Old 03-10-2011, 06:39 PM
raiders1 raiders1 is offline
Mein Auto: 530i
Unhappy Help! Heater inlet pipe replace
I have a 2001 bmw 530i and my mechanic told me that i have to replace my heater inlet pipe. How important is this piece? The part is $40 but the labor is $1000 because the manifold has to be taken off. Does anyone have experience with this?? The pipe is not black like it should be but brownish/yellowish which my mechanic says it can blow at any moment. I've never heard of this piece before. What will happen if that piece blows??
Old 03-10-2011, 07:28 PM
cn90 cn90 is offline
PN = ?
Picture?
Old 03-10-2011, 11:07 PM
I'm a little confused why three threads, all opened today?
- Heater return pipe leak, by raiders1
- Help! Heater inlet pipe replace, by raiders1
- new to bimmerfest , heater inlet pipe, by raiders1
Old 08-21-2011, 02:19 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Still collecting bits and pieces for my "second-stage" cooling system overhaul. Did all of the usual bits last year, now I'm aiming to replace all the smaller heater-related hosing and was wondering, are the so-called "heater inlet pipes" on the M52TU and M54 made of steel? If yes, are they amenable to flushing & cleaning & re-use?
Part #8 (11531705210) in the realoem diagram
Old 08-21-2011, 06:50 PM
Aw, come on ya'll.......
Old 08-21-2011, 07:43 PM
Search forum for posts by "DHoang" and "Mark@EAC".
"DHoang" posted a nice picture of #8 pipe a while back.
The 1997 and 1998 I6: #8 is steel pipe.
The only leak you will ever get is bad O-ring.
1999-2003: #8 is plastic pipe. Go figure!
Old 08-21-2011, 08:57 PM
This thread was referenced in the bestlinks I already referenced:
The pictures were also re-used here:
- E39 528i Coolant. Need your help. Can't figure out.
I just added this to the bestlinks:
- Cooling system heater pipe heater core inlet return pipe leak (1) (2) (3)
ID:	289963   Click image for larger version
ID:	289964   Click image for larger version
ID:	289965   Click image for larger version
ID:	289966   Click image for larger version
Old 08-21-2011, 09:55 PM
Nooooooooohhhh! Okay, must add that to the list, no reason to trust it after 12 years.
Old 08-22-2011, 04:21 AM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
For the M62 crowd popping in here. I recently replaced my heater exchange pipe (made of rubber) on my 535.
I think it ran me about $300, part included. Apparently it's a b*#ch to get to. My indy showed me exactly where it is/was and in hindsight I'm glad he did it and not me. It's tucked hard against the firewall.
On the V8's it's a specially made piece which has a larger diameter opening at one end with a clip attached with the other being smaller plus a tight bend thrown in.
BTW, my symtoms at the time were coolant leaking at a fast rate which was replaced only for it to happen again. The car managed to limp to the indy for diagnosis/repair without anything major happening, thank god.
Old 08-22-2011, 01:58 PM
Thanks for that elucidation.
Since this has not yet been reported (nor photographed) in the pictorial thread on all possible cooling system failures ...
- Pictorial look at typical E39 cooling system failure modes (1)
I took the liberty of adding it, just now!
Old 10-08-2013, 05:48 AM
A Stone A Stone is offline
Mein Auto: 528i
How did you pull out the pipe?
Old 01-17-2016, 06:43 AM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
Did you do it ??
I think I've read somewhere you can get there without removing manifold only the oil filter housing I mean the whole unit so then you can access that mine is fishy but I have to fill just little water about 100 ml or less every week so once it showing more coolant loss I'll think about changing it
Cause just seeing DIY it's a headache and I need to do it within a week cause I don't have patient and I have to take my brother spare car so I can do that Job after extensive reading about this DIY
I know how to remove throttle body and filter also alternator but we don't need to remove also power steering pump but we don't need to remove
But let me read and see the diyers advices it's really horrible
And I'll not let a mechanic do it for me as they are repairing one thing and break few things without informing you that's why Iam trying to be diyer as I changed most parts of my car
But this is the hardest as I think
Old 01-17-2016, 11:09 PM
syphilouis syphilouis is offline
Mein Auto: 2002 530i
I replaced my heater inlet pipe on my 02 530i a few months ago, it was a pain in the ass as I had to remove the intake manifold and replace the intake manifold gaskets since it was off. It took me about 4-5 hours by myself with basic hand tools. The worst part is the end of the pipe that goes into the motor can break off upon removal and getting the broken piece out can be tricky as you don't want to use anything that can scrape or score the hole.
