2008 Glove box trim repair? - Bimmerfest - BMW Forums
Old 09-07-2011, 07:28 PM
jwchi jwchi is offline
Mein Auto: 2008 X5 4.8i
Hi folks. I've searched and searched and can't seem to come across a DIY approach to fixing a peeling top glove box door trim. Can anyone point me in the right direction?
Thanks in advance
Old 09-13-2011, 08:13 AM
finagle69 finagle69 is offline
Get Coded
Would like to see something as well.
I was thinking of using some epoxy.
Old 11-28-2012, 10:33 AM
tyrone guy tyrone guy is offline
tygas
Send a message via AIM to tyrone guy
Mein Auto: x5 2007
same as did u fix it and if so how ???
Old 11-28-2012, 10:59 AM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Thanks in advance
If you bought it new, try getting the dealer to do a goodwill fix for free. BMW knows they had a problem, and may be open to an "after warranty" goodwill fix.
If you didn't buy it new, you're probably out of luck, as such goodwill is typically only extended to the original purchaser.
Old 12-01-2012, 12:08 PM
Fixed it
I ended up following the advise of a few folks and used a VERY thin coat of Gorilla Glue, clamped it, and reinstalled. There are many types of this brand of glue, I used the one that has about 15-20 minutes of working time, and bonds in a couple hours. It's a two part glue, but the kit is just a bottle of the stuff, the 2nd part is water. Hope this helps someone out there.
glove box, repair, trim, x5
