E30 (1982 - 1993)
Old 05-21-2011, 10:22 AM
alabasterbiker alabasterbiker is offline
Mein Auto: 1986 BMW 325
86 325 Driver Door Issue
Another question:
The driver side door was making a popping sound when I would open and close it. The popping sound has stopped but now I can't open the door all the way. It seems to be getting hung up.
Any help is much appreciated!!!
Old 05-23-2011, 10:42 AM
laurelshelton laurelshelton is offline
Mein Auto: 1989 325I
Aloha, When I had this issue with my '89, after getting a suggestion to put on some grease stuff. When I was vacuuming my car the other day, I realized the bolts on the door were loose and I tightened them and fixed the problem. Hope this works for you
Old 05-29-2011, 07:58 AM
old carnut old carnut is offline
old car nut
Mein Auto: 1986 325ES STICK
The door check strap is probably broken within the door. The strap holds the door open in 2 different positions
Old 05-29-2011, 06:09 PM
e^2 e^2 is offline
Mein Auto: '84 325e, '00 323i
Door strap. Just unhook it.
Old 05-29-2011, 11:27 PM
old car nut
Remove it or replace it! Left just unhooked it can dent the door from the inside.
86 325 door
