Old 04-01-2011, 09:18 AM
poolman poolman is online now
Mein Auto: 525i station wagon
If your carfull you can remove the distribution piece without breaking anything. Doru, you just changed your CVV and hose not long ago. You shouldn't have any trouble to clean the distribution unit. The way I clean it, is to remove the part using a very long screw driver to pry up gently at each port front to back. I use throttlbody
cleaner and spray into each port slowly until the whole of the body is full. Walk away afterwards and let the part soak for about 10 min and then come back and use some compressed air to get the junk thats in the part out. Of course have some new 0 rings ready to replace the old parts on the DU.
On checking the DU for vac leaks, you would be surprised how many told me I would hydrolock my engine
by having a few drops of water introduced to the combustion chamber from my methods mentioned.
Old 04-01-2011, 09:34 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Thank you guys. I need to change the injector O-rings/clean the injectors as well, so I might clean the distribution piece as well. I noticed some heavy mayo on my dipstick (argh!) so there is some gunk in there for sure. I know I did the CCV about 2 years ago, but after seeing all that mayo last week on my dipstick, I just wonder......
P.S. : if judging by approach: leave some brake cleaner in the distribution piece for a while to dissolve the gunk inside would work also for the CCV? Or will the brake cleaner damage the diaphragm?
Old 05-01-2011, 09:28 AM
champaign777's Avatar
Originally Posted by champaign777 View Post
yaaa bad guy
here we are :
Metric
inside diameter x thickness = outside diameter (in millimeters)
dealer o-ring : 50MM x 3.5MM ( GREEN COLOR ) = 57MM outside ( updated for bluebee -> M52TU #11617504543 )
chemgigi o-ring : 51MM x 2.5MM ( RED COLOR ) = 56MM outside ( updated for bluebee -> M54 #DO NOT EXIST)
Final decision will be done directly on DIZA ( this weekend )
finally i replaced my DIZA o-ring
The green one ( dealer o-ring from < 2001 ) do not match , no way, its too big for M54 DIZA
The E-BAY chemgigi o-ring match perfect
and to remove the old o-ring was a PITA job
Old 05-10-2011, 06:53 AM
spamboxer spamboxer is offline
Mein Auto: 01' 530i
out of these #140 o-rings, which would be more suitable for DISA?
http://www.amazon.com/gp/product/B000FN0ZHA
http://www.amazon.com/gp/product/B000FMUQQQ
http://www.amazon.com/gp/product/B000FMUVSO
Old 05-15-2011, 07:43 AM
In this thread today:
- E39 (1997 - 2003) > Engine code po171
Paul kindly showed how he fixed his M54 rough idle with Permatex around the DISA valve o-ring.
- **Rough Idle**p0174 and p0171**Vacuum Leak**ALL FIXED
It's likely he was unaware of the DISA o-ring source at the time of his rough-idle P074 P071 DIY ... so I ask this question (of him) and of the tribe in general.
QUESTION: Knowing that the source exists for the M54 DISA o-ring, if you had a leak, would you 'still' use Permatex or would you simply replace the o-ring unlubricated?
Old 05-15-2011, 08:25 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
So, the RED O-ring IS the O-ring to get for 2001 face-lift E39's...
http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
Old 05-15-2011, 10:37 PM
I'm confused.
The original M54 DISA O-ring apparently has a rectangular cross section.
But, if I understand the fix here, you guys are replacing the rectangular o-ring with a circular cross section o-ring. Is that right?
And, what about the 'vertical sealing strips' (which are shown in the photo I previously posted from this thread)?
- Engine code po171
Are people fixing the vertical strips also?
Originally Posted by pshovest View Post
No one had proposed an oring solution when I had the problem and I'm not convinced the oring fix is the best. The M52TU uses an oring, but the M54 DISA seal is not an oring. It is a molded part that doesn't have a round cross section. If the replacement oring is too thick, the DISA won't be properly seated and sealed in the intake manifold. Notice the two vertical sealing strips on the DISA in the photo? The Form-a-gasket fix is less likely to interfere with these seals.
It's been 15k miles and all is well.
Old 05-30-2011, 01:35 AM
Mein Auto: 01' 530i
bought "#136 Silicone O-RING, Pack of 25" at amazon for $7.
buying lesser quantity had no economical benefit.
fit was "fine"
if I had to buy it again, I'd go with #137 or #138 for perfect snuggier fit.
Old 05-30-2011, 08:15 AM
i really don't care 7$ or 12$
yap, red one from ebay is the way to go , match perfect
silicon is a big NO NO, you don't want to see this staff in your cylinders, don't you ?
Old 05-30-2011, 08:54 AM
Makes sense. There is no filter between the DISA and the pistons.
Nobody answered the question about the cross section of the replacement o-rings.
I guess that it's just fine to replace a rectangular cross-section o-ring with a circular cross-section o-ring. Right?
Old 05-30-2011, 11:25 AM
Nittenyadhav's Avatar
Nittenyadhav Nittenyadhav is offline
Mein Auto: BMW F10 520d 2016
Is this guy who is selling Oring on ebay trust worthy? I've ordered the oring on 14th may and mailed him 2 times but no response or oring yet. I even didn't get any confirmation or mail from him for delivery too. What you guys think of him?
BMW 520D M Sports Plus F10
Old 05-30-2011, 12:00 PM
franka franka is offline
Mein Auto: E39 540i Sport
makes sense. There is no filter between the disa and the pistons.
+1
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 05-30-2011, 06:20 PM
this guy needs some "kick off" but finally you will get it
Old 05-30-2011, 11:39 PM
Mein Auto: 01' 530i
silicone
do you know material from which your replacement O-RING is made?
and whats wrong with silicone? how should it get into cylinders?
