E30 (1982 - 1993)
Old 09-09-2011, 12:57 AM
marineman2 marineman2 is offline
Mein Auto: 85 325e
Weird idle issues
Hi all, I have a very strange issue with my idling. My 325e has a pretty low idle, at about 600 to 700 rpms. This is fine, except every time I turn on the air conditioning, the idle drops to about 300, then the car stalls. I can run the fan on full blast, but as soon as the ac button is hit, the idle drops. I'm baffled. Any ideas?
Old 09-09-2011, 06:32 PM
downhiller's Avatar
livin large
hows it work driving down the road
Old 09-10-2011, 02:47 AM
Genoknox Genoknox is offline
Mein Auto: 1987 325eta
That's sounds like an ECU problem. What year is it? If it is 88 or newer, you can do a stomp test* to see if the code correlating to your problem comes up.
Sent from my T-Mobile G2 using Bimmer
Old 09-10-2011, 02:49 PM
Mein Auto: 85 325e
It's an 85. It only does it when I idle, when I drive it is fine, as long as the rpms are kept high. Is there any way to adjust the idle to keep at 1000 consistently?
Old 09-10-2011, 04:20 PM
downhiller's Avatar
livin large
on the icv theres a screw. you can adjust the idle there. its sounding like you may need a tune up. run a can of sea foam before your next oil change. do a 1/3 in the tank, 1/3 in the oil/ then start the car and put the last 1/3 in the brake booster vaccum line. dont let it go into the booster, make it flow towards the intake
Old 09-10-2011, 08:29 PM
I've seen seafoam do some gnarly things on an 85' how many miles does it have? Id take out the icv clean it w carb cleaner then adjust the screw to about 800-900rpm if it still idles funny get it smoke tested may be a small vacuum leak somewhere.
Old 09-11-2011, 12:39 PM
Mein Auto: 85 325e
It has 130,000 on it. Where can I find the icv? I've heard the back of the intake, but I still can't seem to find it.
Old 09-11-2011, 01:51 PM
downhiller's Avatar
livin large
should be on the passenger side of the intake manifold. bout 5 inches long silver can lookin thing. has i think a 3/4in hose that goes over the intake that goes to vacuum lines. if you check the search i know plenty of people posted pictures of it and where its located
Old 09-11-2011, 04:01 PM
Mein Auto: 85 325e
Found it, adjusted it, and I'm no longer stalling. Thanks a bunch guys.
ac, idle, problems
