Old 08-06-2011, 01:18 PM
Brian.G Brian.G is offline
Mein Auto: 02 525i Msport
2002 E39 525i - Power steering whine solved in detail
Right, after a lot of online looking at what this noise could be, everything pointed to a fluid flush, or air in the system.
A little history on the problem first.
I have owned the car two months now, it is an 02 E39 525i Msport 155k miles.
From the day I picked it up it had that horrid whirring noise coming from the belt area.
Because the Idlers and belts where due a service, I changed them out with the new revised hydro tensioner, and the additional idler which bolts to the alternator bracket. It was then about 5% quieter, and still driving me mad.
For anyone wondering what it was that was driving me insane, it was a whirring noise coming from the belt/power steering pump area. This noise was constant, even with the wheels straight ahead, and the pump by-passing. It got far louder while you were turning wheel in any direction.
On inspecting the fluid it was pretty bad, so I changed it out for some uber fluid. Flushing the entire system at the time made no difference either.
For days I thought there was still air in there, so I opened all connections EVERYWHERE to see if I could get it out. No luck, it all seemed ok.
Off with the belt to try and see could I feel the pump rough by turning it with my hand, no noticeable roughness, how strange....
For fun, I called to the dealers to ask the parts guy if pumps where a common wear item. I got the usual ''They never go'' ......but, he did say a new one was around 700euro or something. No thanks, Id rather make one myself. He then said that a place near me reconditioned PS pumps....interesting I thought....what exactly could go in them....not much in there.
I then decided to pull off the pump, and tear it down, I had nothing to loose really.
For anyone not into tech stuff, or not into engineering, then search ''Sliding vane pump'' its the type of pump used in many PS systems. For anyone that is an Engineer, then you will know all about them. I say that, because I know a LOT of Engineers with E39s - Best car in the world right!
Given that I have the car just two months, I didnt really know its history. But, It does have a full service history, each service bill in the region of 800euro - this woman minded her car and replaced anything it needed before time. The power steering pipes to tank were damp as they do sometimes be, and the clips and hose had been replaced with proper clips, and the hoses cut back. So, basically what Im getting at, is that I dont think it ever ran low on fluid, at least not low enough to starve pump dry. This bit is important for my diagnosis later.
By the way, Incase you dont know by now, I tend to keep looking at stuff until Im happy with why it failed. I cant really accept that It did, and carry on.
So, onto the pump teardown, Its easy remove as you know, 3 13mm bolts, a 10mm bolt holding a pipe clip, and of course the pipes and belt need removing. Its a 15min job to have it out in your hand.
Im going to assume for the next bit that you may or may not want to open your pump for fear of messing it up. Thats fine - but, that doesn't phase me one bit, Im used of this kinda stuff, seeing how it was built/designing similar things/and so on.
The pump below, with the metal brackets removed,
Rear removed(4 torx bolts)
And here lies the fault, the internal wall where the vanes run is damaged heavily as you can see, this should be very smooth, with no steps or ridges, and symmetrically oval shaped for want of a better word/calling,
A few close-ups of damage,
Not pretty is it.....you can now see how a shocking clicking/whirring noise can originate from the pump given that the vanes are passing over these ridges at high speed,
Conclusion:
On inspecting all this closely, I knew right away that it had all the signs of the classic vane pump cavitation.
Cavitation in this case is caused by a partial vacuum forming on the intake side of pump.
You can read up on cavitation in depth if you wish, Im not going into too much detail here, as I feel there is no point, its a vast subject which would require a post all of its own.
But, having said that, I need to explain it a small bit so you'll understand why it happened in this case.
First off, this pump was not worn by it ever running dry.
It was something different that caused the wear.
If you know about vane pumps, you know how they work, if not, get reading.
The problem in this case is pretty simple. If there is a partial vacuum on the intake side then the vanes cannot slide out of rotor to conform to the internal wall. Once this vacuum is relieved behind the vanes(slot pockets) they shoot out and hammer into the wall at high speed. The areas where the most wear took place indicates even more that this is the case.
