E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#26
After I've completed the repair, I'll post my findings.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket |
#27
Thanks very much. Although I suppose all it would take is to get access to the reverse light (anybody know if this should be done from the outside by removing the lenses, or from inside the trunk by removing the paneling on the inside of the trunk lid?), and matching up the wiring there with what's in the bundle, right...?
#28
That would solve ONE problem but not the BIG PICTURE.
![]() G. P. Burdell and I were talking about adding value to the big picture by identifying ALL the wires on the E46 (just as we did on the E39). Once that happens, it's much easier to determine which problems can be related to the trunk loom - and - which will have no bearing on the trunk loom. It almost never makes sense to solve the little picture ... that's the whole point of the forums ... to increase knowledge and add value in every post! Good luck! |
#29
#30
Thanks, that helps a lot.
#31
Update:
I finally found the time to rebuild my car's trunk wire harness. I say that I rebuilt the harness because, once I was done, there wasn't much left of the old harness. Here's my writeup for anyone wanting to do the same. Introduction This work took me an entire day from start to finish. I will readily admit that I'm not the fastest DIYer; I frequently stop and take the time to document the process with written notes and plenty of photographs for future reference. On this task, I checked and re-checked my work several times to make sure I spliced the right wires to each other. These checks involved numbering the wires and testing for continuity, both in the car and on the bench. The temporary repair I made about a month ago held just fine, but I had to make an inline splice right in the area of the harness where the original ground wire had broken. The splice would eventually have broken, or it would have chafed against the other wires in the harness (one of which was looking rather kinked already) and caused more damage. Furthermore, in order to find the broken wire, I had cut into the existing corrugated EPDM rubber cover that protects the harness and seals out water. I wasn't able to locate a complete replacement harness in the BMW parts catalog, so I decided to replace the entire wire bundle that passes from the body to the trunk lid. Disclaimer I AM NOT A BMW TECHNICIAN. I am sharing my experience based on the repair I made to my E46 sedan. Depending on the year and configuration of your vehicle, your car's wiring may vary. I will not be responsible for any damage or injury that results from following anything I have posted in this thread. Verify part numbers before you purchase your own materials. It is your responsibility to also verify technical information with a trusted source, such as BMW TIS, your copy of the Bentley Publishers repair manual, or a reputable mechanic. If you are not comfortable with doing this work on your own car, I recommend that you seek the assistance of an experienced friend or your mechanic. Use appropriate safety measures and have proper ventilation when working with heat shrink materials inside the trunk. As always, you are welcome to do things differently and discuss your method here. Materials Most of these products, except for the ones with BMW part numbers, are available from vendors such as McMaster-Carr.
Tools
The Process The basic steps involved were:
Observations
Whew! That was a lot of work, but now I have all new wires passing from the body to the trunk lid. We'll see how long the new bundle and its tougher-than-regular-PVC insulation lasts. BMW could make this repair a lot easier and more convenient if they would produce and sell an affordable replacement harness like they did for the E36.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 02-09-2011 at 05:11 PM. |
#32
This is a lovely trunk loom wiring harness DIY!
Thank you for taking the time to write it up so well for the rest of us to enjoy! Quote:
As documented in that thread, I even called up local BMW dealerships and asked if anyone orders the appropriate harness; they said no. I asked the forum if anyone replaced the entire harness (stock OEM), and nobody said they did. Almost all of us (including me) fix it ourselves ... but (and this is what perplexes me), certainly SOMEONE must be going to the dealer to find the cause of the electrical gremlins that occur when the trunk wiring frays. Q: What is the DEALER doing (are they replacing the entire harness)? Thanks for that hint. I had asked (post #48 over here) what wire size to use and didn't get a decent answer. Quote:
Not everyone agrees, but the evidence is showing that the insulation is cracked and pulled apart by a couple of millimeters. Some wires are broken but most are simply missing a length of insulation. So, if true, the solution "might" be slightly longer wires. |
#34
Thank you!
