Old 09-19-2011, 05:59 PM
jcvara jcvara is offline
Mein Auto: 01 525i
e39 fan clutch removal, need help
I am trying to finish my cooling system overhaul but cant seem to loosen the fan clutch off of the water pump, any suggestions???
Old 09-19-2011, 06:06 PM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
32mm wrench and a small hammer always works wonders for me.
Fudman's Avatar
Fudman Fudman is offline
There are three common approachs:
1. Use the belt friction to hold the clutch while whacking the 32 mm wrench. (see the Beisan DIY)
2. Use the fan clutch holder tool (~$20) to hold it in place and a 32 mm wrench.
3. Use a screwdriver and wedge it into the clutch to hold it. (This is a cn90 trick)
I find the fan clutch tool works easiest with lowest risk of causing damage. Put a dab of anti-seize on the threads when you reassemble for easier future removal.
Old 09-19-2011, 06:13 PM
Mein Auto: 01 525i
the screwdriver is not working and I am stuck
Old 09-19-2011, 06:21 PM
Mein Auto: 01 525i
where is that cn90 trick?
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
I hate to overstate the obvious, but it is a LEFT HAND thread.
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 09-19-2011, 06:25 PM
Mein Auto: 01 525i
yes, that I know but it is not budging
Old 09-19-2011, 06:46 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
This one takes a little bit of finese but it is a great tool. I think I paid around $20 for it.
https://www.napaonline.com/Catalog/C...139_0282458551
Old 09-19-2011, 07:14 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
whack it quick and furious, like it didn't know what hit it.
Old 09-19-2011, 07:16 PM
540indiana's Avatar
Play some Bobby Brown, Chris Brown to get you motivated
Old 09-19-2011, 07:23 PM
16valex's Avatar
Never heard of these guys.........
Old 09-19-2011, 07:36 PM
occhis occhis is offline
Mein Auto: 1998 528iA
I tried for what seemed like hours to loosen mine with all sizes of screwdrivers, along with anything else I could think of, with no success. Got the fan clutch tool and it came off in seconds. Facing the car, turn the nut clockwise.
Either you are part of the solution, or you are part of the problem.
Old 09-19-2011, 07:41 PM
Old 09-19-2011, 07:42 PM
540indiana's Avatar
???? Bobby Brown beat Whitn..... Never mind. Just google Bobby or Chris Brown and the word beating, hitting, smacking, punching etc....
Old 09-19-2011, 07:48 PM
Mein Auto: 01 525i
Where did you get your tool?
Old 09-19-2011, 07:49 PM
Boostted Boostted is offline
Mein Auto: 530
What are you using to hit the wrench?
Old 09-19-2011, 07:52 PM
Looks just like this:
http://cgi.ebay.com/ebaymotors/BMW-W...ht_3036wt_1165
Old 09-19-2011, 07:53 PM
Mein Auto: 01 525i
a sledge hammer
Old 09-19-2011, 08:03 PM
BMW Magician
Originally Posted by jcvara View Post
a sledge hammer
Small hammer sir, it's all about the velocity of the swing, not the mass behind it.
Old 09-20-2011, 12:55 AM
- All you need to know about BMW cooling system overhaul fan clutch nut counterhold tools (1)
For example, this is me using the tool on my M54:
But, others use varying approaches:
I guess the trick is to get enough mechanical force:
People try all sorts of things:
But 'this' is the counterhold tool set to die for!
Old 09-20-2011, 01:49 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
mine come off with a adjustable wrench...
can i make that post any larger? this is what everyone missed every time...
LEFT HANDED THREAD
means you have to tightening it
15486372<-----
Old 09-20-2011, 06:46 AM
Fudman's Avatar
ZDMack has the tool for $20
http://www.zdmak.com/wbstore/main.as...at=BMW%20TOOLS
Old 09-20-2011, 10:37 AM
Here's that referenced ZDMack tool, because links are ephemeral ...
Old 09-20-2011, 11:14 AM
rph74 rph74 is offline
Send a message via AIM to rph74
Mein Auto: 98 540ia Sport
That has worked for me several times too. I would also add that I hold the pulley with my gloved left hand, and whack the wrench with a hammer with my right hand.
99 Toyota Land Cruiser, 08 Dodge Ram Quad cab 4wd 6-speed manual, 01 BMW X5 4.4 All high mileage, but paid for!
An armed society is a polite society
Old 09-20-2011, 11:38 AM
harris2p harris2p is offline
Send a message via Yahoo to harris2p
Mein Auto: 1998 BMW 528i (02/98)
Call around for a shop that will do this for a small fee.
I had this problem in October 2 years ago. the special BMW Clutch Removal tool didn't help me ... I was about to cause some collateral damage or brake/bend a few fan clutch (water pump) bolts.
I drove the car without the cooling fan, going below the speed limit (40 mph) for 4 miles to a shop, waited for 20 minutes, and heard the mechanic working on it for ~60 seconds using some type of air tool. They charged me a cheap $20. Of course, I called them before driving there.