Now....the vacuum on the intake side, what caused that I hear you ask....simple.....the filter in the PS fluid tank.
One thing I hate in all systems, is any type of filter that is contained within the holding tank. Simply because it means that it is either forgotten about, not even known about, or not replaceable at all in my case.
And guess what....my filter was rotten dirty. As you may know, it is screwed down with a small torx screw. I removed this, and also removed tank from car. With the filter free inside the tank(its too big to come out) You can then fill the tank with some Jizer or whatever, and give it a good shake. Repeat a few times until solvent runs clear.
Keep in mind that the oil will also be thicker in lower temperatures, which in turn will make it even harder for it to pass through a blocked filter.
The cavitation was so bad in my case, that it was actually aerating the fluid on re-entering the tank. These small bubbles could clearly be seen after a run. But, I did think at the time I just had some trapped air in there that was being constantly recirculated.
The filter is now minty fresh, and screwed back in. I have to admit, I did think about cutting holes in it for peace of mind. Its simply too fine a mesh from the factory. I hear you say, that thats madness, but, you have to ask yourself whats better, a blocked filter that causes cavitation that kills the pump. Or, some slight contaminants in the oil that also may kill pump. Given that the pump is fairly robust, and could handle small particles, you have to ask yourself which is the better route? In this case, it seems that they should have gone with a bigger mesh filter Im afraid.
As for the black sludge in the filter.....where is that from....again, easy, but not too obvious at first, its from the interior bores of all the rubber pipes.
Perhaps the rubber was of poor quality, or the fluid not 100% compatible with that particular rubber.
Amazing all the stuff you need to add up to conclude a failure for said part down the line.
You could say that maintenance may have prevented this. Maybe, maybe not...
A fluid change would have done damn all for the filter.
A filter change is not possible without renewing tank.
A filter clean to my knowledge is not wrote down by BMW as part of any service.
Hoses should last forever if they are matched with whats flowing through them.
So....it brings us back to the fine-ness of the mesh in the filter, or if they should have just run without - the pump is dead now anyway with it as mentioned above.
Now.....enough of that.....conclusion has been found, I now had a car with no PS pump!! A new one may as well be a million Euro, and my recon guys were on holidays for three weeks. Actually, a quick word on a recon, I suspect they refit the worn ring with a new one, and perhaps new vanes and bearing. I really, really doubt they are re gringing the internal wall. Its just too complex a geometry I feel to bother with, but, maybe they do...I wouldn't, you gone way into the ideal case hardening at that point.
!!**********The next bit is for the fabrication die-hards that hate spending money, proceed with caution*************!!
So, a quick look around the 'spares' bin, and guess what..... A mk3 Golf PS pump is more or less IDENTICAL to the BMW Item!!!!!!!!!!!!
The chassis of the pump is the same bar one bolt hole with does not exist on the Vw pump. There is still 5 m8 bolts holding it on to the metal main bracket, so Im more than happy with that and I would also be happy if it was to do with an aeroplane I was sitting in. Take my word on this, its perfectly fine to run on there.
So, this now means that you have a ton more scrap yard pumps to choose from as the Mk3 Golf PS pump is very plentiful, and I suspect, about half the price.
Fittings are also the same and nothing needs to be changed.
There is one small catch though and that is the pulley offset.
This is a simple thing to get around though depending what you do, or who you know, or where you work. It involves 15min on a lathe and 2 euros of aluminium. Cheap, compared to a new pump...or a second hand one you may not be able to find!
The Vw pump pulley flange face sits 14mm farther out than the Bmw one. The Vw shaft is 14mm longer if you like. The pump casing is the very same bar one bolt hole as I said above. Also, the Vw pumps are cast iron bodied, the Bmw item is Lm25 aluminium alloy.
