Successful DIY battery replace, is BMW registration necessary ? - Bimmerfest - BMW Forums
Old 09-12-2011, 12:20 PM
lcompy lcompy is offline
Mein Auto: 2007 BMW 525i
I read where some say it's necessary for BMW dealership to register battery replacement, and some say not. My 2007 525i is running great with new battery, so do I still need to register ??
Old 09-12-2011, 02:19 PM
Blk530 Blk530 is offline
Mein Auto: 530i
Your car should run fine without registering it. But from what I've learned, our cars employ a smart charging scheme tailored for an absorbed glass-mat (AGM) battery. It varies the charging rate according to the age of the battery to keep it optimally charged. If you get a new AGM battery and don't register it, the car may over-charge the new battery and possibly shorten its life. If you end up getting a standard Pb-acid replacement battery, the car may under-charge it.
Take a look at the thread below, it has lots of info and shows you what others have chosen to do.
http://www.bimmerfest.com/forums/sho...gister+battery
Old 09-12-2011, 05:28 PM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
Also take a look at post #13 of thread below:
http://www.bimmerfest.com/forums/sho...d.php?t=566899
2008 535i Monaco Blue
PP, SP, SAT w/paddles, ARS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Trim,
Gray Dakota Leather
Old 09-13-2011, 09:45 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Well I have replaced my battery today with Deka battery. It's special made battery to fit our cars perfectly. So it's 200 bucks battery. Anyway about registration, I drove on this battery right from battery warehouse (Leesburg VA) to my friend's shop in Leesburg, I drove about 2 miles something. So after a little digging around in the computer to find right menu with battery registration, we finally found it. So during registration, it asked when (date) was battery replaced, then it's automatically showed miles but it's less two miles (distance from warehouse to shop) then it showed on my dashboard. So it seems to me the car(computer) knows that was installed a new battery. So all this registration to me it's just BMW collecting money from their credulous costumers and the free durability information for their financing planning. It's nothing to do with battery charge.
Noted: I have used a small 12 V battery to keep setting current.
BMW CCA Member, Capital Chapter
Old 09-13-2011, 10:17 AM
Smile thanks guys
thanks everyone for your replies and insight. It's great to be able to exchange info and help each other here, so here's what I ended up doing.
This past Sunday, we went shopping and our last stop was near an O'Reilly's auto store. The car was getting harder to start after each location we visited. Well, it finally happened, the car wouldn't start, but we were parked a couple hundred yards from the store, so I went down there, the employee came and tested the battery, show'd me the results, and it was a gonner.
Ended up buying their premium battery, that has 950 cca, which is better than the OEM, plus, it's made in Germany, specifically for my car, and fit's perfectly. We hooked up a core to the charge terminals under the hood to keep the car with some power, replaced the battery, and now, two days later, it shows no sign that it is different. All settings are still there, and it starts like it used to. We are very happy.
To Blk530's point, it's a standard Pb-acid replacement battery, and if it under charges this battery, I have a battery tender that I use, so it's simple to hook up, and I'll know if it's being under charged, and can keep it in a charged state.
As for registration, I found an indy that will do it for $70.00, but I think I'll just save the money and monitor the battery using my battery tender. I found that I could buy three batteries for what a BMW dealship would rip me off for if I went there.
Thanks, and I hope my story helps others that view this thread.
Old 09-13-2011, 10:44 AM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: E92 335i
Originally Posted by lcompy View Post
t
Do both the registration and the battery tender. The registration tells your car the battery is new so it does not over charge the battery which will shorten the life of the new battery. This doesn't occur in a day/week/month, but it will slowly and systematically kill the battery due to overcharging it because the car thinks the battery is older than it is.
Old 09-13-2011, 11:44 AM
phlfly's Avatar
Mein Auto: 07' 550i
Did you read my post #4?
Old 09-13-2011, 03:09 PM
hairball's Avatar
hairball hairball is offline
Mein Auto: 2014 X3 35x
1. New battery + no registration = minimal/modest battery life
2. New battery + registration = maximum battery life
Old 09-15-2011, 07:44 PM
rwvw415 rwvw415 is offline
Mein Auto: 2015 550i M Sport
I installed my own battery and did not register it. That was a year ago and I have not had any problems. With the cost of registering the battery I can buy a new battery every 2-3 years and be money ahead.
2015 550i M Sport
Black/Black
2010 650i Coupe
Black / Black
2007 550i Sport
Silver / Gray
1998 528i
Red/Gray
Old 09-18-2011, 06:23 AM
Gold323Ci Gold323Ci is offline
Mein Auto: 12 535, 12 x5, 08 650i
You think like me. You might even sell the car (like me) before you need another battery.
Let us know if your newest battery needs an early replacement. If it only lasts a few more months, I might change my approach.
Old 09-18-2011, 02:20 PM
The battery I bought has a 3 year free replacement warranty, so I think I'm covered.
Old 09-19-2011, 01:22 PM
RedDvl33's Avatar
RedDvl33 RedDvl33 is offline
Glory Glory!!
Mein Auto: 2007 BMW 530i
Does anyone have a current DIY for the Battery Replacement? I know there was one from RatherBeInCabo back in the day, but his Flickr account is no longer in use. Anyone have any quick tips or tricks other than the typical unbolt, take out, rebolt method?
| '07 530i | Mystic Blue Metallic | Auburn Leather | Sport/Premium |
RIP
2000 Toyota 4Runner
1997 Chevy Silverado
Old 09-19-2011, 05:48 PM
phlfly's Avatar
Mein Auto: 07' 550i
yes it's unbolt, remove and install. But i will recommend to get a small 12V power source, either connect to cigaret lighter or under the hood on driver side.