http://www.realoem.com/bmw/showparts...05&hg=61&fg=10 RealOEM shows a ~$160 harness (No. 4 in the diagram below) for the E39 - is it a complete replacement harness, or would that be the $1,300 one? http://www.realoem.com/bmw/showparts...35&hg=61&fg=10 So far, I don't know that there is a dedicated repair kit for the E46. I guess it depends on whether BMW NA and the service departments across the country have determined that this is a necessary repair kit. Hopefully, BMW NA will begin to stock them for the E46 as the last coupes start to show signs of wiring damage. Quote:
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 02-11-2011 at 03:30 PM. |
#35
I'll ask that question over in the E39 side of the house. - E39 Electrical Problems Traced to Trunk Lid Harness Wire Chafing (DIY Diagnostic) E46 owners can answer it here also. PS: I think my DIY is more of the "how not to repair your trunk loom" because I flubbed up in a lot of places with ugly results! ![]() |
#36
Q: WHAT is the fundamental problem with the BMW wiring harness? Just curious ... do you think these 'clues' support the excellent hypothesis above? Last edited by bluebee; 07-28-2011 at 09:08 AM. |
#37
If the problem is caused, as some have suggested, by excessive tension on a harness that's too short, then why do all of the wires seem to break at the same point? They're breaking there because that's where the bundle folds every time the trunk is opened and closed. I think the more constructive question than "what's the mode of failure?" is "what's the practical way to fix it?" I hope my discussions of materials and methods have been helpful in this regard. The average 'Festers probably are a little bit curious as to why it happens, but they'd also like to fix the problem as efficiently as possible and go on with their lives. Also, since we're in a thread I started, I'll give a brief update and say that the new wires are still going strong six months after I rebuilt the harness.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 07-28-2011 at 10:08 AM. |
#38
Bumping up an old thread: http://realoem.com/bmw/showparts.do?...37&hg=61&fg=10 is #3 a replacement harness for this? Or is that something else?
Thankfully my wires are still good, but I'd really rather not go through the trouble of rewiring it myself when the time does come. Any suggestions as to what can be done to relieve the stress?
Short of never opening your trunk, I'm not sure that anything can be done to relieve the stress. The wires have to unfold and fold every time you open and close the trunk.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 08-31-2011 at 07:10 AM. |
#40
Since you can't relieve the stress, would it make sense just to wrap electrical tape over the wires to help reinforce them and help prevent rubbing?
John "jr" '06 Cic ZHP, Southern California ![]() ZHP Performance Package, Cold Weather Package, Leather, Jet Black/Black/Black Cube Active Autowerkes Tune, Sprint Booster, BMW Performance Air Intake DICE Ipod, Parrot/Connects2 Bluetooth, StealthOne Valentine Module BMW Performance Strut Bar, Orion V2 Angel Eyes, No-holes License Plate |
#41
That's why the maker uses fabric tape instead. Longer lasting and doesn't gum things up as bad as deteriorated vinyl tape.
All old cars develop the 'bad trunk harness wiring' sindrome. No escape. In my old Fords, I've had lasting success by wrapping the harness in rubber self-amalgamating tape. After a day or two, it fuses into a seamless rubber 'tube' that closely encases and protects the wires. The UK-made MotorMite brand I find at AutoZone is reasonably thin and doesn't increase harness diameter too much. Don't know if a harness wrapped like that could be teased thru the trunk access holes and rubber hose in the Bimmers.
2006 325Ci |
#42
The fabric tape makes quite a mess, too, when its adhesive breaks down. Taking the old harness out and marking the wires was a sticky PITA.
#43
Bump
I got this problem today! Where do I start on this This the wiring harnes on the right side? How much would this cost me if I were to take it to a dealer or an independent mechanic?
BMW<3 |
#44
Yes.
If you get a repair quote from your local dealer, be sure to find out if they will replace the entire harness with a new one, or if they just plan to splice new wires into the existing harness. It's hard to tell from the parts diagrams whether there's a replacement harness available at a reasonable price.
#45
I stickied this thread based on the potential hazard involved and that this is the type of thing that ought to be highlighted as the population of E46s ages (gracefully, of course.
Hope that is ok with the OP. |
#46
No problem. I'm just happy to have created a thread worthy of sticky-ing.
#47
So my first step is to open the black thing where the wires are and then see what wires went bad. Then what type of wire should I get at autozone?
BMW<3 |
#48
Local auto parts stores don't stock the wire you need for a lasting repair. My rebuilt wire harness is made from XLPVC-insulated wire sourced from McMaster-Carr.
#49
On the way to work this morning, the trunk open indicator lit up on the dash. When I arrived at work, had to manually open the trunk with the key. I pulled open one end of the rubber cable cover on the wire harness in the trunk and saw that the brown wire was broken.
I think I'll just temporarily patch together the broken wire this weekend and start ordering the wire to build a replacement harness.
Follow me once, follow me twice, follow me on Twitter |
#50
So did you patch it?
Update us
BMW<3 |
| Tags |
| license plate lights, reverse lights, trunk harness, trunk lock problems, trunk wires |