Ideally if I had it(Billet, or time to cast), I would have made a complete billet, or cast Alloy pulley. But what I did instead was fine too, and you could do the same if you wish.
Below is a rough drawing of where you re-gain the 14mm offset. All other measurements are not important, just fill them in as you go/measure vw pump flange diameter.
And a few bad pictures of starting to make it, and of it fitted, didnt have time to take some along the way,
I plan on casting a one piece all alloy pulley for it next month, hopefully... Its fine as is, but the plastic pulleys can be bad at the best of times.
So, thats it really, the last bit may never be carried out by anyone, but, its an option, and an easy one if your near a lathe, considering how plentiful Vw pumps are, and the fact they bolt right up.
To conclude everything.....
The Filter is the main problem I feel. Its just too fine to let the lesser threatening crud through. The crud comes from the interior bores of the rubber hoses. They may be to just poor quality hoses, or, Incorrect/incompatible fluid being used at sometime.
I know a lot of places say to replace the hose. This is no good on its own, since filter needs cleaning too.
And...If your pump is whining, its too late at that point as you can see above.
As for the Vw pump, its running just ace, I can now hear just the injectors opening as you should on the I6 engines. All whirring is gone. Steering feels way better, and the pump internal volumes are very near the same also.
All fluid aeration is gone.
I probably wont change any of the hoses to be honest. Theres new and correct fluid in there now that I can be sure of. I may or may not bin the filter at a later date though....at my own risk of course
Hope this might help or enlighten even one person at least, if it does then even at that, it was worth typing. The Vw pump bit may save a few pound too, and something to show to the techs in Bmw perhaps the next time your in!
Take care,
Brian Garvey.
Old 08-06-2011, 02:28 PM
In your description above, the fine mesh of the 'permanent' power steering filter clogged, causing, in the end, damage to the power steering system.
This was a very interesting (and thoroughly logical) story to read!
Thank you very much for providing valuable insight for us, who, do not want to have to deal with what you valiantly overcame!
Your story is a great example for why we currently recommend changing the power steering reservoir ATF at every oil change ... and ... thoroughly washing the circular mesh filter periodically!
- PSF: Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1)
- Power steering: Dexron III ATF Bentley page 020-20. (realistically, that means Dexron VI ATF because all GM Dexron III licenses expired at the end of 2006 & were not renewed by GM). Note: The E39 I6 (i.e., rack and pinion steering attached to an aluminum subframe) does NOT have a power steering drain bolt on the bottom of the steering pump; the E39 V8 (i.e., recirculating ball and nut attached to a steel subframe) power steering DOES have a drain bolt on the bottom of the power steering pump. Replacement Interval: Bentley says it's "permanently filled"; but most of us would replace the hygroscopic power steering fluid at 30,000 miles; some recommend removing the 8 ounces (250 ml) in the reservoir at every oil change - and removing the T20 Torx bolt on the permanent reservoir screen every 5 years to clean the circular filter more thoroughly - and to replace the power steering cap o-ring every five years to prevent misting. [Volume: about 2 quarts to replace; otherwise about 1 quart to flush the reservoir twice & clean the filter screen; the fluid level should be between the MIN/MAX marks on the dipstick].
Kudos to the OP for both the excellent writeup - and his pictures - which I reproduce below (shrunken to a consistent 640x480 pixels) for posterity.
Interested readers might also wish to read:
- How to clean the power steering fluid reservoir internal filter (1) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush cloudy ATF fluid (1) (2) (3) (4) (5) & what PS fluid to use (1) (2-pdf) (3-volume) & what volume is needed to buy (1) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5).
ID:	288000   Click image for larger version
ID:	288001   Click image for larger version
ID:	288002   Click image for larger version
ID:	288003   Click image for larger version
ID:	288005   Click image for larger version
ID:	288006   Click image for larger version
ID:	288007   Click image for larger version
ID:	288008   Click image for larger version
ID:	288010   Click image for larger version
ID:	288011   Click image for larger version
Last edited by bluebee; 08-06-2011 at 02:55 PM. Reason: Added the pictures in case the original site goes down in the future.
