help me please !!!!!!!!!! - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 08-25-2011, 04:14 AM
bst92 bst92 is offline
Mein Auto: 325i e30 1989
Exclamation help me please !!!!!!!!!!
hey everyone
i recently tired putting 17 inch rims on my 89 325I e30 but they wouldn't fit at the front due to the fact they were hitting my front struts ! any ideas of how to get past this ? or a place to get rims that will fit ?
i would need the offset and all that would be much appreciated.
btw i live in australia
thansk bst92
Old 08-25-2011, 08:59 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Try this:
http://www.willtheyfit.com/index.php...&Submit=Submit
BTW, 17s are too big
I Timothy 2:1-2
Old 08-26-2011, 03:21 AM
do you know of any website or rims that will actually fit ? maybe a set of 16's ??
Old 08-29-2011, 05:23 PM
nomansland92 nomansland92 is offline
Mein Auto: E36 325i 1993
there lots of rims that fit, Next time pick a lower offset like et30 to et20 should all fit, if you go much lower you'll probably have the roll the fenders. Or run spacers and longer lug bolts with you current rims that didn't fit, you can fit 17's but with limited tire size options, 16's are the best way to go.
Also make you you get the right hub bore and use hub centric rings if needed
Old 08-30-2011, 03:28 PM
downhiller's Avatar
livin large
tirerack.com. they give you a good idea of what offset and tire size youll need
e30 325i, rims
