E34 (1989 - 1995)
Old 08-24-2011, 09:24 AM
Jamafia's Avatar
Jamafia Jamafia is offline
Mein Auto: 95 BMW 525i
Unhappy My baby have engine noise (sounds bad)
Another issue i need gone. knocking, clicking noise coming from engine.
It only happens when engine warm, normal running temp.
Old 08-24-2011, 09:51 AM
ricks5series's Avatar
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette
Sounds like sticky lifters to me. Run a quart of diesel fuel in your crankcase but DO NOT DRIVE IT, just let it idle for about 15 minutes then immediately change your oil. Worked for me. If you drive it with the diesel fuel in the crankcase you'll surely spin a bearing. So once again, just let it idle. If it's still present I'd check into rebuilding your VANOS unit as the steel washer becomes worn and loose creating a sound similar to what we are hearing. Good luck!
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Hey Jamafia. Congrats on getting her running again.
I'm almost 100% positive that is your vanos unit knocking. How long has the car been down? Have you checked the oil level? I had the same noise on my E36 after it had been down for several months. After running it gently for about 30 minutes, the noise went away.
Hope this helps.
Steve
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-24-2011, 10:40 AM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
Make sure your oil level is right.
///////////////////////////////////////////// E34 Addicts
Old 08-24-2011, 05:45 PM
5IVE 5IVE is offline
Mein Auto: 94 525i
Sounds like your engine is starved of oil (top) there a lot of lifter noise there...have your oil pump check including what others have listed as possible issues. Oil pump will run you somewher in the neighborhood of $325 - $375. I would also run some "SeaFoam" through the crank-case...
Old 08-24-2011, 08:17 PM
aspenpup aspenpup is offline
Mein Auto: '95 525i '05 X5
That's funny, I thought it was supposed to sound like that!!
You make me nervous now, I need to look into my sound issue on my '95 525i.
Old 08-25-2011, 11:18 AM
Jamafia's Avatar
Thank again friends another problem solved. You know what, the car need oil.
The last oil change at shell service station, i don't think they knew what they were doing or how much oil goes into engine. I will be taking it from now on to bmw specialist.
Thanks for all your opinions / thoughts.
Old 08-25-2011, 11:55 AM
jfs356's Avatar
jfs356 jfs356 is offline
Mein Auto: 1994 530i
Our cars take more than the normal 5 quarts, so yes an oil change shop might not know the right oil numbers and assume 5 quarts.
bmw, clicking, engine, knocking, noise
