E46 M3 (2001-2006)
Old 07-18-2011, 07:01 PM
mexican mexican is offline
Mein Auto: 01 320i
Cool brittle plastic hoses
checking my ccv,tried to remove hose from from front of valve cover.plastic so brittle,the hose just snapped clean in half.wrapped with black electrical tape.ordered new ccv valve,and hoses.not something i wanted to get into,right off the bat.after reading about the complication of changing ccv.i guess to drive a classy car,there is going to be a learning curve.love my first bmw.01 320i 5speed.
with this great site,i feel any problem can,and will get fixed.
thank-you
Old 07-18-2011, 09:33 PM
Mein Auto: 01 320i
hoping
tape looked like it might hold ,may-be a few days.disconnected broke hose,covered with cable weather proofing shrink wrap.looks like,it will hold longer than crap from 3rd world parts store,or ebay.
Old 07-23-2011, 02:33 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
I have a suggestion from you having replaced the CCV a few times. What the easiest thing to do is to replace the CCV is to remove the front brace that attaches to the intake manifold to the block. Once your remove or at least loosen the bottom and remove the top bolt you can move it out of the way. That will allow you to get the CCV out. Note that you have a black rubber hose going to the dip stick and that will be totally welded to the CCV so don't bother to try and save it, you need to replace the hose and it is just a cheap rubber hose anyway. The other black plastic pipe is from the valve cover, the one you broke and the other is a rubber hose that is inserted into the intake.
With your airfilter out of the way you should be able to do this with the brace out of the way.
Old 07-24-2011, 06:32 AM
Mein Auto: 01 320i
re brittle plastic hose
thank-you for the suggestion,i will give it a try.Waiting for my parts,and Bentley manual
