iPhone 4 & smartphone integration cradle - Page 3 - Bimmerfest - BMW Forums
Old 02-17-2011, 07:27 PM
LovinM6's Avatar
LovinM6 LovinM6 is offline
Mein Auto: 2015 750Li
I've reviewed the bulliten and I do believe this new part that is available now for the iPhone 4 will not play media.
See below which I have lifted from the bulliten.
Parts Information:
Description
Snap***8208;in Adapter
Type Part Number
Apple
AppleŽ iTouch Music 84 21 2 162 534
AppleŽ iPhone Phone 84 10 9 182 792
AppleŽ iPhone Music 84 10 9 164 213
AppleŽ iPhone 3G/3GS Phone 84 21 2 158 682
AppleŽ iPhone 3G/3GS Music 84 21 2 158 683
AppleŽ iPhone 3G/3GS Media 84 21 9 229 004
AppleŽ iPhone 4 *NEW* Phone 84 21 2 199 389
AppleŽ iPhone 4 Music COMING SOON
AppleŽ iPhone 4 Media COMING SOON
2015 MB Custom designo S550V . . . . . . . . . . . . . . . . . . . | 2015 BMW M Sport 750Li Individual
designo Mocha Black . . . . . . | designo Auburn Brown . . . . . | Individual Azurite Black . . . . . . . . . . | Individual Opal White
Old 03-11-2011, 05:13 PM
Jovan1210 Jovan1210 is offline
Mein Auto: BMW 535i
Ok-- So far, I have ordered smartphone integration for $150 and an iPhone 4 cradle which I picked up today, PN 84.21-2 199 389-01 for $160... That is BY FAR the MOST expensive phone charger EVER!!! BMW SUCKS ON THIS!!! Almost a year later after the iPhone 4 is out...
Why even put the cradle for sale if it does not work?? Are they morons???
Old 03-21-2011, 08:54 PM
thrang thrang is offline
Mein Auto: 650 Vert X-Drive
I've been using the cradle for a few weeks now, and correct, no media access, which I don't care about because I dedicate a 160gb iPod in the car via the USB port.
But the signal strength is definitely improved. When I connect it in less than ideal signal areas, the signal strength increases. Disconnect it, and it decreases. So somehow, the sharfin is in use.
So from this perspective, I'm pleased.
Old 03-21-2011, 10:53 PM
spadae2 spadae2 is offline
Mein Auto: 2015 750ix
Apple removed the extension from the 30 pin connector, so the increased reception is not true. Please see other posts and Apple discussions for complete documentation.
__
2015 750i X-DRIVE, M-Sport, (born 3/6/2015), Moonstone Metallic, Ivory White/Black w/Honey Walnut, ARS, B&O Sound, Escort 9500ci. VO and FDL Coded. BMS Stage 1.
Old 03-22-2011, 06:10 AM
However, the signal increases when I snap it in (when the signal is fair to poor to begin with). And I don't drop calls anymore.
So something positive is occurring.
Old 03-24-2011, 12:43 PM
MacDriver MacDriver is offline
Mein Auto: 750i from 4/1 before S500
You are both right. The pins do not exist anymore. But the cradle uses inductive antenna coupling.
Old 05-24-2011, 09:29 AM
likegadgets likegadgets is offline
Mein Auto: 2017 750i
Anyone has been able to get the cradle for iPhone 4 with Music? They will probably release this after Apple releases iPhone 5....
Old 05-24-2011, 09:32 AM
Hans_ACS Hans_ACS is offline
Mein Auto: F01 740d
No, it was foreseen for middle of may, but again technical issues with the supplier prohibit the release of the cradle..
to be honest, I think this is insane, what is so difficult in creating the cradle ? Since the Y cable (or the standard delivered iphone white apple cable) works perfectly ! Even album covers are shown on screen. So it must be the use of the external antenne which causes problems ?
frustrating ....
Old 05-24-2011, 11:45 AM
hammadurb hammadurb is offline
Mein Auto: 2009 BMW 750li
I gave up on the cradles. I bought the one for the 3g and while the reception was better, it was a pain having to take off the case everytime. I have been using the Y-Cable since I got my iphone 4 and it works just fine. Even if the cradle does come out soon, I think I will pass. It's not worth buying it and then Apple releasing a new phone, like they have been doing every year.
2016 BMW 750i
Carbon Black Metallic - Cognac Nappa Leather - Driver's Assitance Plus I & II- Executive Package - Cold Weather Package - M Sport Package
13 M5 / 12 650i / 09 750li / 06 750li / 03 745li / 00 540i
Old 06-14-2011, 04:17 PM
eLECTRO eDITION's Avatar
eLECTRO eDITION eLECTRO eDITION is offline
Mein Auto: BMC TMR01 di2
A search on ebay for any current 2009-2011 phone ( choose your style) may include products such as screen protectors, power cables and plastic cradle with suction cup.
You can purchase the specific plastic cradle for your phone, remove the plastic holder from suction cup assembly (usually clips into each other) then simply Crazy Glue the adaptor into the BMW removable base.
Since the center console phone install by BMW automatically detects and through induction amplifies the signal and blu tooth is automatic detect, an update to any phone and phone cradle is easy.
ebay link for cradle holder http://cgi.ebay.com/Car-Mount-Air-Ve...item4aab57bc44
When item arrives your only interested in the plastic cradle not the entire assembly with suction cup. As shown the cradle is a slim mount with thumb release. Phone orientation forward facing up with USB, 180 degrees to photo in ebay listing.
The item shown is slim mount with thumb release. Thumb release side of cradle should be mounted/oriented to side of BMW USB port not side wall of center console.
The item shown probably is attached with four tabs probably slide together easy to seperate from extension arm. Item should easily attach to flat surface of iPHONE mounting plate with a few drops of adhslive crazy glue or 3M tape, crayze glue is preferable.
There maybe different iPHONE bases for your type of iPHONE.
Any good car stereo installer should be able to mate the cardle holder to your BMW iPHONE plate if you choose otherwise not to install yourself.
Old 06-17-2011, 10:38 AM
RepeatBMWGuy RepeatBMWGuy is offline
Mein Auto: 2011 740iL
For those of you that did invest in the iPhone 4 cradle now that its available, are any of you experiencing extreme heating of the phone? If I leave mine in for more than 45min it gets hot enough (the phone) to fry an egg. I let BMW know and they claim to not have heard of this issue at all. Im getting over the fact that I have a 400.00 phone charging system, but heat in electronics is never a good thing unless its by design (like a heater ).
Any insight would be most appreciated.
Old 06-17-2011, 11:45 AM
Apparently there is a lot of buzz on the "iPHONE 4, iPHONE 3 get very hot" issue.
Google search for your benefit with many posts: http://www.google.com/search?q=iPHON...rlz=1I7PRFA_en
A safe option althought time consuming is to log a service call and document the issue with your BMW service dept. If your charging iPhone 4 causes damage to your 7, liability will be with your BMW dealer that logged your complaint and Apple.
I'll say, all is normal for the heat due to battery type and voltage/current requirements to charge the device. No manufacturer wants a product liability issue and thier attorneys will make sure of a win to protect company assets.
Many electronics operate in very warm to hot conditions all perfectly normal: automotive radar detectors on dash in the sun post parking, modern vacuum tube audio, class A amplification, plasma displays, pro audio gear,etc.
Good luck, keep posting updates with your results.
Old 06-17-2011, 01:16 PM
Thanks for the comments. That said, the iPhone actually shuts down due to heat - this to me says there are some parts within the device that are heat sensitive and actually have a failsafe measure within to protect it from damage. And, since this heating only happens in the cradle and no other charging system that I use (OEM or aftermarket), my assumption there is either a flaw in the design or a flaw in my unit itself. In fact, so far its BMW's assumption too - its in for service under these conditions and they are troubleshooting now.
Looking for anyone who has gone through this or found a resolution.
Old 06-17-2011, 09:50 PM
mcorf mcorf is offline
Send a message via Yahoo to mcorf
Mein Auto: 2011 Mineral White 740 Li
I was going to buy the iPhone 4 media cradle once it came out, but just read that once iOS 5 comes out everything will transfer via Bluetooth.
