Old 06-06-2011, 08:25 PM
hasamu84 hasamu84 is offline
Mein Auto: 528I and 740IL
EVAP Purge Valve Flow
My service egine light came on my 2000 528i and the code show P0441 EVAP Incorrect Purge Flow. I need to know where the Purge Valve is located on my 528i, under the hood it has a diagram but I don't quite know what it look like. Can someone show me an diagram what the Purge Valve Flow look like, and actually where it located on my car. I know it on the driver side under valve cover but I don't know what it suppose to look like.
I'm still learning. Can someone please help me out with this situation. Thanks
Old 06-06-2011, 08:53 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Under the intake manifold and close to the front.
See pic....
Old 06-07-2011, 11:07 AM
I learn something about my 528i
I thank you so much for the information you have given me. I was looking over it the whole time not really knowing what I was looking for. Your picture was very helpful. Thanks again.
Hasamu
Old 11-25-2011, 03:50 PM
97-e39-540i's Avatar
97-e39-540i 97-e39-540i is offline
DKUHCreations
Mein Auto: 2000 528i autoSP///Silver
i have the same code that pulled up on my 2000 528i i just bought .
so did changeing just the "purge flow valve" in the photo/ work or did you also need to change the EGR ?
thkx to "SEARCH" button !!
2000 528i Sport Package
17''BMW///BBS
Xenon Lights
Black Leather
Silver Paint
Old 11-25-2011, 11:48 PM
I'm trying to find this purge valve in my E39 diagrams.
Is 'this' it?
What does it to (i.e., how does it work)?
- Fuel Preparation System => Fuel injection system => FUEL TANK BREATHER VALVE
- 01 FUEL TANK BREATHER VALVE Qty=1 PN=13901433603 $82.88
Old 11-26-2011, 07:55 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
That's it. The DME controls it. One hose goes to the charcoal cannister that is connected to the fuel tank.
The other hose connects to the intake manifold
The charcoal absorbs fuel vapors, in the old days the tank was vented to atmosphere.
The purge valve allows the vapors to be sucked out of the charcoal and into the engine.
Old 11-26-2011, 08:52 AM
Hbro Hbro is offline
Mein Auto: 528iT
I had this code. My Indy Mechanic traced to a leaky hose behind the rear driver side wheel.
He also showed me an M3 with the same broken hose.
He installed a used hose.
Old 11-26-2011, 10:11 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Bluebee, I still think this might be the source of your elusive vacuum leak and excessive lean condition, since your missing gas filler cap allows the tank to vent to the atmosphere. The manifold may be effectively vented all the way back to your filler neck.
Old 11-26-2011, 10:47 AM
That's it.
Thanks for explaining HOW it worked! I'm not sure exactly 'where' the hose connects 'near' the idle control valve ... nor what the charcoal canister looks like - but, to add value where I can, I did my best to leverage both 16Valex' & your information by adding it to this thread as the following annotation (see post #78 for the details):
- What is this engine part? (Getting to know my M54 engine bay)
Interesting. Thank you for thinking of me. I 'still' haven't figured out where my vacuum leak is ... so I appreciate your concern.
I 'did' replace the gas cap, a while ago. I never did find mine (after running the experiment for the team) ... so I bought a new one.
- Experimental results removing the fuel filler cap (aka gas cap) on the BMW E39 with resulting OBDII DTC fault and drive cycle reset (1) (2)
I still haven't looked at the BACK of the engine (where I know there are some SAP hoses to check) ... so that's my next battling-vacuum-leaks destination!
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1)
It would be nice to have a PHOTO of the E39 charcoal canister tucked up under the driver side rear wheel well. The best I can find is this picture but I don' think it's even from an E39.
Does anyone have a good photo of the E39 charcoal canister in situ?
Old 04-22-2013, 12:01 AM
I hadn't noticed that I hadn't closed this one.
I resolved that lean-condition misfire problem, and reported the entire task, with a dozen pictures, over here:
- How to diagnose a BMW E39 engine misfire (1)
See also this recent purge valve thread:
- Purge control valve vac hose help!
Old 05-03-2015, 10:12 PM
See also:
- Debugging the gasoline evap purge valve sensor and purge control valve evaporative emissions fuel system vapor recovery P0440 P0441 P0442 P0444 P0445 P0446 P0451 P1403 and other fuel tank breather valve and gas cap leak obd codes (1) & a fuel injection LDP leak detection pump DIY (1) & a fuel system charcoal canister R&R DIY (1) & where is the fuel tank breather valve located (1) & tricks for resolving the P0455 diagnostic trouble code when the missing gas cap is replaced (1) & does spilled gasoline really go into the charcoal canister via the two steel vent holes in the fuel filler canister at the 3 o'clock and 9 o'clock position and why is there a hole in the 6 o'clock position of my fuel filler hole rubber gasket (1)
