Old 09-14-2011, 06:58 PM
alandf's Avatar
alandf alandf is offline
Mein Auto: 2012 535ix
Climate control question
Is there a way to set the climate control so that you are ONLY getting fresh outside air through the dashboard vents ? This time of the year it would be nice to not use the AC but keep the windows closed when driving at high speeds.
Now-2012 535ix-Dark Graphic Metallic II,Black Dakota Leather,Dark wood Trim, Cold-Weather, Premium, Technology, BMW Apps
Prior-2011 528i-Imperial Blue Metallic, Venetian Beige Leather,Prem Pkg, Split fold down rear seat,Heated seats , NAV
Prior- 2008 528i,Black sapphire metallic,Oyster dakota leather
CD,CWP,NAV,PREM PKG,ST,WT
Old 09-14-2011, 07:08 PM
dunderhi's Avatar
dunderhi dunderhi is offline
Next: '18 AMG GT Roadster
Mein Auto: 15 M6 vert, 15 328dxt
Turn the thumb wheel by the dashboard vent to the single arrow. Turn-off the A/C and the automatic circulation control right next to the A/C button. At this point you should only get fresh outside air.
BMWs
2015 M6 Drophead Coupé
2015 328xd Estate
2013 X5M Sport Utility Vehicle
2013 650xi 2 Door Fastback Saloon
2011 Dinan 5 Saloon
2011 335d Saloon
Old 09-14-2011, 07:20 PM
BMW_ACURA BMW_ACURA is offline
Banned
Mein Auto: 535i sport-premium-Nav
r u serious you are asking this question, i see some people ask this question again and again and some one also said that A/C always comes on when you start the car, only the fan comes on and you can definitely turn the A/C of before shutting down
Old 09-14-2011, 07:29 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
What thumbwheel are you talking about? Simply turn off the A/C compressor (snowflake button off). Either let the air distribution mode and fan stay in auto mode or go to full manual to control direction of air (to upper face/dash vents) and fan speed. Note that the system will continue to vary the outlet air temp (adding heat)according to the set temperature. Set it to full low temp if you want ambient air, though heat will still be added on a cold day if the cabin temp is below the lowest set temp.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 09-14-2011, 09:53 PM
gr8nrg's Avatar
gr8nrg gr8nrg is offline
Mein Auto: 2011 528i
That's what bugs me the most about this car...If the outside air temp is a crisp 50 and I want it inside the cabin without AC, I can't get anything less than 60, because the temp wheel won't go below 60 - annoying!!!! This is the ONLY car I've had or rented that is stupid about getting fresh air in!
2011 528i Space Gray Metallic / Black Dakota Leather / Dark Wood Trim / Prem Pack / Nav / PDC / USB-iPod
Old 09-14-2011, 10:23 PM
alandf's Avatar
Thanks-you got the gist of my question that I failed to adequately express.I want plain outside air
Old 09-14-2011, 10:55 PM
bmw_enthusiasm bmw_enthusiasm is offline
Mein Auto: 2011 M3, 550i , 2008 328i
When I turn AC off, I am noticing the air being 'unfiltered?' or something?
do we know if the air passes through micro filter pathway when the A/C is off?
because I had situation when its stinky air from outside and once
you switch to the AC you get such a 'clean' relief ...
but this could be only the reduction on humidity and not filtering effect..
anyone knows?
Old 09-18-2011, 11:34 AM
markl53's Avatar
No car I've ever owned with climate control releases the temperature control to give absolutely untouched outside air. It's not a BMW thing. You'd have to have another control to disable all air temp modification. As far as the system knows you're in a cold weather environment and you chose to turn off the compressor.
BMW-CCA
Old 09-18-2011, 11:55 AM
mstrq's Avatar
mstrq mstrq is offline
8D
Mein Auto: White paint cars
I know what you are talking about. Lexus cars let you do this. (previous car was a Lexus) Even though the climate control is off, it continues pulling in outside air (to filter air, prevent fogging up, etc.). The notification showed on the climate control display panel, and it didn't really get stuffy inside. And no. This feature is not present in Mercedes and BMW cars.
2011 Range Rover Sport HSE with Fuji White and Ocean leather.
2011 E350 4MATIC with Calcite White and Chestnut Brown leather.
2013 650i xDrive cabriolet with Alpine White and Vermillion Red leather coming soon...
Past:
2011 328i Cabriolet with Alpine White with Coral Red leather
2007 ES350 with Tungsten Pearl with black leather
Old 09-18-2011, 11:59 AM
mstrq's Avatar
8D
anyone knows?
AC (snowflake button) dehumidifies the air. That's why the air can feel moldy without AC.
Past:
Old 09-18-2011, 01:07 PM
BobRBob's Avatar
BobRBob BobRBob is offline
Open the sun roof.
Current BMW
2011 BMW 528i
Cashmere Silver/Black Dakota
Ash wood trim
Sport Package
Premium Package
Nav
Premium Sound/Sirius
Comfort Seats
Prior BMWs
2001 530i Sport (deceased)
Cosmos Black
Other
2005 Subaru Outback 2.5XT
1977 Corvette 383 Stroker