Old 09-19-2011, 06:03 PM
TheViolentVicar's Avatar
TheViolentVicar TheViolentVicar is offline
Plate O' Shrimp
Mein Auto: 2008 535xi Wagon
So like if I totally connect a second car to the jumper terminals under the bonnet, will I like totally be able to replace the battery without resetting like everything? Totally?
Sounds bitchen.
Pax vobiscum.
2008 535xi Estate | Deep Sea Blue Metallic | Bamboo Anthracite | Sexy Charcoal Interior Except for Posh-Spice-Cleavage-Colored Comfort Seats | Belly Button Lint | Magic Don't Need No Key Package | Get Very Bad Directions Package | Intra-Uterine Bass Drum | Doesn't Work With Most Phones Package | Fila Brasileiro Snot All Over Rear Windows | Heated This, That, and the Other | Very Considerate Headlights | White-Knuckled-Passenger Package | JB4 |
Old 09-20-2011, 05:45 AM
w5lx's Avatar
w5lx w5lx is offline
Mein Auto: 2008 528i/2007 328i Coupe
How would the cigarette lighter work? In every BMW I have owned the cigarette lighter is disconnected from the electrical system when the car is off.
P.S. Do yourself a favor and heed TJPark01's advice:
The number of people who will buy a $50-$70K automobile, throw in a cheap Walmart battery and totally ignore the manufacturer's advice to register the battery to the charging software that regulates the charging system in the car amazes me.
Old 09-20-2011, 08:05 AM
phlfly's Avatar
Mein Auto: 07' 550i
I have never tried on BMW, I have a small 12V battery that can be used just to keep electronics on. Well in this case only solution is connect under the hood.
Well registration will be useful but is not important. Find some small shop that has BMW computer and they will reset it for you.
Old 05-10-2012, 09:20 PM
itscoo2pyopants itscoo2pyopants is offline
Mein Auto: 04 325ci, 05 4.8is, 09 M3
Any update on this? The people that purchased aftermarket batteries without registration, any problems?
Old 05-10-2012, 09:38 PM
TJPark01's Avatar
Mein Auto: E92 335i
People need to seriously stop being cheap about this. Register the battery.
This is from DIS software, which is used at the BMW dealerships, so it should be the last word on whether we need registration for a new battery....
We do.
Old 05-10-2012, 09:40 PM
Laci535i Laci535i is offline
Mein Auto: 2009 535i
I have an 09 535i and the battery acting up already. I guess it wasn't registered at the factory??? Somebody said in another post that our car would "overcharge" the battery. When was the last time an E60 overcharged anything? Why is a 60-70K car need a battery tender/charger? Why is it not replaced under warranty? (VW did with no questions asked.) Why would the entire car has to wake up when you just open the door to get your wallet from the car? It is pretty much a bad design if you ask me. I am scared to open the sunroof because I am not sure I can close it without an error message. Dealer would blame me for using it wrong or something.
Old 05-10-2012, 09:52 PM
I'd like to save a couple bucks if I could.
Dealer quoted me 1300 to replace secondary air valves.. I did it myself and paid for $200 in parts.
They quoted me 1100 for a Guibo, again did it myself for $170.
If the only problem with not registering the battery is shortening the life of the new battery, I can buy 3-4 batteries for the price of 1 with registering. Just wanted to check in with the people above that are running aftermarket batteries with no problems.
Is it really worth $100 for installation? 2 bolts right?
Old 05-10-2012, 09:59 PM
I am with you, man! 2 bolts for the bracket and one each post. Easy money for the stealer plus another $100 for registration to get 2-3 month extra battery life? It is a joke! Autozone 3 year replacement warranty and prorated to 8 years. And the battery is $160.
Old 05-10-2012, 11:58 PM
gcvt's Avatar
gcvt gcvt is offline
Mein Auto: 2008 550i, Sportsmobile
I put in the Duralast battery a while back and did not pay to have it registered. Everything is fine so far.
2008 550i, Sport Package, Sport Transmission, Active Steering, Navigation, Comfort Access, L7 Audio, Miro 111 wheels 19", full MagnaFlow Exhaust.
Old 05-11-2012, 05:41 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
But replacing an alternator because it has been overworked will cost way more than the modest savings realized from not registering a battery.
Old 05-11-2012, 03:47 PM
borderchris's Avatar
borderchris borderchris is offline
Was ist los? Der Hund!
Mein Auto: F10 528i
Absolutely wrong. Your charging strategy will be set to overcharge the new battery, and possibly damage your alternator. It's not snake-oil- Just pay the $100.
2012 F10 528i . Sport . Premium . Technology
2007 E92 335i . Space Grey . Premium . Sport
2006 E85 M Roadster . Alpine White . 6MT
2006 E60 550i . Sapphire Black . A5 . Sport . Premium
2003 E39 530i . Titanium Grey . 5MT . Sport . Premium
1989 E34 535i . Black . A4 . Premium . RIP
1981 E28 530 . Grey . A4 . German Specs .
1977 E21 320 . Light Blue . 4MT . German Specs .
Old 05-11-2012, 05:15 PM
roboe60's Avatar
roboe60 roboe60 is offline
Mein Auto: 09 X5, 05 530i & 01 740i
Not sure on the E60, but my E38 rear console lighter always has power to it. In fact, that is where my BMW tender connects to maintain the battery. BMW recommends not using this particular tender on the E60, due to the complexity of the electronics.
