Old 07-05-2011, 10:25 AM
99740il 99740il is offline
Mein Auto: 99 740 il
E38 / 1999-740il DSP / Nav / Radio issue?
Hi Guys,
I have a '99 740iL the radio would randomly come on and shut off. The GPS quit working, so thanks to this forum i started my research to fix my problem. I really wish all of these things were all separate ! oh well !
So after reading and trying my best, here is what I have done.
1. Checked the voltage of the battery, it has been replaced with a new battery. - Didn't fix the issue
2. I pressed the eject button and connected the power simultaneously - Didn't fix the problem.
3. Unplugged the GPS Nav mkII from the car and plugged it back in. Didn't fix the problem.
4. My dad has a 2001 740iL with the same GPS, so i plugged his unit into my car with no luck, I did put my unit into his car and the GPS /radio all work. So my GPS unit is not bad.
So from reading the forums I have a few conclusions,
1. Either my dash display needs to be changed as i do have a few pixels that are bad,
2. Change the ignition as that could be the cause
3. The DSP could be bad. Note: the dsp does not light up on the monitor it is greyed out.
Anything else you guys would recommend? I should try?
Thanks,
Raj
Old 07-05-2011, 06:45 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
try the e38 forum..you posted this in the e65 (2002+) model
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
dsp, gps, mkii, nav, radio