Old 06-23-2011, 10:04 PM
G from Dallas G from Dallas is offline
Enjoying my 2009 750Li
Mein Auto: 2009 750Li
Thumbs down Disappointed with BMW iPhone 4 integration
The media cradle does not provide true iPhone integration. It's simply an overpriced charging device that causes the phone to get hot. I contacted BMW NA and complained. I suggest we all do the same. There is no good reason why BMW cannot create a cradle that integrates the digital music and the telephone features through the idrive without multiple cables!! You can voice your frustration to BMW NA at 1-800-831-1117
Old 07-05-2011, 01:40 AM
Mein Auto: F01 740d
I just got my iphone MUSIC cradle yesterday. All works ok, I can control the iphone from the i-drive, browse through folders and so on. But what surprises me, is that album cover art is NOT shown on screen. However, when I plug in the iphone via the y-cable into the USB port, the albums cover do show up...
Frustrating ! Why can't it work via the cradle ?
At a price of 144 euros, a pretty expensive piece of plastic .... that can do less than (also expensive) y-cable ...
Old 07-07-2011, 01:54 AM
Mein Auto: F01 740d
ok, the dealer gave me the wrong cradle
I just got the 'MEDIA' iphone 4 cradle and this does everything the Y cable does : full i drive control + album cover art display on the screen.
FYI, the part number is : 84 21 2 199 392
Old 07-08-2011, 07:28 AM
fmiddleton fmiddleton is offline
Vroom
Mein Auto: 2011 750Li
Folks: the MEDIA iPhone adapter behaves differently depending on the options on your 7. I tried on mine before buying (and as a result, didn't buy it): it only charges the phone and increases reception. On others (with Combox etc) it will play media and provide album art. Frustrating as heck, but that's the deal.
2012 X5 3.5i Sport Sapphire Black
2011 750Li, Alpine White (sold)
2011 335ci Silver Gray, 6-spd (sold)
2007 335ci Titanium Silver, Auto (sold)
2004 745i Sapphire Black (sold)
2004 330cic Silver, SMG (sold)
2001 330xi Black, Steptronic (sold)
Old 07-09-2011, 01:20 PM
CobraCabbage CobraCabbage is offline
Mein Auto: 2013 MCB M5
Repeat... I've noticed that the phone doesn't get hot as long as you make sure the screen is off. You'll notice that once you plug it in it lights up. If you push the button at the top of the phone and make sure the screen is blank before you close your center console the phone shouldn't heat up. At least that's my observation...
2013 BMW M5
2011 BMW 750i M Sport w/ HRE 948R - Retired
2011 Infiniti QX56
'73 VW Dune Buggy
Old 07-10-2011, 01:59 PM
You need the combox AND 6nR option for it to play as a device from the cradle. I have the combox (10/10 build) and it works as a $450 charging dock only.
Old 07-30-2011, 12:56 PM
mrkplatt mrkplatt is offline
Mein Auto: 2010 750 Li XDrive
Well, the Media adapter works perfectly in my wifes 2012 X5. Wish it did more than just charge my phone on my 2010 750... Also would have been nice to have the dealer tell me that before he sold me the adapter! Ugh.
Old 10-23-2011, 07:17 AM
x54.4blue x54.4blue is offline
Mein Auto: 2008 E61
So does the I Phone 4s provide music via Blue tooth? No reason to get a dock?
Old 10-23-2011, 08:45 AM
asaseaban's Avatar
asaseaban asaseaban is offline
Y ask y? Ask y not!
Mein Auto: None
Correct!
_______________
2000 740iL Space Gray - Sold
2003 745Li Titanium Silver - Sold
2009 750Li Mineral White - Sold
2009 750Li Titanium Silver - Sold
2011 xDrive35d Vermilion Red - Sold
2012 xDrive35d Vermilion Red - Sold
2015 xDrive35i Glacier Silver
Old 10-23-2011, 09:09 AM
Is it the phone or the car? My iPhone 4 never could stream music to the early 2011 740i, but a 3 series loaner did allow me to stream
I have the 4s now but haven't looked at this feature
Old 10-25-2011, 02:34 PM
I have a 2010 750i and got the Music Cradle for the iPhone 4.
It charges the iPhone 4S - but reads no music from it.
