Old 05-25-2011, 07:44 PM
Lailoken Lailoken is offline
Mein Auto: "Adele" 2001 530i Black
Yet another blower fan (Fuse 75, 76) question
Hello. I'm new to the forums, although I have used them before to help me with minor issues.
This is a minor issue, but I am having a HELL of a time figuring it out. I've read through several posts about the location of Fuses 75 and 76 and the FSU in a 2001 530i, but I can't seem to find it. I've scoured the glove box, underneath the glove box, inside the fuse panel, all to no avail. I'm frustrated now, so I've stopped. I'm not an idiot so not being able to figure this out is utterly infuriating. Any help would be great...especially with pictures.
Old 05-25-2011, 10:11 PM
SeanPhang SeanPhang is offline
Mein Auto: 02' 530iA/steptronic@123k
I just checked mine a month ago. Do this, put your head where the passenger feet should be, I mean, really in there against the wall. Look up to the sky, pull that black panel with a big round hole towards passenger seat. You'll see.
06/10: rear shocks
08/11: cooling overhaul, O2 sensors
09/11: auto transmission drain & refill
09/12: alternator, VANOS seals, differential oil change
04/13: 2nd auto transmission drain & refill, changed fuel filter
Old 05-26-2011, 12:15 AM
There are plenty of pictures of the FSU location and the fuse locations in the FSU threads in the bestlinks ...
- What is the canonical thread on the BMW E39 FSU/FSR/Blower Motor Resistor (1) and what is the right brand FSR to purchase (1) (2) when your interior heating & air conditioning HVAC/IHKA blower motor goes haywire (1) (2) (3) (4) (5) (6) (7) (8) & how to repair your own final stage resistor including an autopsy & wiring diagram schematic (1) (2) and why a bad final stage unit will cause the battery to drain overnight (1) (2) (3) & how to isolate and replace the E39 blower motor (1) (2) (3) (4) (5) & how not to replace the FSU (1)
Old 05-26-2011, 04:03 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Pull the bottom plastic panel off that is under the glove box, pull it straight back toward the seat.
Then unhook the side supports for the glove box.
This is what your will see.
Old 05-26-2011, 03:37 PM
Awesome! Thanks so much. Finally got it open.
Thank you also! One more question though: Whats the easiest way to unhook the supports without breaking the tabs?
