E46 (1999 - 2006)
Old 08-09-2011, 04:43 PM
sam2000 sam2000 is offline
Mein Auto: 2000 328i
2000 328i Blown Head Gasket
My 2000 E46 328i with 140k miles, blew the head gasket last week.
I was driving on highway and I saw the temp gauge rising. I stopped and noticed low coolant. Since I was long way from home, I stopped at the gas station and filled it up with drinking water. Gauge was fine, but after few miles, gauge rose and smoked came out. Basically, It died right there.
I got it towed to a shop and the mechanics confirmed me that there's a code for cranking error and there was water on spark plugs.
I have been maintaining the car properly over the years and always prompt with oil changes and other maintenance.
Is this a common thing with E46 inline 6's? What could have caused this? I had no engine lights or any other symptoms that would hint me.
Currently I am looking in to buying a new engine, since I do not want to move on to another car at this time. The dealer quoted me somewhere around 5k+ for a rebuilt engine and saw a place online for way less. http://www.woodfins.com/PartDetails.aspx?SKU=5001746
Any input would be greatly appreciated.
Thanks in advance.
Old 08-09-2011, 08:01 PM
KenG KenG is offline
Mein Auto: 00' 323ci 5sp mt
That is horrible
sorry about the engine
Are you gonna install the engine yourself?
If so and you are pretty good with tools, I say order the one off the website and go for it
Old 08-10-2011, 07:04 AM
I am looking for engines online. Once I find a decent one, I will be going to a local shop. I wonder if it's a direct swap or any ECU, coding work has to be done with the computer?
Old 08-10-2011, 08:21 AM
mike@cobywheel mike@cobywheel is offline
Past Sponsor
Mein Auto:
i swapped an e36 motor into an e30 and had to swap over ecu etc. but if the same motor/model# swap over i would think not but never know.gl
Old 08-10-2011, 12:42 PM
Are you 'sure' it's the head gasket?
- How to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2)
You do have options:
- Summary advice to provide users who suspect a major engine repair due to overheating (1)
I've been keeping tabs, mostly on the M54 engine, and, well, here are the sad stories of the last 30-odd people whose cooling system has blown their engine:
- What happens if you drive 1 mile too far on a bad cooling system (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30).
Dunno. But, the question has been asked of the M54 I6 before:
- Why the M54 engines are so prone to heat-related damage in the first place (1)
I gathered this information for the E39 bestlinks thread, but, companies serving you and options should be similar for the E46:
- How to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2)
Sometimes it 'can' be repaired:
- Welding the crack between cylinder #3 and the water jacket on the exhaust side (1)
Here's my input for a similar question:
- A well researched reusable response to a particular user with a blown engine (1)
Here are things to ask:
- What questions to ask when severe heating-related damage is initially suspected (1)
I don't know either, but, the OP may find hints in this similar thread for the E39:
- What E39 engine swaps are most recommended (1) (2) (3)
Old 08-10-2011, 02:19 PM
Wow, thanks for reply. Will go thru those links..
