Old 06-06-2011, 05:34 PM
jwdilljr jwdilljr is offline
Mein Auto: 2003 325i
HelpAC not working and it was 106 here in TX today
I sure hope someone can help me out.
My AC is not blowing cold, the pulley down by the belt is working fine, it turns on when I turn the air on and everything but it just won't get cold. I charged with freon and it didn't want to take any,....
Old 06-06-2011, 05:43 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Well, you may have a more significant problem than just being low on freon.
Maybe time to go to a shop and see what is going on?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 06-06-2011, 06:54 PM
tyler3567 tyler3567 is offline
Mein Auto: 2003 BMW 325xi
Has it been serviced lately, have you put refrigerant in recently? Systems will also under perform if you have overcharged them.
Old 06-06-2011, 09:19 PM
Tech Savvy Tech Savvy is offline
Mein Auto: 2004 BMW 330CI
If you search for a Robinair A/C repair shop They would be able to find your problem within 1 hour at most. Probably change you between $40 to $89. good luck,
Old 06-07-2011, 10:04 AM
elhombre's Avatar
elhombre elhombre is offline
Mein Auto: 2003 325i, '99 e36 328is
Try your "hot water control valve". They generally fail in the open position, sending hot water to the heater core. A/C is not able to overcome the heat generated resulting in a condition simillar to what you discribe in the O.P.. It's located under the hood on the drivers side wheel well, under the air filter box/ maf sensor area. Theres a two wire connector on top and two hoses attached in back. Clamp either of the hoses, run the climate control and see if the situation improves. If so, replace the valve.
Old 06-07-2011, 10:06 AM
mexakin05 mexakin05 is offline
Mein Auto: 325Ci
did you check ur fuses??
Old 06-07-2011, 11:00 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
First thing you do on any A/C system is check the pressure on the low side and high side. Without those readings, you will be shooting in the dark. I can tell you from experience when the same thing happened to me I had really high low side pressures and it was because the suction side of my compressor died. I had to replace the compressor and she was back in business. It could also be the expansion valve, but again, without at least a low side pressure reading, it will be hard to nail down the problem.
Old 06-07-2011, 11:48 AM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
Question: you can see low side of the pressure when A/C compressor is engaged, right? High side of the pressure when it is off, right? My readings are something like this (80F ambient temp): low side 45-50 psi, high side 60-65 psi. Does it look ok?
Old 06-07-2011, 01:36 PM
smolck's Avatar
ROLL TIDE!
Doubt you are reading high side at 65psi. Typical high side range is 250-310 (give or take), but no you read them with the system running. Low side should be in the low to mid 30's with an 80 degree ambient.
Old 06-07-2011, 01:39 PM
All my numbers are from small gauge mounted on the r134a recharging bottle.... I probably need to buy a good set of A/C gauges (I think there should be two gauges connected to two different ports, right?)
Old 06-07-2011, 01:49 PM
Yeah, I see. I, probably, eventually will get this set: http://www.harborfreight.com/a-c-man...set-92649.html
Old 06-07-2011, 02:06 PM
smolck's Avatar
ROLL TIDE!
Well if that is the case you CAN'T get a high side reading because the high side port is larger and the gauge won't fit.
ac, air conditioner, air conditioning control, air conditioning problem
