F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#26
So this 'driver experience control' and ECO PRO are something new for 2012? Is that what's driving the 2k base price increase?
____________________________ 2012 535i X-Drive | Imperial Blue Metallic w/ Everest Grey Dakota Leather | Sport Package | Sport Automatic Transmission w/ Paddle Shifters | Cold Weather Package | Driver Assistance Package | Premium Package | Technology Package | Head-up Display | Active Cruise Control | BMW Apps |
#27
dynamic damper control and dynamic driving control for more sportiness you should add ARS (active roll stablilization)
![]() 2008 328i dark graphite ,cold weather pack,USB/ ipod/black leatherette SOLD hers: 2009 X5 alpine white, dakota tobbaco leather,sport, DHP premium pack |
#28
auto start-stop floor mats driving dynamics with ECO pro ambiance ligthing BMW assist bluetooth bmw teleservice IPOD adaptor/Combox
#29
Thanks man.....but what exactly is the "auto start-stop"?
#30
the car's engine will turn itself off-on to save gas
A clever way to save fuel: the Auto Start Stop function turns off the engine each time the vehicle comes to a complete halt - such as at traffic lights - and restarts it automatically. A reduction in fuel consumption is the result. The principle is simple: if the engine is not running, it cannot consume fuel. The Auto Start Stop function turns off the engine whenever it is not needed. In a traffic jam or in stop-and-go traffic, simply putting your BMW into neutral and taking your foot from the clutch will activate the function. "Start Stop" on the Info Display signals that the engine has been turned off. To set off again, just put your BMW back into gear: the moment you depress the clutch, the engine immediately springs back to life and you can drive on without a moment's delay. Driving comfort and driving safety are not affected by the Auto Start Stop function. The function is not activated, for example, until the engine has reached the ideal running temperature. The same applies if the air conditioner has not yet brought the cabin to the desired temperature, if the battery is not adequately charged or if the driver moves the steering wheel. The Auto Start Stop function is coordinated by a central control unit that monitors data from all relevant sensors, the starter motor and the alternator. If necessary for comfort or safety, the control unit will automatically restart the engine: for example, if the vehicle begins to roll, the battery charge falls too low or condensation forms on the windscreen. Furthermore, the system also recognises the difference between a temporary stop and the end of the trip. It will not restart the engine if driver's seatbelt is undone, or if the door or bonnet is open. If desired, the Auto Start Stop function can be completely deactivated with the press of a button. When used consistently, the Auto Start Stop function delivers significant reductions in fuel consumption and CO2 emissions.
#31
one part comes standard on 2012 , one part comes from 2012 sport package and other part is a option... I seriously hate BMW package system they make to many mandatory/dependencies and too much confusing ... what is the point. |
#32
#33
If you check Audi configuration its pretty simple...i think they are screwing it up in the name of flexibility. |
#34
Sort of, - There are more items standard, including the Driving Dynamic Control that gives user control of accelerator response characteristics, engine response, the power steering characteristics, the Dynamic Stability Control (DSC) thresholds and, on automatic models, the shift characteristics of the transmission. I believe some of this was available with 2TB - Sport Auto Transmission, but some may have been part of 2VA - Adaptive Drive that cam with ZDH package. - The "Sport" elements have mostly just been re-factored. --Below holds for 535i-- For 2011, The $2,200 Sport Package (ZSP) was more cosmetic: - 255 Sports leather steering wheel - 2K3 19" Light alloy V-spoke wheels style 331-with performance run-flat tires (19x8.5, 245/40 R19 front and 19x9.0, 275/35 R19 rear) - 456 Multi-contour seats - 760 Shadowline exterior trim - 840 Increased top speed limiter The $2,700 Dynamic Handling Package (ZDH) gave you the configurability and adaptive control: - 223 Electronic Damping Control - moved to ZSP for 2012 - 229 Active Roll Stabilization (ARS) - 2VA Adaptive Drive For 2012, The $3,600 Sport Package (ZSP) now adds 223 - Electronic Damping Control from the 2011 ZDH option From BMW brochure, DDC "instantly adjusts shock absorbers from the softest to the firmest settings. The result is exceptional ride comfort and fluid handling at all times – during changes in vehicle speed, load or road and driving conditions." - 223 Dynamic Damper Control *new* - 255 Sports leather steering wheel - 2K3 19" Light alloy V-spoke wheels style 331-with performance runflat tires - 456 Multi-contour seats - 760 Shadowline exterior trim - 775 Anthracite headliner - 840 Increased top speed limiter For 2012, the ARS option for $2,500 includes both ARS and 2VA Adaptive Drive. Ths is the same as the 2011 ZDH package, except 223 has been moved to the Sport Package: - 229 Active Roll Stabilization (ARS) - 2VA Adaptive Drive So, the full sport and adjustability options went up $1,200 for 2012 ($4,900 -> $6,100) |
#35
Sorry, but I can't seem to find where 4UR is listed. Can you help me out? Thanks.
