E36 (1991 - 1999)
Old 08-20-2011, 07:25 PM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
Do what I did on accident ....unleash at 1st gear and the rev limiter should kick in at 39mph. My car thinks it idles and 1k but redlines at 9k lol and at highway speed it thinks its running at 4 or 5k
Sent from my HTC HD2 using Bimmer
Old 08-20-2011, 08:10 PM
DenKare DenKare is offline
darksilver
Mein Auto: 1995 325is
diff tags are not wrong 3.15 is stock diff for 325 5 speed its defs your tach
I like the colour No Bias.
1995 325is 5spd
Old 08-20-2011, 08:23 PM
granlund granlund is offline
Mein Auto: 2002 530i
After some digging around, I believe you have an instrument cluster from a Z3. They are the only ones I believe came without an MPG gauge and with chromed rings. If the donor vehicle was an 1.9, then you have the 4- vs. 6-cylinder rpm problem.
Old 08-20-2011, 08:44 PM
Moeman10's Avatar
Moeman10 Moeman10 is online now
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: 1992 325is
Either that or a TI, they came without the MPG gauge as well.
Its the cluster. Not your diff.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 08-20-2011, 11:34 PM
CoolStanceBro's Avatar
CoolStanceBro CoolStanceBro is online now
I6 feels good
Mein Auto: 97/4/5 Cosmos
OP...
Try this out, if cluster was bad the tach and speedo wouldn't be synchronized...
(Guys let me know if I'm wrong here ok)
97 M3, KW V2 C/O, shark injected, SS Headers, AA Exhaust, Apex Arc8s, Daily Driven, POS, Slammed!
Old 08-21-2011, 12:54 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
I think that only tests the operation of the IC, not whether it's reading correctly. It can't hurt to try it, though. Good idea, Brad.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 08-21-2011, 10:37 AM
jsdugan jsdugan is offline
Mein Auto: 1995 325ic
Good and Bad news
Good News: The car really stumbles at 1,000 rpm's when I tried to stay in gear or engage 1st, 1,000 rpm's would almost cause it to stall. AND, THE BIGGER DEAL - I tried red lining it, and it was going well past 7,000 and I didn't keep it going any more to the rev limiter because I figured I got my answer about the tach being wrong. So, is there any way to adjust it so I can have the correct reading (swap a gear in the tach?).
Bad News: This means my instrument cluster must have been swapped out at one time, so the 111,000 miles that I thought I have on the car is completely inaccurate. I know almost everything on the car except for the aluminum radiator seems stock. Shocks, struts, bushings, possibly even spark plugs.
So, I will run it a while a check the mileage to see how it goes. So will I be able to get the tach accurate? Thanks!
Old 08-21-2011, 11:02 AM
Carfax?
Does anyone have the ability to run a carfax for me? I am curious if the odometer swap, or whatever happened, shows up on it. My VIN is: WBABJ5325SJC82388
The report could be sent to jsdugan@gmail.com if someone is able to do this.
Thanks!
Old 08-21-2011, 11:08 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
You'll have to swap the clusters to get an accurate tach. They can be had for around 100 bucks, and arent terribly hard to install
RIP Ben "Jever" Doebele, we wont forget you
Hi, I'm Chad. Talk to me or GFY
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things!
1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Old 08-21-2011, 01:33 PM
Moeman10's Avatar
hookersandblow
Thanks!
No, that's illegal.
Old 08-21-2011, 02:14 PM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Originally Posted by drive by72 View Post
You'll have to swap the clusters to get an accurate tach....
Huh? What about the standard procedure of coding the cluster to match the car (and engine)?
Old 08-21-2011, 06:04 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
I don't think you have to code the cluster at all. You just need one with the same mileage.
-CJ
Old 08-21-2011, 06:07 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Only certain E36s came with codes you can swap, do a search on bimmerforums and it will show you.
I would just get a cluster with around the same mileage.
Turbo Build Here
Parting Out Complete 96 328is
Old 08-21-2011, 06:47 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Except that he has no clue what the milage is now. He wasn't the one who swapped the clusters.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 08-21-2011, 06:52 PM
cj.surr's Avatar
some kid
Well, since there's no tamper dot, we would assume the mileage on the cluster is correct, right?
-CJ
Old 08-21-2011, 06:55 PM
jonesin's Avatar
The Canadian Prick.
The tamper dots weren't in all years. I don't recall what year they started off the top of my head.
Old 08-21-2011, 06:57 PM
cj.surr's Avatar
some kid
Then what stops people from throwing in clusters with lower mileage?
-CJ
Old 08-21-2011, 07:08 PM
What is this tamper dot thing? I just bought the car, so I guess I don't have a clue how many miles are actually on it. So, there is a chance I can reset a z3 tach, or whatever instrument cluster I have. I am guessing that I just need to live with it.
Old 08-22-2011, 03:12 PM
Just drove 200 ish miles and got 25 mpg with doing about 30% at 67, 55% at 57, and 15% in town. Oh, about 80 miles were with the AC on. Not the greatest, but I am sure the plugs are old and could use a tune up. The bad idle got a little better throughout the day, at first it would die if I put it in neutral and idle while slowing down, but throughout the day it got a little better.
Old 08-22-2011, 04:50 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
25 isnt bad at all, except i get that going 85
Old 08-22-2011, 04:57 PM
So, besides the plugs and valve cover gaskets (which I am pretty sure don't have anything to do with mileage) , what should I replace for better mileage? The factory type air cleaner looked pretty clean.
Sent from my ADR6300 using Bimmer
Old 08-22-2011, 05:02 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Pretty much the basics. Plugs, fuel filter, air filter, ensure good tire pressure, shift before 2500rpm while driving, coast as much as you can and use brakes only when you need to, etc.
Old 08-22-2011, 05:08 PM
Shift before 2,500, ha! Remember what my original post was about I may be dogging it a bit too much if I try that on my tach. I was surprised to see how cheap, and easy (I think; might be wrong), the fuel filter will be.
