Old 08-23-2011, 10:30 AM
blackandcoke's Avatar
blackandcoke blackandcoke is offline
New York
Mein Auto: 528IA
Thermostat,Fan Clutch,Bleed Screws... Finally
Reason for this post.. I want to know if I miss anything to complete my cooling overhaul final steps below is a list already DONE at 85k The pic's below are the final thermo and fan clutch installed. NOTE if your fan clutch makes that (((LOUD))) blowing noise everyone is talking about change em BIG difference better pick up and smoother ride and i do feel like im saving a little on the MPG side.
00(E39)
Radiator BEHR
Upper and Lower Hoses OEM
Expansion Tank OEM
Brass Bleed Screws
Water Pump BOSCH
Thermostat BHER
Fan Clutch SACHS
Conti BELTS
Pulley's
Old 08-23-2011, 10:36 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
The Plastic Fan Blade....replace it at 120-130K or so (BMW Only!).
Otherwise you are good to go.
Old 08-23-2011, 11:42 AM
New York
Mein Auto: 528IA
Thanks! will do down the line..now i can sleep in peace
Old 08-23-2011, 11:45 AM
Also the WP Pulley (BMW only), replace it at 120K or so.
Old 08-23-2011, 04:29 PM
ElwoodBlues ElwoodBlues is offline
Mein Auto: 2002 530i Sport
Just curious, what's the logic behind 'BMW only' for the replacement pulley? Or why replace it anyhow if it shows no signs of wear or cracking?
I'm gather my cooling overhaul parts this week, and I "splurged" for the BMW fan, but I think I overlooked the pulley.
Old 08-23-2011, 05:28 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Bearings: made in China vs made in Japan or USA.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 08-23-2011, 05:40 PM
Joe@Bavarian Joe@Bavarian is offline
Mein Auto: Me - E39 5spd, Wife - E36
+1
You are better off repacking the bearings on a OEM BMW then buying a new China one.
Repack OEM = (small automotive pick, remove the rear bearing cover, clean with parts cleaner, inspect the balls for pits and/or bluing, if good then repack with high temp grease, replace cover - it snaps back on)
Old 08-24-2011, 05:50 AM
poolman poolman is offline
Mein Auto: 525i station wagon
You missed your Vanos seals rebuild pack and valve cover gasket kit.
Old 08-24-2011, 06:36 AM
Huh? I think we're not all on the same page here. The water pump pulley is just a pulley, no bearings involved. It bolts to the water pump, which I assume has internal bearings, but that is already being replaced as a unit. I'm only asking why / why not replace part #8:
Old 08-24-2011, 10:29 PM
I will reference this, since it has nice pictures to the thread:
- List & picture of all the cooling system overhaul parts to replace (1) (2) (3)
The OP might also wish to see:
- Recommended parts list for a complete belt drive system overhaul (1)
And ...
- Typical tandem DIY repair jobs combined while you're already there (1)
Old 08-25-2011, 10:27 AM
New York
Mein Auto: 528IA
Thanks! I did the Vanos awhile ago along with gaskets and plugs...
Old 08-25-2011, 11:12 AM
Originally Posted by ElwoodBlues View Post
Huh? I think we're not all on the same page here. The water pump pulley is just a pulley, no bearings involved...
LOL,
Whenever we mentioned the word pulley, it makes these guys excited ha!
ElwoodBlues is right, we are talking about the WP Pulley, which is a piece of Plastic (special plastic).
This is a crucial part, if this part goes bad, it creates thousands of dollars of damage!
So stick to BMW or if you can find Aluminum Pulley, go for it.
