8 Series - E31 (1989 - 1999)
92 850i - Overheat
I'm looking at buying a '92 BMW 850i for $5000 with only 94000 miles. But the catch is that it has been overheated due to a broken aux wyer pump. The water pump has been replaced by the current owner whom I'm possibly buying from but now the engine is acting up. He says that some of the cylinders aren't firing, but I don't think that's it. There is a "clank" noise when the car runs every 10 seconds or so. Can anyone diagnose this or have any ideas on what could be damaged from it overheating. Other than that, the car is amazing. He has Remus cat-back exhausts, ac shnitzer(?) lowering kit, cross drilled rotors, and a short throw kit. I really am interested in trading my e34 540i for this car. Can someone please tell me if this will be a fix that would be less than $1000
White 1993 850Ci - 251,187 miles Black 1993 850Ci - 125,508 miles |
Yeah true, but instead of keeping the current engine. Would it be worth it to buy another v12 engine? The car is pristine other than that.
It is not that easy to determine based on the assessment of a non 8 owner. What might seem to be perfect except that one "little" thing might actually be very expensive in the long run.
The only problem I see with what you have described is that if you did indeed need another engine, you are left with getting one that potentially has the same problem. A "decent" engine is in the neighborhood of $2000 - $2500 and unless you can install one of these yourself, it can get pricey. I have done a number of engine swaps on these cars and can remove an "old" one and install a new "one" in about 9-10 hours. Take the car to a BMW dealer and have them do a leak-down test. This will help determine if there are any major issues with the car. Also a hook-up to the diagnostic computer will tell you if there are any other "issues" with this car. There is also a "Pre-Purchase" checklist available online that can give you a hint of what you need to look out for ( http://www.wuffer.ca/index.php/downl...ellaneous.html ). As for the Auxillary Water pump causing overheating - that really only happens if the outlets on that pump break and you loose all the coolant from it. The Aux Pump is really only for the heater and A/C on these cars.
White 1993 850Ci - 251,187 miles Black 1993 850Ci - 125,508 miles Last edited by TxGr8White; 07-12-2011 at 05:49 AM. |
Sounds like a potential disaster. If i was you don't buy teh car. period. An overheated engine can have a warped head.
