Old 07-03-2011, 02:09 PM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed/2003 M5
Dented hood from fan shattering, replace or repair it what's cheapest?
Anybody have any idea if it would be cheaper to repair dents on an existing hood and repaint it as opposed to buying a new hood and having that painted?
Old 07-03-2011, 02:20 PM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
I would start calling junkyards. Probably the best way to go IMHO.
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 07-04-2011, 12:05 PM
You might PM the guys who also went through hoods & quarterpanels from the same problem:
- Pictorial guide to cooling system failures & the results thereafter (1)
Old 07-04-2011, 12:33 PM
Alright I'll look a bit more for answers, those pics show pretty much exactly what happened to my hood.
Old 07-04-2011, 12:48 PM
It has never happened to me but from the threads I've read (most of which are crosslinked in that one pictorial cooling systems failure thread I already referenced), it seems the cause of the problem is generally:
  1. The motor (or transmission) mounts are sagging
  2. Or the viscous van clutch seized in the locked position
There are some who say it's more often the former than the latter, which means it's very important for you to figure this out or it will happen again to your newly repaired hood.
What was the cause of your fan blades disintegrating?
Old 07-05-2011, 11:06 AM
Well, I wasn't personally driving the car but from what I hear from my brother who was driving it at the time he was passing a car with the rev just a bit too high and it disintegrated. Keep in mind that my car was high in the miles when this happened. I think it's bound to happen to any engine with high mileage. Perhaps a carbon fiber hood would be good protection against damage to the hood.
Old 07-05-2011, 11:16 AM
Ben Carufel Ben Carufel is offline
Send a message via AIM to Ben Carufel
Mein Auto: BMW Motorcycles
Carbon fiber would likely crack/shatter when hit with impact that's hard enough to punch through the factory hood.
The best protection against damaging the hood is replacing the fan and fan clutch before it happens.
Ben
1989 BMW 325i S50 - 2002 BMW R1150GS ADV - 1972 BMW R60/5
Old 07-05-2011, 01:10 PM
Interesting, I'll have the shop take a look at it and see what state it's in. The plastic guard around the fan definitely didn't stop the fan from tearing up the hood. Here's an attached photo of the damage.
Name:	Ceedub pics 212.jpg
Old 07-05-2011, 01:51 PM
zman2001 525i zman2001 525i is offline
Mein Auto: 2001 525i
If you want to go cheap either junkyard or certi-fit. You can get a BMW hood from Tischer for about $650 shipped. Probably another $400-$500 to paint / install at a body shop.
Old 07-05-2011, 04:40 PM
I don't disagree.
But.
When I researched this (at the time of my cooling system leak), I was told by one of our suppliers that the fan almost never breaks 'on its own' - it's always as a 'result' of the clutch or the mounts.
So, the theory goes - you don't need to replace the fan (unless of course it shows evidence of wear). Likewise, if you 'just' replace the fan after it has disintegrated, you'll have the problem again ('cuz, the theory goes, the fan wasn't the problem).
I'm not sure if that theory is correct - but - I didn't replace my fan. I just replaced the clutch.
What do others think?
Old 07-06-2011, 04:55 AM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
Bluebee: imho knowing how the heat/cold cycles affects the cooling system plastic components and knowing how weak are those components after 80K miles, I'd say that even if the fan is in "good" condition, I'd replace it, as part of the cooling overhaul.
Old 07-06-2011, 05:11 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
The hood is about $800. Note that the padding under it is a separate part, and that's over $100, more like $130-150 as I recall. If it was just dented, you might be able to have a body shop fill it, but with those punctures . . . dunno, might be better off just replacing it, money wise. Also I hope the hinges are still good, as those are pricey too (surprise).
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 07-06-2011, 07:04 AM
Melrose Melrose is offline
Mein Auto: 540i
I could not believe what happened to me. While changing the belts on my 128 k 1999 540, I dropped the fan a distance of 18 inches, and it literally exploded. Why not a nylon fan like the rest of the world ?
Old 07-08-2011, 06:16 AM
StevieV22 StevieV22 is offline
Mein Auto: 03 540I 6spd M - 06 ML500
Mine exploded around 60k.
I'll stop by a body shop today and come back with what I'm quoted
Old 07-08-2011, 08:37 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
WOW! It even blasted the paint off the hood emblem! I'd rather have a salvage yard hood than have that repaired. It looks bad.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 07-08-2011, 10:57 AM
Joe@Bavarian Joe@Bavarian is offline
Past Sponsor
Mein Auto: Me - E39 5spd, Wife - E36
The problem with bondo on a hood is you can see it 90% of the time. A good shop will not even offer to fix it.
You can also use a OEM metal fan blade off a E32 750IL when you replace it so it does not happen again.
Old 07-08-2011, 11:06 AM
Chisum Chisum is offline
Mein Auto: 02 530iT/6 ZHP, 03 525i
Electric Fan
Suddenly my Zionville radiator with electric fan does not seem to cost too much
Chisum
Old 07-08-2011, 01:02 PM
The fan has since been replaced and the emblem as well. I think I'll go for a replacement hood. Found one on ebay recently that came off an E39 M5. Does anyone know if an M5 hood will fit on my 540? The best part about this hood is that the color matches.
Old 07-08-2011, 06:37 PM
It's the same part. It'll fit fine.
Ben
Old 07-08-2011, 07:09 PM
Tyrone Tyrone is offline
Mein Auto: '97 540i
I'm located in Orange and have a hood in Titanium Silver if you're interested..if it's any more convenient to you than purchasing on eBay. If any interest I can try to take some pictures, though accessibility is tight at its current location. Removed from 00 540i
Old 07-09-2011, 03:13 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
/me gets nervous when He see's this
I have no date to reference when this was last replaced, and since wifey managed to mess up my hood already... idk what to do
/me looks concerned and upset
15486372<-----
Old 07-09-2011, 06:16 AM
Hi Joe,
If the flying-fan problem 'really' is a bad fan clutch or engine/transmission mounts, what would happen if someone replaced a plastic fan with the metal fan - without fixing the underlying problem?
Old 07-14-2011, 05:43 PM
ncmallard78's Avatar
ncmallard78 ncmallard78 is offline
Mein Auto: BMW 2003 540i m-sport
i bought a certafit hood a year ago for 150 bucks. the fit looks great and im very happy. on a high milage bimmer it was the only way to go.
Old 07-14-2011, 06:01 PM
fortunateson fortunateson is offline
Mein Auto: 525i
[QUOTE=bluebee;6170929]You might PM the guys who also went through hoods & quarterpanels from the same problem:
-Bluebee, I really appreciate all the info you share, however, for a fan to chew up a quarter panel it would have to pass the "B" pillar which I don't think could happen. It will chew up a font fender pretty good though.
When it comes to repairing a hood as thin as a E39's it is truly a major chore as you will end up chasing any stretches or shrinkage forever. A good recommendation is a good used hood, soda blast it by someone who knows what they're doing, and refinish. If soda blasting is not an option have the painter spray sealer over the original paint to prevent bleed through and then repaint.
Old 07-15-2011, 01:08 AM
I'm basing that on this thread from another forum:
- I checked it once a month, but yet...
So, if it's not a 'quarterpanel', what is the name of this punctured part?
PS: Here is a closeup of the punctured (whatever it's called) panel:
