Old 06-13-2011, 11:45 AM
dckang dckang is offline
Mein Auto: 2011 X3
Few Questions
Just received my X3 this past weekend and only driven like 60 miles so far. still have not taken any pictures yet.
Still trying to get used to it....very different from my old Honda!
So have a few questions, maybe pretty dumb...or should ask my dealer.
1) Emergency Brake - should i be activating this when i park? before i set to Park? or after? im used to the hand brake in my Honda...so not sure if i should be using it. i notice when i park without the brake, it still moves alittle....
2) MPG, so far only 60miles, but i checked the screen, it said 13.5mpg....is that normal at the beginning phase....or am i just pressing on the gas pedal wrong (still not very use to this either, especially at under 40)
3) if there is a scratch on a side window....does the entire window need to be replaced?
4) how can i upload music from my ipod into the music collection? can i only upload through a flash drive?
5) is there a way to lower the volume of the navigation voice
Old 06-13-2011, 02:50 PM
Skygal Skygal is offline
Mein Auto: X3
2) My mpg improved over time.
3)They will probably want their rep to look at the window. My windshield is being replaced.
4) I believe only from flashdrive or cd.
5)When navigation is actually speaking press the volume - button to lower voice.
Old 06-13-2011, 03:22 PM
No12 No12 is offline
Mein Auto: 2016 340i xDrive MPerf EB
As to item 1 - not sure it matters, but I always put into P, then pull up the brake switch. The electronic switch for parking brake acts no differently than the old pull up handles. If you used parking brake before, use it now.
As to item 2 - you are way too early to be worried about mileage, engines usually take several thou miles/kms before accurate fuel ecomony figures show. Just enjoy your new car, and forget about mileage for a while.
2016 340i xDrive EB MPerf
Plus 18 other BMWs since 1971..
Old 06-13-2011, 03:44 PM
Mein Auto: 2011 X3
I tried that but didnt seem to work. Only lowered my music volume... I will try again and see. I just wish theres an actual volume scale or gauge....for the music at least.
Old 06-13-2011, 05:03 PM
Mein Auto: 2011 X3 35i
Go into the I-drive menu under settings then I believe it is the sound or tone option. You can then choose how loud the Nav voice is, the PDC beeps and "bonging" seat belt sounds are to name a few. You can also download your music right from your Ipod to the hard drive via the usb port in the glove box. You can go through the I-drive menu to do this as well.
Old 06-13-2011, 05:15 PM
double post.....deleted
Old 06-13-2011, 05:33 PM
Mein Auto: 2011 X3
i hooked up my ipod to the usb port in the glove box. it charges my ipod, but it wouldnt search or play anything from there.
as for the navi voice, in the setting i saw, the 1st option reads "speed volume". is that the same? or maybe i just have my main volume up really loud (music not loud enough!).... i already turned down my goong and pdc sounds....
Old 06-13-2011, 05:44 PM
I believe it is "Tone" you are looking for under settings. As for the Ipod, when you plug it into the glove box port, you have to go to the import/export music option through the I-drive menu before you can play the music. It explains it in your owners manual well.
Old 06-15-2011, 02:23 PM
whispered whispered is offline
Mein Auto: 2005 Acura RL
It's pretty tricky, especially if the voice doesn't talk long. You have to adjust the volume knob while the voice is talking. Anything before or after that will result in just the main music volume change. Good luck!
Old 06-15-2011, 09:23 PM
AzNMpower32's Avatar
Tar Heel Faithful
The parking brake can be used anytime when stationary. Treat it like a normal handbrake in an AT; if you're like me and pull the handbrake every time, set it before or after P, doesn't matter much.
In fact, the Auto H function will hold the brakes when you're stationary and automatically release when you step on the throttle (or get of the car). Makes stop-and-go traffic easy.
The engines need about 10000km to reach best fuel consumption figures. Don't fuss over this.
To adjust the sat nav volume, turn the volume knob when the voice is speaking.
