2001 528i engine
My son ran his 2001 528i with a cracked radiator and ended up with a blown head gasket and bad water pump. The shop that looked at it said two of the head bolts tightened, but a third just spun so the engine is shot.
Is there a market to sell a beemer with a bad engine? It is very clean. Or, is there a reliable place to try to buy a rebuilt engine? Perhaps a BMW enthusiasts would like a project to work on... The car is currently in the Seattle area. |
Part it out. I need a fuel door.
![]() Sent from my iPhone using BimmerApp |
See: - What to tell people who overheated their BMW E39 engine (1) Quote:
See: - What is the difference between a bimmer and a beemer and, um, yeah, a beamer (1) In the thread I referenced above, there are places listed which will sell a rebuilt engine for the E39. You might want to price it out. You can get the parts value and some reliable shops for advice from this link: - BMWfans phantom diagrams (1) & realoem nominal prices by part number (1) & EACTuning prices by part number (1) labor rates by zip code (1) (2) (3) where to find a good mechanic (1) (2) joining BMWCCA (1) (2) & finding a reputable BMW indy in your area (1) (2) & the most often recommended parts suppliers (1) Good luck. Let us know what you end up doing. |
Fair enough if a daughter did it because, no offense bee but women know f all about cars and they car just as much.
But for a boy to have the same 0 factor? Is it just me or are the younger generation of boys just caring less about their cars? On the other hand man these lil aluminium blocks are weak as piss!!! Sent from my iPhone using BimmerApp |
Truth be told.... If I didn't know E39 cooling systems were so prone to failure, I wouldn't know to pay any extra attention to it. Then again, I might not have bought it...
RE: mazzellaak
You can do a used engine with a 2-year warranty. If you decide to fix it let me know and i will discount it down for you. I'll be back in the office Monday. -Joe |
Hi Joe,
I'd like to add information from you to the recommendations in the threads. Is there a specific web page listing options specific for E39 users who have blown engines (typically newbies to the forum) that I can reference them (other than the home page)? Do you have an E39-specific linkable resource? Bluebee |
Go here: http://www.bavengine.com/
They are close to you and do a very good job on their rebuilt engines. Go with the 5 year warranty. Going to have to balance out whether or not it is better to finance another car or just put a rebuilt engine in this one and keep driving it. In this economy, my bet is on the rebuilt. Last edited by jarhed1964; 04-14-2011 at 05:44 PM. |
BMW 528i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M52 1996 - 1998 BMW 528i 4DR E39 BMW 528i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M52tu 1999 - 2000 BMW 528i 4DR E39 BMW 525i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M54 2001 - 2003 BMW 525i, 525i Wagon E39 BMW 530i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M54 2000 - 2003 BMW 530i 4DR E39 BMW 540i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M62 1996 - 1998 BMW 540i 4DR E39 BMW 540i 4DR E39 ENGINE - ASSEMBLY - Long Block - Used M62tu 1999 - 2003 BMW 540i, 540i Wagon E39 BMW M5 4DR E39 ENGINE - ASSEMBLY - Long Block - Used S62 1999 - 2003 BMW M5 E39 |
Hope the son won't be getting the car back anytime soon
![]() I'd replace the engine. IMHO there's little that will replace an E39.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
Thanks.
I peppered the overheat advice and engine-swap advice threads with the following table from you so that users with this problem have the information ready at hand. Quote:
Based on yet another overheated-engine-blown thread today:
- E39 (1997 - 2003) > Engine head For the cross linked record, to help others in the future, I've compiled all the overheated-engine-blown threads I could into a set of comprehensive links as shown below: - Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28). |
I'm 19 and I've had my 2000 528i since I was 15 and have put almost 70k miles on it (got it at 100k miles) and i do all the work myself on my car and enjoy every bit of it. Maybe thats why everyone comes to me for problems... I dunno... Sorry for ranting
2000 528i steptronic Blacked out |
We were all young once ...
Another overheated leaking cylinder #3 today:
> E39 (1997 - 2003) > Cylinder 3 Misfire
I stopped referencing the blown-engine threads in the bestlinks at 50 threads, but, one thing interesting about this thread today is that one person's catastrophe is another person's boon!
> 5 Series > E39 (1997 - 2003) > ENGINE R&R help... Quote:
Another blown engine:
> E39 (1997 - 2003) > SES light Quote:
Another probable blown M54 engine:
Another cracked head, this one temporarily fixed with magic in a can:
Here's another one today which is probably an overheated engine due for replacement:
Advice to young drivers....
Based on the topic, teach them to be alert to the smell of coolant.
I have gone through 4 young drivers. I have been lucky. Alertness and awareness can be stressed and they will remember you for it. Quick instructions while still in the driveway. They cant always call AAA (or you). What coolant smells like and its consequenses of loss. How jumper cables work. How to safely change a tire. How to check oil level and windshield fluid. How to change a light bulb. (easy pull-over for cops) How to pull OFF the highway. (not breakdown lane) You can judge a car pulling out by looking at its wheel spokes. Do this when they want the keys for independence. You are catching them at their peceptive and absorbant peak. |
This is wonderful advice!
BTW, here's another thread opened today where, as usual, overheating is the first major symptom - yet - folks concentrate on bleeding - in the hopes that the air in the system is what's causing it to overheat. > E39 (1997 - 2003) > 2001 525i Overheating So that others have the bleeding information, I added these PDFs from the bestlinks to that thread:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 11-29-2012 at 02:33 AM. |
Get and older 528 engine put in I have a 1998 and it doesn't have the aluminum block
For the record, another user with a blown engine today is seeking advice so I pointed him to the canonical set of replacement engine advice links, one of which is this one:
BMW_E53_X5_M54_Engine_Training_Manual.pdf M54_technical_information.pdf
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-04-2012 at 11:19 PM. Reason: Added pdfs. |
#25
Looks like another Bimmer bought today with a blown engine.
At least I hope these guys get 'em cheap. Quote:
Another blown engine today:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-18-2012 at 08:33 AM. |
