Old 09-06-2011, 07:18 PM
shawnshaw shawnshaw is offline
Mein Auto: 745il
Angry Parking brake wont release
my parking brake wont release and I can not finf the emergency release tool anywhere in the car. Can I buy this part from BMW?
Old 09-06-2011, 07:24 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Did you look under your dash below the steering wheel? Thats where its located.
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 09-07-2011, 08:58 AM
grtwht's Avatar
grtwht grtwht is offline
Mein Auto: 2008 750Li
The parking brake release tool is in the trunk tool kit - it's a long, thin metal rod at the top of the trunk toolbox thing.
Right in front of the spare tire there is a hole you stick it in and turn it until there is resistance (you're sticking it into the parking brake actuator by doing this).
2008 750Li
Old 06-24-2015, 06:37 AM
eliguh eliguh is offline
Mein Auto: 2005 bmw 745i European
Did you ever find out where you could get the emergency release tool from? Could you get it from the dealer? If so, how much was it?
745i, brake, parking, release tool
