E28 (1982 - 1988)
Old 09-18-2011, 12:59 PM
CanadianE28 CanadianE28 is offline
Mein Auto: 528e
Tachometer and onborad computer won't work :mad:...
Hi there
I have a 88 528e which in the past has had the fuse connection for the tachometer, onboard computer and odometer go out (also the stereo, but another owner changed the original hook up I believe).
I had repeatedly tried fuses and working with the connections, but as of late, I think it might be done.
Does anyone have a troubleshooting idea?
Thanks for any suggestions.
Ken Wood
Old 09-18-2011, 01:41 PM
catso's Avatar
catso catso is offline
catso
Originally Posted by CanadianE28 View Post
Hi there
Ken Wood
Corrosion, particularly on the instrument cluster or the connecting wiring could be a problem. A bad SI board will usually blow the fuse for the computer and tach. Search "SI board". The odometer might be a separate problem with worn gears, rather common with older BMW's. Older cars start having lots of electrical issues. Check the connections and wiring very carefully. Sometimes the corrosion is inside the insulation where it can't be easily detected.
![/I][/FONT]
Old 09-18-2011, 02:18 PM
Mein Auto: 528e
Thank you Catso, I will look into the wiring. That sounds very logical. In the past I have jiggled or moved the fuse and it works fine. Now, nothing.
Old 09-18-2011, 03:08 PM
catso's Avatar
catso
The fuses and fuse holders are known problem areas. Sometimes a fuse looks good but still doesn't work due to a small crack, looseness, etc. Try changing the suspect fuses with new ones and clean the contact areas.
![/I][/FONT]
