Old 08-22-2011, 08:25 AM
mad12.1964 mad12.1964 is offline
Mein Auto: 540i
AC tensioner installation
Hello…. I need some help. This weekend, I wanted to replace the hydraulic tensioner on my 540i V8 and decided to remove the assembly (tensioner and bracket ) off the engine. Now that I replaced the tensioner I do not know how to align the tensioner with the engine body. I should have marked how the tensioner aligned with the body before I removed bolt ( see red circle) close to the roller (between AC and Crack shaft). I do see a line mark on the engine (not sure if that is to align the tensioner assembly or it is there for other reason) but do not see any marks on the tensioner assembly. So my question, what is the correct procedure to put it back together?
Name:	AC tensioner image.jpg
Old 08-22-2011, 11:06 AM
cn90 cn90 is offline
This is a nice DIY by "BlackBMWs" on Zionsville Cooling Overhaul.
It should help you, see Picture #4 or so:
http://forums.bimmerforums.com/forum....php?t=1139685
Old 08-22-2011, 11:42 AM
Mein Auto: 540i
Thank you... I will check it out.
Old 08-22-2011, 11:52 AM
The first picture you posted above seems correct, at that setup, the hydraulic tensioner pushes up the most.
More info:
http://autorepair.about.com/library/faqs/bl453d.htm
Old 08-22-2011, 12:17 PM
Nice tensioner adjustment arc picture!
I had not known about the hydraulic tensioner adjustment arc, nor about the nice DIY cn90 referenced ... so ... since we don't want to lose this information ... I'll take the liberty of cross referencing this information in the canonical pictorial tensioner threads ...
- How to tell if you have mechanical or hydraulic belt tensioners (1) how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2)
BMW 740il Serpentine Belt
Q. How do I go about changing the Serpentine Belt and, if necessary, the A/C belt on my 2000 BMW 740iL?
A. First thing you have to do is take off the fan and fan coupling.
Layout of Serpentine Belt
Then loosen nuts (1) and (2), loosen and remove the Serpentine Belt.
Use hex head (1) to preload adjusting plate to end of long bore (2) and tighten nuts (3). Installation:
Fit Serpentine Belt and check it is correctly located on pulleys.
The A/C belt is as easy as it looks. Just loosen the tensioner and replace the belt.
ID:	290012   Click image for larger version
Name:	AC tensioner adjustment.jpg
Old 08-15-2012, 12:39 AM
For the record, this same question came up for the same engine in the E38 forum today:
> 7 Series - E38 (1995 - 2001) > Need Help with Serpentine Belt Tension?
Originally Posted by wes1971 View Post
I am new to this site and just purchased a 1995 740 IL. The serpentine belt was loose and trying to tighten it but it doesn't stay tightened. Any help would be appreciated. I have never worked on a configuration like this one. Thanks
Old 11-21-2013, 09:14 PM
For the record, this question was asked again today:
Originally Posted by supark View Post
I'm replacing the idler and deflection pulleys on my E39 540i, but when I checked it initially I couldn't figure out the correct way to tension the belt tensioner on the main serpentine belt. On the I-6s, you just insert a hex key into the idler pulley to get the serpentine belt in there - but there doesn't seem to be a place on the 540i tensioner. The bentley says to "turn a hex counter-clockwise".
Originally Posted by rtw_travel View Post
I can't remember exactly without looking at it - but I do remember you need a wrench and a socket. There are two bolts on the same axis - if you turn them in opposite directions, you add tension to the belt.
Originally Posted by KeithS View Post
It has automatic tensioners too. They look like little cylinders that push the idler pulleys. You loosen a nut then turn a cam about 10 degrees to unload the tension. The cam has a hex head on/in it (not an allen like the 6 cyl). At that's the case on my 2000.
Using at this convinient post as an example: http://www.bimmerfest.com/forums/sho...d.php?t=126965
Look at the idler pully just to the right of the AC compressor, Follow it down you will see the tensioner cylinder. Look near the bottom of the cylinder (near the oil pan) and you can see the cam I am talking about. The other one is pointing up between the waterpump and the alternator.
How do you apply tension to the little arm that's connected to the alternator/water pump belt though? I do see a hex to turn on the AC belt, but not on the alternator/water pump belt.
figured it out - I think. The hex you that you are referring to is the bolt holding the top of the tensioner on correct? Unfortunately if you apply too much press you end up loosening the bolt, but just the right amount will tension the tensioner correctly...
Only did this once but as I recall the bolt/nut you need to turn to add/remove the tension is welded to the plate/cam that you need to turn. This of course is after you have loosened the holdown screw/bolt. Once you loosen the the holdown screw the tension should release by itself, but you will need to turn the cam more to move the idler pully enough to get the belt off. When tightening need to hold the tension with one wrench while tightening the holddown with another.
Thanks, yeah - the bolt isn't actually welded on, but if you pivot it just the right way it'll let you tight down the tensioner arm without loosening the bolt.
I wrote this for both I6 and V8:
http://www.bimmerfest.com/forums/sho...d.php?t=213002
The principle is the same.
The rollers have 8-mm Hex (aka Allen) head. A 5/16" Hex socket is also fine.
To release the belt, scrape the inside of the bolt (dirt is inside) with a small nail or paper clip, then:
CW to tighten the bolt and to apply more pressure on the tensioner, thus releasing the belt.
CCW to remove the bolt and replace the roller.
Originally Posted by rph74 View Post
You need 2 wrenches. One wrench to tension the serpentine belt, using, if I remember it right, a 17mm socket on the "fake bolt", while simultaneously tightening the lock bolt with the other wrench.
Originally Posted by Flounderasu View Post
You tighten it as far as it will go.
Originally Posted by Calicoastin View Post
How do you know how much tension is enough? Do you turn until the belt has no more "flex"?
I have a 540i with the "shock" type tensioner.
Thnx.
If you type /tensioner F3 into the bestlinks, this comes up, which explains, in detail, with pictures, the answer to the OP's question:
- How to tell if you have mechanical or hydraulic belt tensioners (1) & how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2) & how to rebuild your hydraulic tensioners (1) & how to re-grease your pulleys and rollers (1) & the answer to the question of adjusting the 540i hydraulic tensioners' belt tension (1) (2)
Old 05-19-2015, 11:57 AM
This question came up today ...
> E39 (1997 - 2003) > Proper serpentine belt tension
Originally Posted by jolo3361 View Post
Both on mine are not hydraulic but are mechanical/spring tensioners with a Slide/slotted bracket that allows you to apply tension to the belt as the pulley wheel moves against the belt. Probably same as yours. I am assuming that I move the bracket just enough to apply moderate pressure against the belt. If I hear squealing when the engine is running I know I have not applied enough pressure against the belt. I think that will be the best approach. Any other ideas are welcome. Replacing an alternator at home without a lift is not much fun so I don't want to ruin this one.
Thanks much for the advice.
