was a donut and the hub hat in two separate pieces. I kept those in my garage for years as a reminder. About a year later, Chrysler had a recall on their rotors. Wonder why.
Point being, there certainly is a difference in rotor quality.
So Winhere, Losethere?
We carry zimmerman, ATE, Balo, and then some.
http://www.eaceuroparts.com/parts/BM.../5510/35432665 |
I opened a separate discussion over whether a rotor is a rotor, or not, over here:
- Is there 'really' a difference between (standard) E39 rotors of various brands? I have no datapoints other than intuition ... but ... my default is that a rotor is a rotor (assuming OEM fitment and recommended brands such as those EAC Tuning carries). |
I just read this thread! Any Updates on how these rotors are? I am thinking of getting Winhere for my 2002 330ci?..
Thanks |
I have these rotors for more than 20k miles now and no problem.Rotor is rotor.
Do not drive it like you steal it!It's a BIMMER |
Cool Good to know.. was just wondering if their product could be trusted.
Now can purchase with confidence! |
+1. I would go with a good reputable manufacturer, German made would be a plus+...! LOL! I would also talk to Michael at R1Concepts/ Acute Performance for some StopTech rotors that are already electro-static treated, and have the hats pre-painted. http://www.bimmerfest.com/forums/sho...d.php?t=462719
Rotor is NOT rotor.
a Cheap rotor is..... casted, heat treated, machined, oiled and put in plastic and then a box. cost maybe $40 to $60.00 A good rotor is..... a) casted homogeneously b) stress relief c) pre-machined d) heat treated to specs e) final machine f) other process i.e. electrostatic treated g) vent holes machined h) painted on hat and rib edges. typically $ 90.00 to $ 120.00 you have to drive a car with the good rotors to appreciate them. Same car same speed different rotors you will feel the difference. Cheap rotor tend to warp after the first re-cut might as well throw them away. Good rotor last for a while. You drive a great pricey car why would you put cheap rotor??? |
The reason I am looking for a less expensive option:
1. I am a college student on a budget and have to replace my clutch as well. 2. If I have to replace my rotors every time I do my pads, its hard for me to justify spending that much each time. I am just looking for an affordable option, that I can use as DD (very few spirited drives) and that wont empty out my wallet. Of course within reason; I don't expect to pay nothing and get the best. The way I see it right now it that if there has been satisfied reviews on these rotors, I can try them out and they may fit my needs. If not, I will move up next time I need to change my pads. Is it likely that cheap rotors brake? Will they become unsafe? Because, if the worst that can happen is aesthetics (shake), I can deal with till the next time I need to change the set. Heck, its a $50 investment that may save me lots in the long run. |
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
I bought them here.....http://www.******************.com/basket.php
But I agree, if you want to save money on a BMW, don't own a BMW... and certainly don't save money on your brakes or tyres!
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
Anything that is not blessed by Bmw logo or price is not welcome here. For crying out loud, its a used bmw, have a try at something else. I am very happy with my R1 concepts from acuteperformance. Sorry to be a pain to know it all heads and gurus of this 9+ YEAR OLD BMW forum.
You guys crack me up.
I am ordering Winhere brakes for my car today. By the way, Winhere Brake Parts is a division of Gates Automotive — a huge automotive supplier. The Winhere brake disc is an OE-Quality replacement for the premium segment of the European aftermarket. OE-Equivalent and Direct fit Application. High carbon content disc. Protective anti-corrosion coating. Resistance to thermal cracking and distortion Provides a higher friction coefficient. Resistant to vibrations and noise. Improved heat dissipation Warranty Information: 12 month - 12,000 mile limited warranty. Winhere Manufacturing - Winhere Auto-Part Manufacturing Co., Ltd. manufactures brake rotors, brake drums and water pumps for automotive aftermarket and original equipment customers. The 10-year-old company sells over ten million brake parts and water pumps annually. One more thing, our race shop sells "OP Parts" rotors. Made in China. We beat the hell out of them on our race vehicles and they are ever bit as good as Porsche OEM. Just make sure they are DOT/TUV certified, and you are good to go. - Mike
My new Porsche site Flat6News http://flat6news.com/ I am fortunate to have unique press cars delivered weekly, but I own: '13 Audi Q5 2.0T Quattro 8AT '86 Porsche 911 Turbo 4MT Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i. ~~~~~~~~~~~~~~~~~~~~~~~~~ Find my work on Autoblog or on my new Porsche site Flat6News! |
I don't want to start an argument, but why would you want to change your rotors every time you change your pads? Granted I know that some people hold to the philosophy of changing everything when they do brakes. But if as you say you do little spirited driving and your a poor college student (like me) your rotors should last at least 2-3 pad changes...
This time, however, my front rotors have a very tall lip... meaning they are quite thin. It is easier to buy new rotors at $60 each. - Mike
#25
How do you know if you don't measure the thickness?
Mine, for example, which I measure at each pad change, seem to only last through two sets of pads before they reach the wear limit stamped on the edges. Copious details and pictures are here: - One user's example of a complete brake job with all torque figures, specs, measurements, fluids, decisions, tools, tricks, mistakes, suppliers, costs, etc., that it entails (1) Quote:
