Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc... |
#76
Hello,
I think i might need some clarification on how this works. I have a E66 with an L7 amp that is broken (wont drive the subs) Will this device help me go around my broken amp, or do i need a properly functioning amp for this to work. At first i thought that this will bypass the amp, but im beginning to get the feeling (from reading other posts about L7), that this will only convert the high output signals from a working amp to low output signals to be routed to an aftermarket amp. thanks Willis |
#77
Hi Willis
A functioning OEM amp is required for this harness to work. The issue with the Logic7/Premium OEM amp is that it is a digital-proprietary (MOST) inputs amp so a proprietary device is required to handle those inputs. There is no aftermarket amp that can be used to directly replace your OEM amp. There is a MOST preamp device available for certain BMW but it is not available for the 7-Series in particular: http://www.mobridge.us/sites/default..._Manual_V3.pdf Quote:
#78
Thanks for the reply technic. I thought i could get away with a fast one this time, but it looks like my 7 has beat me yet again.
#79
Amplifier harness for E70 X5 with Hifi stereo
I am planning on using the JBL MS-8 connected to a JL Audio HD900/5 amplifier. The MS-8 requires either a full range low level input or several speaker level inputs that can be summed to provide the full range signal. I would prefer the speaker level input, to remove the LOC from the picture and reduce the possibility of noise in the system. Can you provide a harness that would have the speaker outputs clearly indicated that can just be plugged directly into the amplifier? If so, I would like to order one. Thanks in advance Chris Newfoundland, Canada |
#80
Hi Chris
I can create a MS-8 to OEM harness (no LOC) for full integration depending of the X5 OEM system. I have no Top HiFi harnesses available for the next 3-4 weeks, though. Quote:
#81
Im looking to add a kicker solo baric with 1000 watt amp to my 2007 e90. I'm pretty sure I have the logic 7 system. Will this harness work for me? And all I will need to add is the power and ground correct?
#82
Any update on when the harness will be available....
Regards, Impatient in VA |
#84
The harness should be available the week of the 20th of May...
#85
Harness will be available for sale by next Tuesday... thanks for your patience and support.
#86
Harness is available...
#87
#88
#89
PM replied...
#91
Hi mate could you tell me will this fit a e60 2005 with the standard system?
If so could you pm me a price with delivery to the uk! Cheers Matt |
#92
If your standard system is the Stereo system (6-speakers, no OEM amp) then this harness will not work.
#93
Bump...
#94
Bump...
#95
cool product man, looks simple and effective. i have a 97 528i without dsp...i have no idea what this logic7 system is????? but would your setup work fine for my e39? im very interested in your product. let me know.... thanks.
BMWCCA member #446696 aloha state |
#96
Unfortunately, no.
#97
I'm interested in one of these for my UK L7 equipped 750i. Can you ship to the UK?
#98
I need one of these I have a 2002 745Li I will check to see if I have the logic 7 my goal is to run aftermarket subs/amp and run a separate amp on the front and rear high/mid speakers..is this possible?
#99
If you want to add more amplifiers to drive the rest of your speakers then the harness itself will have to be cut and modified accordingly. I do not support/warrantee such use but it can be done, however you will need more than just adding another amp (search for JBL MS-8). |
