What's the correct VW MAF p/n for a 2003 540i? - Bimmerfest - BMW Forums
Old 06-20-2011, 03:15 PM
Calicoastin Calicoastin is offline
Mein Auto: 2003 E39 540i auto
I remember reading a while back about the VW maf sensor working on the 99-up 540i. Does anyone know what the correct p/n is?
Thanks in advance for your help.
Old 06-20-2011, 03:18 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
Range Rover works too: B3130139283
Happy reading:
http://forums.bimmerforums.com/forum...d.php?t=911151
Old 06-20-2011, 08:57 PM
I simply did a /maf in the bestlinks to find this:
- Mass air flow sensor (MAF) & idle control valve (ICV) require periodic cleaning (1) (2) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF) & cleaning the throttle body (1)
Old 06-20-2011, 09:18 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
I have read a considerable amount of information about use of the VW MAF. It is my opinion, based on that research (mostly from reading threads on the M5 boards) that it is best to use the factory oem Bosch MAF only. Several users of the VW MAF found differences in the read out of liter/minute flow of the VW MAF versus oem. Obviously the VW MAF works, but it is not optimal. If you are comparing a worn or malfunctioning oem MAF to a new VW MAF, the VW appears to work fine....but it will run better with the proper oem MAF.
If you want the absolute best price on the later style oem Bosch MAF, find the seller "germanautosupply" on Ebay. He sells the factory oem Bosch part with free shipping for $165.
I don't see him listing them right now, and oh, I see our sponsor has them for $170 with shipping on ebay! Find "eactuning".
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 06-21-2011, 08:45 AM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
Yup you can buy one from our Ebay store as mentioned above. If you are not an ebay user you may also order it directly from our site.
http://www.eaceuroparts.com/catalog/product/418
This is a brand new Bosch part specified for any 540i built after 9/1998. Do it once, do it right and save the guesswork on whether or not your MAF is performing optimally.
