Old 06-20-2011, 10:34 AM
relder relder is offline
Mein Auto: 2007 750Li
Want to add power to inside of trunk
I'd like to add a power outlet (cigarette lighter outlet) into my trunk, running a lead off my fuse box, so it doesn't interfere with the other electronics in the car. Could someone kinda walk me through how to do that, as I don't generally do customizations/modifications to cars.
I have a 2007 750Li w/ Comfort Access.
Thanks in Advance!
Old 06-20-2011, 11:04 AM
BMW Arabia BMW Arabia is offline
Mein Auto: 750Li 2006
well, I dont really recommend messing with electrical stuff especially on a BMW !!!
Old 06-20-2011, 11:48 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is offline
Major
Mein Auto: 745 li
^^^ and specially with computer on wheels like 7
Old 06-20-2011, 11:53 AM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Thanks in Advance!
You would need a socket first like this:
http://www.iboats.com/SeaDog-SS-Powe...-view_id.39773
and then some an Add-a-fuse that looks like this:
http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
You can find the add a fuse at autozone, pepboys, etc. Just make sure you get the right size!
As far as what fuse to tap into, I'm not really that sure but there are a number of possible fuses. For example there is the coolbox/refrigerator fuse that's probably unused in your car. You will need to put a the add a fuse in there, HOWEVER only plug in the fuse for the wire sticking out, do not plug in both!
Then simply run a power wire to the power side of the outlet, and run the negative/black side to a grounding point.
fuse box, power