Silicone is acceptable for temperature applications between -65 degrees F (-54 degrees C) to 450 degrees F (232 degrees C). It has good resistance to ozone, weather, detergent, salt water, engine and transmission oil, non-petroleum brake fluid, hydraulic fluids that resist fire, vegetable and animal oils, and high molecular weight chlorinated aromatic hydrocarbons.
Silicone is vulnerable to mechanical wear and tear, water and steam over 250 degrees F (121 degrees C), aromatic hydrocarbons (benzene), chlorinated hydrocarbons (trichloroethylene), acids and bases, and hydrocarbon fuels.
Old 05-31-2011, 05:34 AM
But how do I contact him? I sent 2 mails from ebay but no response. Is there any phone number where I can call him?
Old 05-31-2011, 06:38 AM
Vacuum from the engine would pull the silicone into the cylinders. Now if your smart and use sensor safe silicone there wouldn't be any problem. The only problem with small bits of silicone getting into the cylinders would be that once burned the stuff would contaminate your 02 sensors. The stuff is so sofet that there wouldn't a problem to the combustion chamber, unless your pour huge amounts in. For the amount thats going to be used to seal off the DISA valve, only small and I mean very small particles would be pulled into the engine. I don't see where this would cause any problems what so ever.
Old 05-31-2011, 07:08 AM
Mein Auto: 01' 530i
can't believe you are talking serious about it.
I'm talking abut silicone o-ring, not silicone sealant!!!
Old 05-31-2011, 01:23 PM
tell him negative feedback is on the way , this will help
and for people who want to use silicon as poolman said should be no issue
damage, no damage , finally its your car and your decision and if it worth 10$ then go for it
Old 05-31-2011, 01:29 PM
Hi champain777
Thanks for your reply. I just mailed him again so hope he will get back to me soon. Thanks again.
Old 09-29-2011, 01:27 PM
Ooops. Because I'm debugging lean-mixture pcodes, today, at about 105K miles (2002 BMW 525i), I removed my DISA unit today for a quick look.
  1. SES: P1083,BMW 202, Fuel Control Limit Mixture Too Lean (Bank 1 Sensor 1)
  2. SES: P1085,BMW 203, Fuel Control Limit Mixture Too Lean (Bank 2 Sensor 1)
  3. SES: P0174,BMW 228, System Too Lean (Bank 2)
  4. PENDING: P0171,BMW 227, System Too Lean (Bank 1)
The DISA 'looked' OK. But now I had the problem of the o-ring seal.
Looking on my shelf, I found (and used) this stuff as the sealant.
Did I use the right or wrong stuff as a sealant?
Old 09-29-2011, 03:29 PM
chemgigi chemgigi is offline
Mein Auto: E39
go get the o-ring
if you use the sealant that is not sensor safe, you will end up like this.
The picture shown here is a silicone contaminated oxygen sensor. A contaminated O2 sensor will give you lean fuel-air mixture and the car feels very sluggish. You might not get a code but you will get a bad gas mileage.
Old 09-29-2011, 05:16 PM
It makes sense to buy the relatively cheap o-ring if you plan on removing the DISA, so as not to risk the expensive sensors.
The good news, for now, is this response from over here:
- E39 (1997 - 2003) > Car was throwing codes....DISA valve!
Originally Posted by uncmozo View Post
According to the Permatex Ultra Copper Technical Data Sheet, Ultra Copper IS sensor safe. You're fine.
Permatex Ultra Copper Maximum Temperature RTV Silicone Gasket Maker
File Type: pdf Permatex_Ultra_Copper_RTV_Silicone_Gasket_Technical_Data_Sheet.pdf (154.4 KB, 145 views)
File Type: pdf Permatex_Ultra_Copper_RTV_Silicone_Gasket_MSDS.pdf (98.7 KB, 118 views)
Old 09-30-2011, 07:58 PM
Bazza-Aus Bazza-Aus is offline
Mein Auto: 2002 530i
Originally Posted by pleiades View Post
Is the O-ring on M54 DISA units just an O-ring or more complicated? Has anyone measured that one?
Technically, there is no O-Ring on the M54 DISA units... and that's why there is not one shown on the realoem diagrams. The sealing is done via a built-in "lip" on the base of the unit that mimics an o-ring. Yes, you can gouge out the old sealing to uncover the grove that a normal o-ring can be fitted into, but you have to wonder why BMW made it the way they did, why it's rectangular, and the original seal is moulded and "glued" into place.
Also, and a big assumption here - the reason the DISA units may not have a traditional o-ring fitted, is, what might happen when it wears, or is mis-fitted, and gets sucked down the intake manifold and into the motor?
Putting an o-ring onto an old worn unit might be a bit of a risk perhaps.
ID:	295413   Click image for larger version
Last edited by Bazza-Aus; 09-30-2011 at 08:41 PM. Reason: Attached pics of old DISA Vs new DISA
Old 10-02-2011, 06:21 AM
Doru mentioned something similar in this thread:
- E39 (1997 - 2003) > Broken DISA Valve
Originally Posted by doru View Post
The seal is flush with the lips of the groove, having only a very small rib that will seat inside the receiving end - intake manifold, and that will produce the seal.
I'm not sure what this 'lip' actually is & why it disappears on the old DISA.
Q1: Does this additional lip flatten right away when a new DISA is installed; or does it take time to flatten out to nothing?
Doru said the same thing over here:
Once the DISA is out, and in case it's still good (fat chance), the glued O-ring seal is certainly toast.
Q2: What glue should we use when installing a new DISA?
ID:	295563   Click image for larger version
Old 10-07-2011, 05:57 PM
Shameless bump ...
QUESTION: What "glue" do you use when replacing your old DISA with a new DISA?
