Old 07-30-2011, 11:17 AM
entropy4 entropy4 is offline
Mein Auto: Z4
Yet another Z4 Overheat question
Hi all, couldn't quite find anything that precisely matched my symptoms, so I was wondering if anyone might be able to help me troubleshoot.
I have a 2003 2.5 Z4 ~110k. It recently began overheating. This does not occur at highway speeds, only while idling. The odd thing is if it begins to overheat while idling i can rev to ~3000 rpm and the engine temp drops back to the middle. I've only really noticed the problem while the AC is on. Unfortunately it's averaging 100 degrees outside right now When turning on either AC or Heat the electric fan does come on, but if I turn on the AC, let the thermometer climb and then turn of the AC, the fan turns off too.
Kinda stuck here and hoping someone has some suggestions before I start randomly buying expensive cooling system parts.
FYI coolant system does not appear to be leaking and was bled when I replaced the expansion tank about a year ago.
Thanks in advance!
Corey
Old 07-31-2011, 04:43 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Sounds like the electric fan is not working.
The electric fan should run whenever the AC is running.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 07-31-2011, 06:50 AM
GeorgeT's Avatar
GeorgeT GeorgeT is online now
Mein Auto: '07 750i BMW; '03 Z4 BMW
If it cools down when you rev the engine, it sounds as if the water pump isn't fully working. If it were the fan, revving the engine would not have any impact.
Old 07-31-2011, 11:21 AM
Mein Auto: Z4
Brilliant, I'll try replacing the WP later tonight.
Thanks for the idea!
Old 08-01-2011, 06:57 AM
Pinecone's Avatar
M Mad
There are two fans. An electric fan and one driven off the engine.
When you rev the engine, the engine fan moves fast enough to actually move air through the radiator. At idle, the electric fan assists if the temps get up.
Check the electric fan before you change the water pump.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-01-2011, 07:28 AM
GeorgeT's Avatar
My '03 3.0 does not have two fans, only an electric fan.
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
No fan?
Old 08-01-2011, 08:35 AM
Mein Auto: Z4
Just looking at my motor, there is one large electric fan directly in the center of the radiator, I don't see a belt driven fan. I would very much prefer it to be a fan issue seing as how replacing the water pump apparently requires me to move the engine.
Old 08-09-2011, 09:56 AM
Mein Auto: Z4
Just an update, replaced the water pump and the thermostat for good measure (It does suck that you have to move the engine to pull out the pump).
Needle's been hovering in the middle for two days now, keeping my fingers crossed!
Thanks for your input everyone!
Old 08-09-2011, 08:06 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
When this happened to my Audi TT a few years ago it was the electric fan that had stopped working. Your symptoms also indicate a possible water pump issue which you have replaced so good luck!
To check for the fan, it should turn on automatically on a hot idling engine w/o the AC actually being on to regulate the temp by moving air. I don't know what the trigger temp is for BMWs though.
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW Clubsports w/400lb Linear Rear Springs|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|BBS RGR 18x8.5/18x10|Potenza RE-11s
Texas Mile (March, 2010): 155.4 mph
Old 08-13-2014, 06:30 AM
Isaiah73 Isaiah73 is offline
Isaiah
Send a message via Yahoo to Isaiah73
Mein Auto: Z4
Overheated z4 when idled
Thanks in advance!
Corey
I have the same problem even after water pump and thermosated along with pipes and water resovoir was replaced.
Anyone have any ideas what else could be going wrong?
Old 08-13-2014, 06:31 AM
Isaiah
Mein Auto: Z4
I have the same problem even after water pump and thermosated along with pipes and water resvoir was replaced.
I did read that the over heat sensor does need to be reset is that another option?
Old 08-13-2014, 05:13 PM
pokeybritches pokeybritches is offline
Mein Auto: G-Power & ESS Z4Ms, VF Z4
Did you bleed the air out of the system?
G Power Z4M and VF Engineering Z4 3.0i
Old 08-13-2014, 06:33 PM
Isaiah
Mein Auto: Z4
Yes I did bleed the water coolant but not sure about reset the sensor, is that something I can do or do I need a pro?
Old 08-13-2014, 07:29 PM
Just to make sure we're talking about the same thing, you purged the air by cracking the vent near the radiator cap as the car was running but cold?
The coolant temp sensor shouldn't be too hard to replace, IIRC.
Old 08-14-2014, 06:03 AM
kalali kalali is offline
Mein Auto: 2003 Z4 2.5
You should also verify the overheat using a temp gun. Also keep in mind engine overheat could potentially damage the cylinder head if it is not addressed quickly.
Old 08-15-2014, 09:13 AM
Isaiah
Mein Auto: Z4
Yes the coolant was blended the only two things not replace was sensor and fan..
Old 08-15-2014, 09:19 AM
The coolant being blended or replaced has nothing to do with purging the air from the system...
Old 08-15-2014, 03:35 PM
Isaiah
Mein Auto: Z4
Yes the air was purge and took it to be looked at and it turns out it was some bad wiring. Fingers crossed... thanks guys for the help.
overheat, thermostat, z4
