Old 09-05-2011, 07:03 AM
bimy550 bimy550 is offline
Mein Auto: ML550
Do I need wheels aligment?
Hi everyone,
My 550i just past 6000 mls, on the way to work I hit a big pot hole on right wheels now the vehicle pull to right, not happened before hit.
Do I need wheels alignment or balance the tires?
Thank you.
Old 09-05-2011, 07:07 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Probably not balance but maybe alignment. Also could have a bubble assuming you have run flats and maybe loss of air pressure.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 09-05-2011, 07:16 AM
Mein Auto: ML550
Can I do aligment at NTB?
Old 09-05-2011, 07:24 AM
laser's Avatar
Sure, I've had good luck with them over the years ....... but make sure they check out other possible damage, it sounds like you took quite a whack to the right front tire!
Laser
Old 09-05-2011, 12:54 PM
richschneid richschneid is offline
Mein Auto: 2015 i8 Tera World
Hi everyone,
Thank you.
No question it is the alignment. Had to align my car for similar circumstances. Had it done at the BMW dealer. It is a totally new rear suspension and requires all four wheels to be aligned. Did it with the technician and it took more than two hours. He had to redo the rear wheels because the process of doing the front wheels the rear came out of alignment. He said the F10 requires a lot of work and he is just getting used to it. It requires the sophisticated dedicated BMW computer assisted alignment machine. Costs about $200.
Do NOT get it done anywhere but a BMW dealer. He will check all the tires at the same time.
2015 i8 Tera World Protonic Blue
Old 09-05-2011, 02:21 PM
GeneJ GeneJ is offline
Mein Auto: 750i xdrive
I agree, I have F01 and the new suspension has to be done at a BMW dealer.
Old 09-05-2011, 04:06 PM
Mein Auto: ML550
Thanks all,
I will let BMW dealer do alignment and oil change tomorrow.
