no injector pulse - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 07-06-2011, 11:40 PM
vicacq vicacq is offline
Mein Auto: 1985 BMW 528e
no injector pulse
Seems like I got spark,I definetly.got fuel,but still only runs if I spray starting fluid ,but doesn't run off its own fuel,I'm thinkin no injector pulse,where do I start in the testing process please?
Old 07-08-2011, 06:31 AM
catso's Avatar
catso catso is offline
catso
Check for voltage at the injector connection.
![/I][/FONT]
Old 07-14-2011, 11:34 AM
ok, so i got power to the injectors but when i turn the car over there is no power to the injectors,and as soon as i stop turning it over the injectors have power again..but no pulsing,thats for sure
Old 07-19-2011, 05:27 AM
ernesto50 ernesto50 is offline
classic
Mein Auto: 1985 735i bmw
crank sensor controls injector pulse ohm out that sensor not sure on the spec.
Old 10-18-2013, 02:42 PM
Alika808 Alika808 is offline
Mein Auto: X5
Hello,
Seems I have the same issue with my 1998 323is. Replaced the crank sensor but still won't start. Anyway, the issue start when I wash the car and sprayed water into the engine compartment. Anything else to check or replace? Thank you.
Old 10-18-2013, 03:15 PM
catso's Avatar
catso
Originally Posted by Alika808 View Post
Hello,
Try posting in the E36 forum, they are more likely to know what's wrong with your car.
![/I][/FONT]
