Old 07-15-2011, 07:47 PM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
Engine head
Is it worth trying to rebuild your crack engine head , or should I just pay $800 for a another one??????
Sent from my SPH-M900 using Bimmer App
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 07-15-2011, 08:32 PM
bobdmac bobdmac is offline
Mein Auto: 2001 540i/6, '90 BMW k75s
I think $800 is pretty reasonable for a head if you can be confident that it's in good condition;
Old 07-15-2011, 10:12 PM
Did the engine overheat?
Old 07-15-2011, 10:46 PM
jbonly21's Avatar
Yep
Old 07-16-2011, 02:21 AM
Anderias86 Anderias86 is offline
Mein Auto: 2002 525i sport
did you take the engine apart and verified the head is cracked, its fixable if there is a machine shop by you also its cheaper, update us with what you get thanks
Old 07-16-2011, 06:28 AM
Originally Posted by Anderias86 View Post
its fixable if ...
A while back, people were coming into Bimmerfest once a week with blown engines due to overheating ... so ...
I read all the overheating threads I could find to come up with this set of references to help people like you.
Read these and then add your input so that we can help the next person after you. Learn from and add value to these threads where you can by asking related questions:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28).
Old 07-16-2011, 11:57 AM
jbonly21's Avatar
Haven't taken the head apart, I wanted to know my options before I did, I also need a couple more weeks to have the money.
Old 07-16-2011, 06:21 PM
Try a can of Bars Leaks first, at a cost of about $8.00, I think. Search the forum for a couple of threads on this.
Old 07-16-2011, 07:06 PM
jbonly21's Avatar
its fixable if there is a machine shop by you also its cheaper, thanks[/QUOTE]
has anyone ever had this done, and what was the out come?
Old 07-16-2011, 07:08 PM
jbonly21's Avatar
Try it already,didn't work.
Old 07-16-2011, 07:14 PM
Ah, too bad. It's sweet when it works.
Old 07-16-2011, 07:41 PM
People have welded it. Successfully.
Look at the referenced threads for the details and contact information.
Old 07-18-2011, 03:25 PM
jbonly21's Avatar
So I figure why saving for my repair why not give this a try, what's the worse that could happen ?
Old 07-18-2011, 03:33 PM
I thought you said you tried this already, and it didn't work.
Old 07-18-2011, 04:42 PM
jbonly21's Avatar
I try the k&w, it didn't work, and back then the car had the original water pump and fan clutch, I replace those already, I am hoping that will make a difference.
Old 07-18-2011, 04:56 PM
Okay, let us know how it turns out. Some people have had some amazing success with the Bars Leaks
Old 07-18-2011, 06:01 PM
jbonly21's Avatar
Maybe I am over doing it, been driving around in this Cal sun for about 4 hours with the bar stay in the engine. Haven't over heated, about to drain it and let it sit over night, wish me luck.
Just paid $ 27 for bmw coolant at the dealer, is that what they go for?
Old 07-19-2011, 10:22 PM
- Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1)
Old 07-20-2011, 02:21 AM
Burning2nd Burning2nd is offline
Spinning Vinyls
Mein Auto: e39(01) e36(97)
mechanic in a can will work for a few hours to get you home... But i wouldnt add that..
It will bust up your heating and cooling system..
Is it leaking fluid? Bimmers are strong i bet you can run it for a long while still with a cracked head
01 540I
97 328is
live Thursday and Saturday night
www.ukbassradio.com