Old 08-06-2011, 04:00 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Bravo!
Kudos for an amazingly detailed and information-packed post.
I had wondered about cannibalizing units from other makes/models. I've seen "rebuild kits" sold online for VW and Volvo PS units but none for the ones that are used in our e39s.
At a minimum, I am going to be cleaning out my PS reservoir filter real soon, as instructed.
Old 08-06-2011, 08:22 PM
cn90 cn90 is offline
Wow,
THANKS Brain for sharing the PS Pump Anatomy.
My 2007 Honda Odyssey van with 35K miles had the PS Pump Whining, it turned out to the the PS Reservoir!
I replaced with new Honda PS Reservoir, problem solved. It is a known problem in Honda Odyssey vans (2005-2010 models).
When I flushed my Honda Odyssey PS Reservoir, I found that the typical fluid flow through the reservoir is amazing: the entire reservoir (12 ounces) is drained within 1.5 seconds.
In other words, the typical flow through a PS Reservoir is: 12 ounces/1.5 seconds or about 14.4 L/minute!
For some reasons, the E39 PS Reservoir lasts a looong time without issues.
However, after reading your thread, I think it is a good idea to replace the PS Reservoir:
- At ??? 150K miles, or
- When one hears the PS whine.
Old 08-06-2011, 08:23 PM
Originally Posted by pleiades View Post
...At a minimum, I am going to be cleaning out my PS reservoir filter real soon, as instructed.
I'd not clean it, replace it.
It is about $25 at dealer.
These days it costs $60 to fill the gas tank anyway!
Old 08-07-2011, 02:53 AM
Westech's Avatar
Westech Westech is offline
Mein Auto: '00 Z-3 '06 325ixT
Fantastic Post
Thank you for your time and effort. This is what the forum is about.....one Bimmerhead assisting another. Magnificent job.
Old 08-07-2011, 10:42 AM
it is a good idea to replace the PS Reservoir: At ???
I don't disagree that it's not a bad idea to replace the power steering reservoir at any time ... but ... if it's 'really' only the filter we're after ... then I see no problem with simply cleaning out the filter 'periodically'.
When I looked at mine (at <100K miles), it was pretty clean (photos here); and, even if it were gunked up like the OP's filter, why wouldn't the suggestion of temporarily removing it and swishing a solvent about the loosened screen work just fine?
If you couldn't 'see' the screen - I'd then say that replacement is the 'best' idea; but, since you can loosen and clearly see the entire screen, my argument is the same as edjacks (I think) which is something like:
  • Replace the 8 ounces of fluid in the PS reservoir at each oil change
  • Clean the filter at ? (dunno) ... maybe every 4 or 5 years?
Of course, that's just my 2.
Old 08-07-2011, 11:42 AM
Jcourcoul brought up a good point over in this E46 thread today:
> Recommendation to clean your power steering fluid reservoir circular wire mesh filter
See warning in bold red below:
Originally Posted by jcourcoul View Post
Interesting. So a T20 holds down the mesh "filter" which is cylindrical in shape. Does it fit easily without damage thru the lid orifice? Cause once loose, you'd need to carefully tease it out without too much disturbace, so any deposits in it come out instead of dropping right down to the pump.
In that case, JimLev's suggestion to clean with gasoline OFF the vehicle may be apropos:
- Looks like PS systems are the hot topic today
Originally Posted by JimLev
Edjack had mentioned in a post about draining the pump and cleaning the reservoir with gasoline. You'd be surprised at the crap that the screen collects. No need to replace the reservoir, a cleaning is all that's needed.
You can ... remove the reservoir, unscrew the filter and flush with gas.
