E34 (1989 - 1995)
Old 06-05-2011, 08:04 PM
south26 south26 is offline
Mein Auto: 535i 1989
reasons to change your timing belt on a m20
Hi, I was taking a head off a m20 from a e34. I bought the car to part out. I was told that it had a blown head gasket. Well I have never seen a gasket go like this. I did not count but a number of rockers broke. 6 valves broke, one stuck in a piston. 4 out of the 6 pistons had holes in them.
Remember change your timing belt.
Andy
_________________
Old 06-05-2011, 08:52 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Yes i think thats good advise.That a lot of damage for one event. I can only imagine the sound that made. good pics too. I have two m50 h/g blown engines on Dolly's for the day i decide to rebuild one.
Name:	igors  93 525i m50 012.JPG
Old 06-06-2011, 04:31 PM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Wow, that's comprehensive. Bad head gasket, yyea. Perhaps mail a valve head to the seller
Take my advice, I'm not using it.
Old 06-06-2011, 05:55 PM
gomfrddy gomfrddy is offline
Mein Auto: 93 525i
it sounds like a miniature machine gun or sewing machine....ratatatatatatatatata
Old 06-06-2011, 08:49 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
...But it's got a Mobile 1 oil filter!
Good food, good people, good times.
Old 10-16-2011, 09:56 AM
Reason to change your timing belt.
Andy
Old 10-16-2011, 01:30 PM
Banned
Mein Auto: car
Hi Ross ole' buddy ole' pal !! How are you ??? Have a lovely day !!
Old 01-22-2013, 04:22 PM
Hi, I thought I would bring this back for those with a m20.
Andy
Old 01-22-2013, 05:22 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Ahhhh .... the joys of an interference engine with a timing belt (that is not properly maintained/changed out)
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-22-2013, 09:33 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
reminds me i have to do the one on my M40 in my 3er sometime in the next 6 months. ergh. its not a difficult task on either, ive done it several times, but just so time consuming!
E30 above Sold
Last updated 2nd January 2014
Old 01-23-2013, 07:32 PM
but not doing it is some much more time consuming.
Andy
Old 01-24-2013, 12:43 AM
not a true-er word was said
E30 above Sold
Old 10-09-2013, 07:22 PM
Just a friendly reminder to those of us with a m20.
Andy
Old 10-10-2013, 06:30 AM
MustangAndy MustangAndy is offline
Mein Auto: Ferd F-Teen Thousand
Andy
Does this apply to the M30s as well?
_
'90 535i 5speed (The Project) - '02 Mustang ProCharged 3.8L V6 5speed (The High School Car) - '04 F250 6.0L V8 TurboDiesel 4x4 - 13.86 1/4 mile - Bye Felica
Old 10-10-2013, 08:26 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Thats what costed me my first car and second car.. Cruising along then all the sudden SNAP!
Time for a new car.. Hadnt gottn into swapping yet.. Seemed to hard back then lol
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 10-10-2013, 05:10 PM
_
Nope the m30 has a chain. Only the 89-90 525i has the m20.
Andy
Old 01-04-2015, 08:23 PM
Bump to help with reasons to change your timing belt.
Andy
Old 07-10-2016, 08:07 PM
For those new people that have not seen what happens when you forget to change your timing belt.
Andy
Old 07-17-2016, 07:33 AM
aliff01 aliff01 is offline
Mein Auto: E34 M20 and 850SE
Actually do all m20 engines use timing belts rather than chains?
Old 07-17-2016, 01:29 PM
Yes all m20 use a belt.
Andy
Old 07-17-2016, 08:46 PM
How many kilometers would a new one last before it snaps and what are the signs of it needing a replacement?
Old 07-18-2016, 07:28 AM
No signs, just breaks. In miles it is every 60,000 miles or 4 years. If sitting for 6 years and only has 10,000 miles it should be changed.
Andy
Old 07-19-2016, 08:56 PM
BMW_507_4ME BMW_507_4ME is offline
Mein Auto: 530i
Belt/ chain
As all know BMW used a timing chain in most motors. Even the chain can be a disaster if you don't keep up with the tensioners. The M50's had a double roller timing chain with a mid engine gear on a bearing to take the stress of the chain. My 740IL didn't have that gear, instead, BMW just used plastic chain guides and as such, many failed as a result. BMW must have saved hundreds per car, but their customers (and reputation) lost thousands. I am sure they saved a few bucks using a belt on the M20's also. My advice is to change your tensioners and / or belt often, even more often then you might think you might need too, cheap insurance IMHO
Old 07-19-2016, 09:35 PM
I think you might be over stating the fact about the chain. It is not a common problem and yes can happen but not likely. As to saving hundreds? The m20 with the belt was built to be less of a gas hog compared to the m30, which it was. The belt was suppose to deal with the closer specs compared to the 60s tech that made the m30. I have driven a car with the m30 and have never worried about the chain. I have parted 26 BMWs and have never parted one because of a failed chain., 5 of those had a failed belt. So yes a chain guide can fail but not likely.
Andy
Old 07-19-2016, 10:09 PM
Mein Auto: 530i
Belts VS Chains
Well, you missed my point. It was that chains are much better "IF" properly maintained and don't suffer from a poor design. But I am sure after junking so many BMW's you already know what the major design timing chain flaw was in the M60 0ver the M50. I only have 40 years of fixing and racing cars and bikes under my belt, junking must be much harder and I am sure you learn more by tacking one apart, then by making them run, thanks for setting me strait, I will junk my car tomorrow
