Old 08-22-2011, 10:35 PM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
"Hydraulic" Accessory Drive Belt Tensioner Rebuild DIY.
Begin by removing the dust cover from the tensioner pulley and it's pivot bolt.(missing on my example motor :/ ) The dust covers are Pivot PN 12 31 1 713 143 and Pulley PN 11 28 1 727 159
There should be a black plastic cover here.
Under the tensioner pulley you will find an 8mm allen bolt that holds on the tensioner pulley.
http://farm7.static.flickr.com/6188/...1ceba3d643.jpg
While removing this 8mm allen be sure to support the arm from extending past it's stop. I used a wrench I had handy and gently pressed down while breaking the 8mm loose.
Here are the parts of the tensioner pulley laid out in order of removal from right to left. Take note of rear dust shield that normally resides behind the pulley.
Now that the pulley is removed you can access the three 13mm bolts that hold the tensioner assembly onto the oil filter stand.
2 of the bolts to remove the assembly are fairly obvious. (bottom of the hydraulic spring and at the pivot of the tensioner arm) the third is in the shadows while mounted on the block but is pointed out here by the authors finger.
Here is the tensioner assembly brought over the the work bench for rebuilding.
This spring assembly needs to be compressed slightly for further disassembly. I'm fairly certain you could use a large "C" clamp for this but I used a large bench vise.
Once the spring is compressed the pivot portion will slide right out.
Here are those pesky needle bearings we're in here to service. (PN 12 31 1 713 153 if yours are damaged beyond repair)
I uses brake parts cleaner and a small brass cleaning brush to clean the old grease and rust out of these bearings. (hence the rust colored solvent running out)
The best way to get the bearings rotated is with a finger, so you can get all that old grease out.
Also clean up the pivot arm itself, I use light 1200 grit sandpaper to remove light pitting if necessary. It should look like below when done.
If the pivot base plate is damaged or seriously pitted like in the image below it should be replaced. (PN 11 28 1 726 744) The faint lines are where an improperly lubricated bearing assembly has damaged the pivot itself.
Heres the grease I've used on these for years, it seems to hold up well but it will be a few more before I can tell you if it was any better than stock. Axle grease would probably work well in this application as well.
Work your chosen grease into the now cleaned bearings until they are well greased.
Now is a good time to inspect the oil damped spring for damage to it's boot or binding of its movement. if it binds or has a damaged boot a replacement can be ordered. (PN 11 28 1 717 188)
Then return to where you left your compressed spring and reassemble the pivot to the spring and remove it from the vise. (or "C" clamp.)
That's it the tensioner is all ready to return to it's home on the motor.
Once the tensioner is bolted in place now is an excellent time to install a replacement tensioner pulley. (PN 11 28 1 748 131)
Don't forget to reinstall the dust covers.
Please PM me if you find any errors that need correcting. With this maintenance the belt drive should be good for 120k or so until the needle bearings need servicing again and 60k until it needs a belt and the tensioner and idler pulleys again.
Happy Motoring,
Bimmerteck
Old 08-22-2011, 10:42 PM
BMW Magician
Reserved for future belt drive rebuild shenanigans.
Old 08-22-2011, 10:50 PM
An instant classic!
I'll cross reference to one or more of these threads so it can more easily be found in the future...
- How to tell if you have mechanical or hydraulic belt tensioners (1) & how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2) & how to rebuild your hydraulic tensioners (1)
Old 08-23-2011, 06:53 AM
cn90 cn90 is offline
Thanks bimmerteck,
For the most part we (including myself) simply replace the hydraulic tensioner and the pulleys without looking at the needle bearings!
Thanks for sharing this cute trick, it will be on my list at the next tensioner/pulley maintenance.
I think the needle bearings move very very little, this maybe why it is rarely an issue in these cars.
Unless as you said before, this comes from a junkyard engine that is left exposed to the element!
Old 08-23-2011, 07:09 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Nice! Hoping this will save me some money when I finally do my pulleys.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 08-23-2011, 07:15 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Very good write up Nice attention to detail.
I would add this though, If it is needed to replace the damper it may be wise to look at the entire kit which comes with the damper,pulley,mounting plate and swing arm as well as all bolts and dust cap.(basically the entire assembly) for right at 100.00 compared to just the damper that is around 55-60 by itself.
Max
Old 11-06-2014, 04:58 AM
There is good information on the hydraulic tensioner pulleys over here today:
> E39 (1997 - 2003) > This just happened, belt splip out!
Originally Posted by theWalkinator View Post
Just find out that I can use Dayco 89144 or 89052. 89144 is 25 mm wide and is plastic, 89052 is 27 mm wide and is steel. I probably go with 89052, price wise are not much different, $16 ~ $17 depends where you go, but I need 3 and store availability is usually 1 or 2 so I might buy from more than 1 store. Stock roller size, Outer diameter 70 mm, inner diameter 17 mm, width 27 mm.
Old 11-06-2014, 10:32 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
It is information, one can debate if it is "good". Dayco pullies are not of high quality. Not recommended. It would be preferable to use the factory INA pullies, and as was stated by the sponsor above, it is probably a "wash" to simply buy the complete assembly from INA, with new pullies and tensioner, rather than buy the INA parts individually, or attempt servicing individually. If one enjoys the time and servicing, that is one thing. But if you are in a hurry or paying someone, simply swapping the assembly is probably worth the few more dollars over buying individual parts and then taking the assembly off, taking the assembly apart, reassembly and then installing.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