Old 10-05-2011, 10:27 AM
ericono ericono is offline
Mein Auto: 1985 M635, 2000 528iT
I just saw your post and love the detail and effort you have put into it. I agree, I'm an engineer as well and have an e39.
Anyway, my question is, could you have swapped the worn part you showed out with the same part from the VW pump? I would think this would save the need to machine an adapter for the offset.
Thanks again,
Eric
Old 02-11-2015, 12:31 AM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
Sorry to bump old thread but I changed my ps pump a year ago it was whinning
Now the new used one is clicking or something like this you can hear it when you put your ear in the reservoir while engine running
I've changed all pulley also not from water pump not alternator
Only this can it be rebuilt if I dissassemble it
If I took the worn part and ask to make same will he make or they don't know ??
Old 02-11-2015, 12:47 AM
ALGhoul
And by the way will runing the car while it's making that sound from the pump will harm rack steering mean there is some metal part from power steering pump will go to rack steering and spoil it or is it normal as my sound stil on the beginning not too noisy
Old 02-11-2015, 04:09 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
Sroor, I dont think you can buy parts for the pump. The OP did indicate that the pump was the same as a VW mk3 Golf. You might be able to swap parts from a VW pump and avoid the modifications that the OP did. Normally, you would replace your pump with a rebuilt or new.
When someone says "What year is your Bimmer?", I say "What part".
Old 02-11-2015, 05:10 AM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
for old Toyota I could buy the rebuild kit, was a few O-rings and seals, for $15.00 and new fluid. Not sure how much now, but was easy. hard part was R&R, the bleeding the air was a pain but doable. Not sure if you can buy rebuild kits for bmw, no many seals in there just a pain to get out disassemble... but good as new when done...
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Old 02-11-2015, 08:50 AM
ALGhoul
ok here is whats inside
i'am surprise why it was whining or clicking
opened 4 screws
no problem in this which supposed to make wining
these all parts
one of these small chip insert lost but will it affect if i assemble it and retest it again and as there is no cavitation from where that sound ?
can i use it there is no bearing sound its ok onle that grease on the sides of the pump
so it need a seal kit but what ive seen the seals are ok but it seem this soil or grease was from previous owner i refill it and its not leaking
but whats this noise ?
Old 02-11-2015, 08:53 AM
ALGhoul
just want to know if i use it with one chip lost is it ok ?
Old 02-11-2015, 12:04 PM
Flybot's Avatar
Mein Auto: '98 528
I would not use it without all the vanes (chips).
You probably just had air in the system. I was going to replace my pump because of noise and and while waiting for the pump to arrive I took the reservoir out expecting the filter to be dirty and clogged. It was for the most part clean after over 200,000 miles. I put it back together and bleed several times and I havnt had any noise since. I had to do the bleed procedure several times to finally get all the air out of mine. I just bled it over a couple of days as I was pulling out of the garage.
Old 02-11-2015, 10:27 PM
ALGhoul
Thanks flybot
But how many time you have to beld the system it seem you have done it many time is it by just open the reservoir cap and turn the steering left and right
Old 02-12-2015, 04:08 AM
Flybot's Avatar
Mein Auto: '98 528
When I changed the steering rack a few months ago I bled the system 5-6 times. After a few months it started making the pump whine/buzz noise that you have. I was going to change the pump, but as I said, I cleaned the res filter (but it wasnt really dirty) and re-bled the system again a few times. No noise. I think maybe a bubble will get trapped in the system. In your case the pump seems to look fine. So the noise must have been something else.
Yes, to bleed the system, just turn slowly full left and right. If you look in the reservoir with a flashlight while this is being done, you can see fine bubbles, like from a soda, enter the res. Turn off the engine and let the bubbles dissipate and repeat until you dont see any bubbles. When you put yours back together and start it there will be quite a bit of air and it will not sound good. Just keep bleeding it. It will take several cycles.
Old 02-12-2015, 08:10 AM
ALGhoul
Thanks a lot friend for your help
