E36 (1991 - 1999)
Old 08-15-2011, 06:14 AM
JohnGutmannnn JohnGutmannnn is offline
Mein Auto: White 1995 325i
I guess you're referring to the transmission cooling coils.
Yup.
Is your trans cooler external or in the radiator?
Not sure, have to check.
Most (all?) were external, bolted in front of the radiator. Easy to switch over.
Found this out when I started looking around. I thought all radiators were created equally. Guess not. I was thinking I could get this set up this way anyways even if the radiator and ATF cooler was an OEM single intergrated unit.
What's an EFM?
EFM = Electric Fan Mod, thought this acronym was from around here, but I guess it is from the Audi forum I am on.
I will post a list of parts I plan to order later on when it is closer to complete.
http://dceuro.com/forum/
Old 08-15-2011, 08:45 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
I never heard of deleting the electric fan. There's the FDM, Fan Delete Mod, but it's for deleting the clutch fan driven by the belt. I wouldn't delete the electric fan if I were you.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 08-15-2011, 08:47 AM
Ummm......
When did I say anything about deleting an electric fan? EFM is exactly what you are describing. I have no idea where you are getting these random details from.
Old 08-15-2011, 08:56 AM
D'oh, You kids!
Well, excuse me. Do you see the similarity between EFM and FDM? The FDM is a "mod" that deletes the fan. I figured you either had the terminology mixed up, or the "mod" was going to be to eliminate the fan. Carry on.
Quotes to live by:
BMW-CCA #441426
Old 08-15-2011, 08:58 AM
Well FDM also stands for Fan Delete Mod Which makes it a bit more obvious.
I am not sure how that acronym got into my head..Maybe I just made it up. I just recall seeing the mod with a link in someones sig somewhere.
Old 08-15-2011, 09:02 AM
D'oh, You kids!
John, that's my point exactly. FDM is Fan DELETE mod, and that is what I wrote, which means deleting the belt driven clutched fan on the water pump. What did you think I said?
Quotes to live by:
BMW-CCA #441426
Old 08-15-2011, 09:03 AM
D'oh, You kids!
I see what you did there.
Quotes to live by:
BMW-CCA #441426
Old 08-15-2011, 09:06 AM
That is exactly what I think you said....
My point was that you were assuming to what "Electric Fan Mod" meant (the wording doesn't explicitly say whether it is being added or deleted) as compared to "Fan Delete Mod" which explicitly states that it is being deleted.
Old 08-15-2011, 10:59 AM
So far I have this all for what I need:
$31 - Fan Clutch tool http://cgi.ebay.com/ebaymotors/BMW-F...ht_2838wt_1165
$120 - Water Pump Cooling Overhaul kit http://www.fcpgroton.com/product-exe...+Kit+1991-1999
$210 - Aluminum Radiator, Electric Fan, Fan shroud http://cgi.ebay.com/ebaymotors/E36-M...ht_2734wt_1165
One thing I cannot find, is a thermal switch for the electric fan. Anything else you guys think I need for this?
Old 08-15-2011, 02:05 PM
D'oh, You kids!
You're right, it doesn't say 'delete', but what "mod" would you do to an electric fan beside delete it (or add it if it doesn't have one already)?
Your list of parts looks good. Is the puller fan that comes with the aluminum radiator the electric fan mod you were talking about? Get rid of the clutch fan and replace it with the electric? I like.
Quotes to live by:
BMW-CCA #441426
Old 08-15-2011, 03:21 PM
Not much, was just referring to the ambiguity of my statement.
Yes, that is what I meant. Know anything about a temp switch? I could make one, but its easier to buy off the shelf parts.
Old 08-15-2011, 03:23 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
jeez you two made my head hurt with that
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 08-15-2011, 03:30 PM
T'was "drive by 72"....
Leaving this here for reference...
http://www.bimmerfest.com/forums/sho...d.php?t=542497
Old 08-15-2011, 03:32 PM
Old 08-15-2011, 04:26 PM
D'oh, You kids!
Why not use an OEM one?
Then my work here is done.
Quotes to live by:
BMW-CCA #441426
Old 08-16-2011, 06:03 AM
Didn't know it was an option. I read through that thread, looks like they just jump the signal off of the OEM one.
Old 08-21-2011, 01:49 PM
Just found the issue. A broken nipple that was connecting 2 hoses. Looks like I got lucky this time!