Old 01-18-2016, 05:28 AM
ALGhoul
By the way can you replace plastic heater inlet pipe with previous model 97-98 model
My car say 525 model 2001 can I swap with metal pipe or it'll not fit different shape ??
Old 01-18-2016, 08:01 AM
ALGhoul
By the way from DIY I see that no need to remove the oil filter housing , throttle body , air filter , fuel injector rail
Old 01-18-2016, 12:12 PM
I'm not sure to be honest, but I believe when I was researching it I had the same discussion with someone and we decided it wouldn't work and I can't remember why.
Old 01-18-2016, 02:35 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
i wouldnt try to replace the plastic pipe with a homemade metal pipe unless you have machine capable knowledge to fabricate, it seals in with o rings and has to be made very accurately.
99 528i 5sp sport
Old 01-18-2016, 07:51 PM
ALGhoul
Thanks friend
But By the way from DIY I see that no need to remove the oil filter housing , throttle body , air filter , fuel injector rail mine is m54 engine 525 model 2001
Old 09-27-2016, 03:39 PM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
At 190,000 miles my heater inlet pipes are leaking.
Going for:
throttle body gasket (upper and lower maf boots are new)
intake manifold gasket and orings (disa is rebuilt G.A.S)
starter
ccv
dual temp switch
heaters hoses and inlet pipes (rest of the cooling system is new)
vacuum line(s) for whatever crumbles
Does anyone recommend RTV on the orings of the inlet pipes and anything else I should replace while i'm in there such as knock sensors? Thanks in advance.
Old 09-28-2016, 02:10 AM
Don't use rtv
Old 09-28-2016, 10:45 AM
Don't use rtv
Thanks for the tip, did you replace the fuel injector orings and ping knock sensors?
In NYC I doubt we'll see negative 20 degrees, but if I ever smell gas in the cabin it may be time for the updated fuel injectors.
Does anyone know how I can confirm that I get viton orings for the bottom part of the fuel injectors?
Old 09-28-2016, 10:58 AM
MKJS MKJS is offline
Mein Auto: '99 540iA
How u doing?? Hope all is well.
From what I have heard, viton is not good with fuel so don't think it would be material of choice for the fuel injectors.
Jim
Old 09-28-2016, 11:01 AM
Jim
Hey Jim thanks for the response, I'm going with Elring fuel injector orings and will hope for the best.
Someone correct me if I am wrong but I think that both the upper and lower injector orings are FPM flouride rubber.
http://spareautoparts.eu/autoparts/s...135500/ELRING/
The orings on the coolant inlet pipes seem to be EPDM (ethylene propylene diene Monomer (M-class) rubber)
http://spareautoparts.eu/autoparts/s...531435808/BMW/
Throttle body gasket is FPM attached.
Name:	throttle gasket.jpg
Old 11-12-2016, 05:55 PM
Here are some things that I learned:
When the inlet pipes break in the block, use a small flat head to pull the first oring. The second oring pulled the rest of the piece out.
If you don't want to remove the positive terminal on top of the intake manifold, then place the manifold at an angle and remove the connection at the starter.
The dual coolant temp switch has a mark that makes it easy to torque. Notice the original and line up the replacement the same way. I used a 22mm oxygen sensor wrench to remove it.
Original inlet pipes, ccv, and starter had 190,700!
Cleaned icv and throttle body. Replaced all heater hoses, inlet pipes, throttle body gasket, distribution air piece orings, intake manifold gasket, ccv, starter, and dual coolant temp switch.
ID:	581722   Click image for larger version
ID:	581723   Click image for larger version
Old 11-12-2016, 06:40 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
somethings cost a lot to repair.. even being cheap....
time is money...
perfict pic dude... prime exsample on how its done... intake swept to the side paper towel plugs not even dissconnected...
and a good shot of the cooling hose's and how that system is routed
damn that motor!
15486372<-----