Prod Date 4/5/12, ED: 4/19/12, Redelivery 6/20/12, 535xi, TiAg on Gray Dakota, Anthracite Wood, Cold Weather, Premium Pkge, Tech Pkge, Side and Top Cameras ED: 2007 530xi, Monaco Blue on Gray Dakota |
#37
4U2 is Driving Dynamics Control w/ ECO PRO - standard on 528 & 535 4UR is Ambiance lighting - now standard on all 5-series This is from the ordering & pricing guides the OP posted in the Ask-a-Dealer section: http://bimmerfest.com/forums/showpos...7&postcount=34 He also linked to that post in post #5 of this thread. |
#38
Thanks very much. This is great.
#39
So what is the best way to order a 2012 BMW 535i with M sport trim? Do I go to a dealer and order it or is there a better way. Sorry for the newbie question.
#40
first you need to choose the color and specs the go to bmwconfig to customize it and get the invoice time to negotiate from invoice, 2-3 dealers ( loyal credit, nav credit ) choose the best offer ( dealer ) order the car to your specific specs wait 6-8 wks for the car to arrive
![]() 2008 328i dark graphite ,cold weather pack,USB/ ipod/black leatherette SOLD hers: 2009 X5 alpine white, dakota tobbaco leather,sport, DHP premium pack Last edited by jondoc72; 09-06-2011 at 03:24 PM. Reason: revise it |
#41
I just can't understand why BMW altered the 2011 5-Series Dynamic Handling Package and the Sport Package. They have made it more complicated and surrepticiously increased the price of buying both at once.
Deciphering the 2012 set-up, it appears that one can buy the sports package ZSP without Active Roll Stabilization ARS but you can't buy ARS without ZSP. This doesn't make any sense. The ZSP is meaningless without ARS. There is confusion over what comprises Adaptive Drive. I initially thought that it is an umbrella term for combining Active Roll Stabilisation with Dynamic Damping. Yet the PDF stated that ARS is bundled with Adaptive Drive. I would be relieved if anyone can succinctly explain what Adaptive Drive is. Furthermore does anyone know whether one can attain the Sport Packkage ZSP without Shadowline trim? I prefer cars that present a chrome trim. This brings out the Hoffmeister Kink and is a beautiful site especially against vivid dark paint. I don't see how making the car look sporty has anything to do with Shadowline trim. |
#43
#44
nav credit is currently ongoing for sep-oct 2011 // applied to the following 2012 models (535i, 535xi,528i, 528xi) is 1,730.00 off the purchase price this credit is not available for the 550 models before negotiating with dealers: - if leasing , do your homework and learn well how leasing works - negotiate over the invoice and not from mrsp - do get the price for at least 3 dealers . - better to deal from internet (e-mail, over the phone, instead of going in person to the dealership, you will love the car and pay wathever they ask you // I did a couple of test drives before the purchasegood luck!!! PM me for more info if needed
![]() 2008 328i dark graphite ,cold weather pack,USB/ ipod/black leatherette SOLD hers: 2009 X5 alpine white, dakota tobbaco leather,sport, DHP premium pack Last edited by jondoc72; 09-15-2011 at 04:29 PM. Reason: corrections |
#45
There isn't enough info on differences between 2012 MY 535i and 550i. If we talk about 2011; it was obvious that BMW was subliminally encouraging customers to buy the 550i over the 535i. The msrp shows a $10000 difference in base prices but when one looks deeper, it is clear that the 2011 550i came with many more desirable standard features eg navigation, leather upholstery, ambient lighting, park distance control, 100% chrome grill etc. There is $5000 worth of standard features. This means that the net cost difference is only $5000 and it is worth it to attain the mighty 550i engine.
The 550i is not just faster from a stop. It has far better passing acceleration in the important bandwidth 25 - 70mph. This is very handy when overtaking an obstructive truck on the highway. Cosmetically the 550i looks better. The trapezoid exhaust tips give the car balance. The cylinders in the 535i look too skinny for the car! |
#46
Drive dynamic control
Where does one find information on this? I do not see it anywhere on the bmwusa website for the 2012 535 xdrive. I agree that BMW packages just kill ya. Dealers seem to have a 62k ideal price point on their inventory. Thus I've seen a 2011 sport without sport tranny so no select buttons. I would forgo the sport in a 12 if there was some button to adjust throttle etc like ddc standard
#47
Ordering 2012 BMW 528xi - need help
Hi I just spoke with a dealer about ordering a 528 xi 2012 model with premium package, technology package, and cold weather package, metallic paint, and leather. MSRP on this configuration is $55,900. His offer is $50,800. Invoice he claims is $51,500 after the $1,730 credit for NAV.
Is this a good price? Any advise? New to forum and this will hopefully be my first BMW. Thanks
#48
2012 535i Alpine White | Oyster Black Dakota Interior | Painted Calipers, Reflectors & Black Gloss Grill | Born on 1/30/12 Gre8tW8LL |
#49
CA told me a couple of weeks ago that the Driving Dynamics with EcoPro is standard.
#50
2012 528i or 2011 535i
Bimmer experts.
I am currently negotiating to buy a 2011 535i demo model from my local dealer. I have driven the 2012 528i and am confused on what to do. I like the 4-cyl engine although the savings in gas is not the most important factor to me. I am by far not a BMW expert like some of you. What do some of you recommend? go for the 2011 535 demo or 2012 528?? I know if i wait for the 2012 535i, the deal wont be as good as with the 2011. Any suggestions?? Eric- |
