ac pressure specs e30 - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 06-04-2011, 09:43 AM
a228380 a228380 is offline
Mein Auto: 1991 325i
does anyone have the low and high pressure specs for a 1991 325i e30 4 door factory ac system.
I had the system evacuated put in a new compressor and switched to r134a. On a very hot day the ac is luke warm. in the mornings before it gets hot the ac will be cool.
I have manifold gauges and i want to do some diagnosis but need to know what the low and high pressure should be.
thanks
Old 06-04-2011, 05:59 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
not sure of the pressure at the moment, but the evap temp (on your suction gauge) needs to be around 40' (somewhere around 40-45 psig i believe). you should have sweat on your suction line up to the compressor, but NOT on the compressor itself. if i get a chance, i will get my gauges and get you an acurate #...
Old 06-04-2011, 09:27 PM
downhiller's Avatar
livin large
the best way, since these are the r12 originally, then 134a numbers will be off. the best way to do a good check, wait till its low 90s out and add some 134a until it blows cold. what youll want is a thermometer to put in the vents and youll want somewhere around 40* comin out.
Old 06-06-2011, 05:39 PM
eieio4tn's Avatar
BMW...riceless
with 134a gauges, 40' evap temp is 40'. there is no "off" to it. pressure/temp charts are a constant. 40' on r12 is 40', the pressure is different, thats the only difference.
Old 06-06-2011, 08:17 PM
downhiller's Avatar
livin large
i was mainly talkin the air comin out of the vents.
Old 06-07-2011, 05:57 PM
eieio4tn's Avatar
BMW...riceless
anyway...we both agree on the temp. to achieve a 45' supply air, the suction pressure would have to be @ 30 psig, which is 34'. head pressure should be in the 150-180 range.
