E28 (1982 - 1988)
Old 04-09-2009, 11:56 PM
Don Mac Don Mac is offline
Mein Auto: 1983 528i
Exclamation Location of Central Locking Unit E28
Can't find the controller for the central locking on my right hand drive E28 528i (1983).
I have looked in the rhs footwell; behind the instrument cluster and nearby.
Old 04-11-2009, 06:37 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
If I remember correctly, you have to remove the drivers side front speaker and tucked in there you will find it. You need to pull the carpet to gain access to two screws. If you don't have it by now, get a Bentley's E28 maintenance manual. You WILL need it to work in these cars!
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
Old 04-16-2009, 04:09 PM
Smile
Thanks, you were spot on. Unscrew the two screws and pull down the cables. The overload relay contacts needed resoldering after all its hysterical activity. All fixed
Cheers Don
Old 08-23-2009, 12:05 AM
mahogany mahogany is offline
Mein Auto: 86' 528e
would this apply to the 86 528e too?
Old 08-23-2009, 06:08 AM
south26 south26 is online now
Mein Auto: 535i 1989
Yes it is in the same place.
Andy
Old 07-06-2011, 11:48 PM
Mein Auto: 86' 528e
Hey Andy Thanks! I will check it out...
Old 07-07-2011, 05:21 AM
it is on the Passenger side not the drivers side.
Andy
Old 01-29-2017, 10:38 AM
IrollBMW IrollBMW is offline
Mein Auto: 88 528e
Hi: I can now only lock or unlock the doors on my 88 528E by using the key or pulling up on the door lock knob. I checked fuses, and they are okay. Next step is to check the central locking mechanism, since none of the locks are working. Where is the mechanism located? Is it behind one of the front speakers, as suggested above for a different model? Thanks
